    • Ei ref-linkkejä
Tekniikka AdGuard Family Plan: Lifetime Subscription-devices: 9-$16
Tuote:
Tarjoushinta: $18.97 = $16 AdGuard
Normaalihinta
: $79
Kauppa: stacksocial
Voimassa:
Linkki: AdGuard Family Plan Lifetime Deal | StackSocial
Promokoodi: AdGuard
Kommentti tarjouksesta
: Promokoodi: AdGuard =$ 2.97,$18.97-$ 2.97=$ 16
Missä olemme
AdGuard on paikassa Limassol, Kypros.
AdGuard Software Limitedin virallinen osoite on Anexartesias and Athinon 79, Nora Court Flat/Office 203-205, 3040 Limassol, Kypros.
Where we process your Personal Data
We store your Personal Data in our own data center located in Frankfurt, Germany. Your Personal Data may be processed by our employees, who can only access your data through their job duties on a need-to-know basis. If you have questions or would like to know from which countries your Personal Data may be accessed, you can write to us at privacy@adguard.com.
For data transfers to other countries, we always implement appropriate safeguards to ensure that your Personal Data always remains safe and that your rights are respected:
  • The country or the third party is recognized as providing adequate protection.
  • A valid transfer mechanism is used, such as the Standard Contractual Clauses, and additional measures are implemented where necessary.
  • The transfer has your explicit consent.
  • The transfer is necessary for the performance of a contract with you or to take steps requested by you prior to entering into that contract.
If you would like a copy of the Standard Contractual Clauses used, please contact us at privacy@adguard.com. To determine if a non-EU country has an adequate level of data protection, please visit the European Commission website.
    88 KB · Luettu: 76
    104,9 KB · Luettu: 19
    66,6 KB · Luettu: 19
En oikein ymmärrä. Miten kännykkä-sovelluksen voi ostaa nettisivun kautta?
Latasin tuon sovelluksen Play-kaupasta ja katselin, niin heti ensimmäisten ruutujen aikana tuo sovellus kertoo, että se toimii vain Yandex Browserilla sekä Samsung Internet Browserilla.
Itsellä on käytössä Brave-selain, joten ei taida itsellä toimia tämä.
Luulin ensin että tämä on sellainen sovellus joka asentuu puhelimeen siten, että se estää koko puhelimesta kaiken, mukaanlukien kaikkien sovellusten sisäiset mainokset.
Brave-selaimessahan nämä mainostentorjunnat ovat vakiona päällä ja on ilmainen sovellus.
Androidille joutuu lataan sovelluksen täältä Ad Blocker for Android by AdGuard for rooted and unrooted devices | AdGuard. IOSlle saa ihan appstoresta. Blokkaa sovellusten sisäiset mainoksen psl. YouTube, Reddit yms.
Latasit todennäköisesti väärän ohjelman. Tuolta: AdGuard — Maailman kehittynein mainosten esto! Saat parhaan mainosvapaan kokemuksen
Edit: Hidas.
Siis tämä sovellusko pitää ladata nettisivun kautta, eikö löydykkää play-kaupasta?
/löyty Samsungin Store-appistä tuo
Ei löydy Play-kaupasta, koska tuohan taistelee Googlen bisnesmallia vastaan.
Kun asensin tän nyt, asetuksista löytyy valikko adguard VPN, pitääkö se nyt kans ladata vai onko se maksullinen?
Ei pidä. Se on maksullinen. Ohjeet löytyy parhaiten osoitteesta Installation | AdGuard Knowledge Base
IPhonella blokkaa mainokset myös peleistä (joissakin saattaa edelleen näkyä, riippuen toteutustavasta). Iphonella täytyy olla VPN päällä (ei pidä sekoittaa adguard VPN erilliseen ohjelmaan ja lisenssiin) tai DNS vaihdettu adguardin serveriin.
En ymmärrä tätä kohtaa. S23 ultra, ei näy mitään asetusta tuolla. Pitääkö olla rootattu puhelin?
    70,5 KB · Luettu: 314
Käytän Mulvadin tai NextDNS:n DNS:iä, eikä mainoksia tarvitse niilläkään katsella. Saako Adguardista merkittävää lisäarvoa?
Näyttää asetusten otsikot ja valikot muuttuneen.
Olettaisin että stepit menee kutakuinkin näin kun katsoin omaa S23 Ultraa:
Security and privacy -> More Security Settings -> Install frofm device storage -> CA certificate -> Install Anyway (hyväksy varoitus) -> valitse tiedosto ja asenna.
Tämä AdGuard vaikuttaa ihan mielenkiintoiselta tuotteelta, mutta en ehkä aivan ymmärrä, mihin kaikkeen se soveltuu. Seuraavassa muutama kysymys:
- AdGuard on ilmeisesti saatavilla myös selainlaajennuksena esimerkiksi Firefoxiin. Kuuluuko tämä ominaisuus myös tuohon tarjouksessa olevaan tilaukseen? Entä miten AdGuard vertautuu ilmaiseen Adblock Plussaan?
- Ymmärsin yo. keskustelusta, että kännykällä (Androidilla) sovellus blokkaa myös muissa ohlemissa kuin selaimissa olevia mainoksia. Toimiiko se esimerkiksi myös Youtubeen?
- AdGuardin sivujen perusteella se on saatilla myös AndroidTV:lle. Blokkaisiko se siinäkin esimerkiksi Youtuben mainokset? Tai jopa muiden "mainosrahoitteisten" suoratoistopalvelujen mainokset (Ruutu/Katsomo/jne)?
    66,6 KB · Luettu: 89
    104,9 KB · Luettu: 88
Noin kuukausi sitten oli tämä sama tarjous. Ajattelin silloin kokeilla tätä, kun ei ole iso menetys jos ei toimi.
Minä olen ollut tyytyväinen ohjelmaan ja esim. YouTuben mainokset on toistaiseksi blokannut.
Kaikkia mainoksia tämäkään ei saa pois, mutta tähän mennessä olen ollut tyytyväinen ohjelmaan.
[QUOTE="Jumpe, post: 15416129, member: 36600
[/QUOTE]
Tuossa ylempänä mainittiin, ettei blokkaa Youtuben mainoksia. Siihen toimii Revanced.
Edit: blokkaa ilmeisesti kuitenkin?
[/QUOTE]
Ei blokkaa android apissa (siihen vanced) tai televisiossa... Selaimessa kyllä
Niin tämähän on ollut nyt silloin tällöin alessa ja täällä ilmoiteltu (kiitokset siitä). Aika paljon on ollut keskustelua tämän ympärillä ja aikaisempiin tarjousketjuihin kerääntyi ihan hyödyllistä tietoa (vastauksia yleisimpiin kysymyksiin). Useimmat pitää todella hyvänä ohjelmana. Tuossa aiemmat ketjut:
Juu kiitos. Täytyi ensin kääntää englannin kieliseksi puhelin nii löyty
Toimiiko tämmönen ku lapsella on iphone, niin voiko senki pelien sisäiset mainokset estää, vai onko tää vaa androidien ominaisuus?
Itsellä on toiminut iPhonella ihan hyvin ainakin nettiä selatessa, pelejä en oikein pelaile niin en niistä osaa sanoa kovin tarkasti. Muistaakseni vähän riippuu sovelluksesta/pelistä miten hyvin tuo mainostenesto toimii.
Kuinka asennan tämän nyt toiseen puhelimeen, käytänkö tätä samaa lisenssiä vain ja sillä on selvä. Vai pitääkö mun omalla puhelimella tehdä jokin tunnuksen jako?
Eikös tämä Adguard ole venäläinen ohjelmisto vaikka pääpaikka onkin Kyproksella? Mitäs tietoja appi tarvitseekaan toimiakseen?
Ainakin yhdessä edellisessä ketjussa, mitkä yläpuolella on lueteltu, löytyy keskustelua aiheesta.
En huomannutkaan, että tästä on ollut paljon keskustelua jo aiemmin. Täytyy tutustua niihin... Hiukan tuo mahdollinen kytkös Venäjään kuumottaa.
Sellanen kusetuksenmaku jäi taas suuhun ettei ole tosikaan. Paypal ei mennyt läpi, koitin uudestaan. Nyt on sitten kaksi hylättyä katevarausta roikkumassa tuolla ties miten pitkään ja saa taas imeskellä pikkukiviä.
Ipadiin latasin Adguardin ja kirjaannuin googletunnuksilla.
Niin: you have succesfully logged into your adguard account but there are no license keys that allow yout to activate the Premium version.
Kokeilin tietokoneelle ladata adguardin ja googlen tunnuksilla sisälle ja se toimii.
Siinä lukee että Standard licence lifetime.
Onko tosiaa että ios ei toimi tällä, vaikka siellä mainostettiin sitä..
toimi itsellä ainakin, kirjautumiseen sähköpostiosoitteen tilalle laitetaan se aktivointikoodi.
For iOS
  1. Tap the Redemption Link above
  2. Choose iOS as the platform to install the application
  3. Then, open the app and tap 'Settings'
  4. Tap 'License'
  5. Tap 'Restore purchase'
  6. Tap 'Use AdGuard account'
  7. Enter your license key in the email field and leave the password field blank
  8. Tap on 'Log in' to activate the key
Ios aktivointi tapahtuu hieman erilailla. Juuri ihmettilin samaa asiaa, kun yritin aktivoida uutta laitetta aikaisemmin hankitulla adguard stacksosial lisenssillä ja enkä enää muistanut kuinka se tapahtuu. Stacksosial sivuilta löytyi ohje, jonka mukaan aktivointi onnistui, eli pelkkä lisenssiavain email kenttään.
For iOS
4. Tap 'License'
How to Redeem Your Purchase
Please follow the steps below to redeem your purchase
For PC
1. Click the Redemption Link above
2. Choose Windows as the platform to Install the application & click 'Download'
3. After downloading, install the application
4. Click Leave settings as is and click 'Ok'
5. Click 'License', then click the 'Activate License' button
6. Switch to 'License Key'
7. Copy & paste the above License Code into the 'Enter your license key' box
8. Click the 'Activate license' button
For Mac
2. Choose Mac as the platform to install the application & click 'Download'
4. Click Leave settings as is & click 'OK'
5. Then, click 'Settings' (gear icon) & choose 'License'
6. Click the 'Activate' button
7. Switch to 'License Key'
8. Copy & paste the above License Code into the 'Enter your license key' box
9. Click the 'Activate' button
For Android
2. Choose Android as the platform to install the application
3. Open the app and tap the X button offering prices and 7-day Free Trial
4. Then, go to Settings (gear icon)
5. Tap on 'License'
6. Tap on the 'Activate license' button
7. Tap on 'Use license key'
8. Enter your license key
9. Tap on 'Activate'
For iOS
4. Tap 'License'
You’re all set! You’re now subscribed to Adguard Family Plan: Lifetime Subscription.
Ei nyt varsinaisesti vastaus sinulle kun kerran ostit ja asensitkin jo, mutta kertauksena vielä mahdollisesti muille ihmettelijöille niin "EI" tätä ei saa play-kaupasta juuri siksi, että Google ei hyväksy siellä mitään adblokkereita ja päinvastoin yrittää taistella niitä vastaan joka puolella.
For iOS
  4. Tap 'License'
For iOS
4. Tap 'License'
For PC
For Mac
For Android
5. Tap on 'License'
For iOS
4. Tap 'License'
no jo on keinot. kiitos paljon!
Vaikka sovellus on laadukas ja edullinen niin muistutuksena, että tämä on venäläinen tuote.
Ylläpito poisti viimeksi tämän kommentin vaikka hyväksyy muissa tarjouksissa (Pingviini jäätelö) maininnat Venäjä-kytköksistä. Mielestäni ihan aiheellinen maininta.
Missä olemme
Toki, dataa prosessoidaan ja säilytetään Saksassa ja muutenkin EU-säännöksiä noudatetaan, mutta tuossa mainitaan että työntekijöillä on pääsy dataasi.
AdGuardia hallinoidaan Venäjältä käsin ja luultavasti työntekijöitä löytyy myös Venäjän rajojen sisäpuolelta. Kikkakolmoset varmasti hallussa. [1]
Tässä heidän vastaus:
"Our head office is physically located in Moscow, however, legally AdGuard is a Cypriot company and abides by the EU laws.
The iOS app is no different to any other app that's developed by AdGuard team in that regard." [2]
[1]
[2]
Löytyy lisää googlaamalla.
Jokaisen oma valinta haluaako tukea venäläistä firmaa. Halusin vain tuoda esiin tällaisen Venäjä-kytköksen.
Edit. Mainitsivat itse 2v sitten, että pääkonttori sijaitsee Moskovassa [2]. Tällainen työkalu tuskin noin vain katkaisee napanuoraa, varsinkin jos miettii miten hyödyllistä dataa SRV & FSB pystyy keräämään ulko -ja sisäpuolelta.
Ei saa lisäarvoa; NextDNS:ään voi listata about samat estolistat mitä AdGuard käyttäisi. Pientä lisäarvoa voisit saada jos käytät AdGuardin iOS Safarin plugaria, mutta se taitaa muutenkin olla ilmainen.
Youtuben mainoksia ei voi estää verkkoliikennettä suodattamalla, vaan ainoastaan selaimen plugarilla, johon pöytäkoneilla uBlock Origin on paras ja puhelimilla taas esim. Brave torjuu ne. Käyttökokemus mobiiliselaimessa ei toki ole Youtube appiksen veroinen.
Omasta taloudesta poistin kokonaan AdGuardit taannoin, kun NextDNS ja selainten laajennokset riittävät, ja ne venäjä-kytkökset hiertävät.
[1]
[2]
Jos EU-yritys palkkaa venäläisiä, onko se rikos vai virhe?
Jos EU-lakeja noudattava yritys palkkaa venäläisiä työntekijöitä, onko se huono yritys?
Onko kukaan saanu ostettua tätä Curven kortin kautta tai jos tulee virheilmoitus "State must be filled".
Kaikki on täytetty, mutta ei mee läpi.
Jokainen toki päättäköön itse jos mahdolliset tai oletetut venäjä yhteydet haittaa, sen verran voisi mainita että ovat tainneet itsekin ilmoittaa että heillä on ollut ja on varmaan edelleenkin toimisto myös Ukrainassa, ellen ihan väärin muista.
Tohon Youtube hommaan korjaus, että vaikka en tekniikasta ton taustalla paljon tajuukaan minusta AdGuard nimenomaan verkkoliikennettä suodattamalla ne Youtube mainoksetkin estää ja toimii se mulla ainakin Win koneessa ihan hyvin ettei tarvii mainoksia Youtubessa katsella.
Ja jos tekniikasta, tietoturvasta, privacy ja adblocking asioista haluu pysyy ajantasalla kannattaa seuraa Adguardin blogi postauksia, siellä hyviä artikkeleja usein just koskien Youtubenkin & Googlen uusimpia juttuja miten yrittävät estää adblokkerien toimintaa.
Tottis
