- Liittynyt
- 30.06.2018
- Viestejä
- 219
Hinta: 110
Tuote ostettu (mistä ja milloin): 11.1.2018 SoundImports
Kuitti löytyy (takuu voimassa): kyllä, 12kk?
Myydään järeä kasituumainen tee-se-itse miehelle/naiselle! Dayton Audio on kotihifin terävintä kärkeä ja tätä elementtiä ei suomen markkinoilta edes saa. Käytetty ~10h.
Tässäpä on speksit lontoon kielellä:
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
Highlights
* Extensively vented motor eliminates power compression and allows quiet excursion
* Triple shorting-ring motor for ultra-low distortion
* Heavy-gauge aluminum cones withstand pressures of small enclosures
* 4-layer high-temperature coils for maximum power handling
* Durable aramid fiber spider for greater mechanical control
* Unique, high-end look
* Optimized for small enclosures
Product Details
Dayton Audio RSS210HO-8 8" Reference HO Subwoofer 8 ohm
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intemodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
PRODUCT SPECIFICATIONS
Nominal Diameter 8"
Power Handling (RMS) 300 Watts
Power Handling (max) 500 Watts
Impedance 8 ohms
Frequency Response 30 to 1,500 Hz
Sensitivity 83.5 dB 2.83V/1m
Voice Coil Diameter 2"
THIELE-SMALL PARAMETERS
Resonant Frequency (Fs) 29.6 Hz
MMM
Sijainti: JKL, kulkeutuu 18.7 Suomussalmelle asti. 1.9 muutto Ouluun josta löytyy sitten syyskuussa.
Toimitustapa: nouto, posti
Maksutapa: käteinen, rahat tilille
Kuva:
