Myydään Corsair PC4-19200 32GB 2x16GB DDR4 2400MHz CMK32GX4M2A2400C14 (Vantaa)
Tuote: Corsair PC4-19200 32GB 2x16GB DDR4 2400MHz CMK32GX4M2A2400C14
Hinta: 100 euroa
Tuote ostettu (mistä ja milloin): Mindfactory.de 2017
Kuitti löytyy (takuu voimassa): kuitti sähköisenä, muisteissa taitaa olla limited lifetime warranty, mutta ei tietoa miten käytännössä toimii
Löydetty kaappien siivouksen yhteydessä. Ollut itsellä aikoinaan Ryzen 1 buildissa jonka jälkeen seissyt vuosia kaapin pohjalla odottamassa käyttökohdetta/myyntiä.
The Corsair VENGEANCE LPX memory kit consists of two 16 GB DDR4 modules, providing a total capacity of 32 GB. It is engineered for high-performance overclocking in systems with Intel and AMD motherboards. Operating at a frequency of 2400 MHz with a CAS latency of 14, this memory is built to deliver stable performance for demanding applications. The low-profile design ensures compatibility with most builds, including small form factor cases or systems equipped with large CPU coolers.
Each module features a heat spreader made of pure anodized aluminum for effective heat dissipation. The design incorporates an eight-layer PCB that assists with thermal management and supports stable overclocking. This kit is optimized for wide compatibility with Intel 100 through 600 Series and AMD 300 through 500 Series chipsets. Support for Intel XMP 2.0 allows for simple, one-setting configuration to achieve the rated memory speed in the system BIOS.
Key Features:
  • Memory Capacity: 32 GB (2 x 16 GB)
  • Memory Type: DDR4
  • Speed: 2400 MHz
  • Latency: CL14
  • Voltage: 1.2 V
  • Form Factor: UDIMM
  • Modules: 2
  • Heat Spreader: Anodized aluminum
  • Intel XMP 2.0 Profile: Supported
  • Compatibility: Intel 100-600 Series, X299; AMD 300-500 Series
Paikkakunta (ilmoita myös otsikossa ja tagissa): Vantaa 01390
Toimitustapa: nouto, postitettuna +6 euroa
Maksutapa: käteinen, mobilepay
JuhaniOwnaa
