Myydään DW5930e T99W175 5G Module PCI Express M.2 Card for dell
Tuote: DW5930e T99W175 5G Module PCI Express M.2 Card
Hinta: 50
Tuote ostettu (mistä ja milloin): ebay
Kuitti löytyy (takuu voimassa): ei
1. Function: The T99W175 is intended for laptops or any other device compatible with PCI Express M.2 slot specification 3042 type key B.
2. Support: T99W175 is a data card solution that provides wireless wide area (WWAN). 5GNR (Sub 6G), LTE, UMTS (HSDPA, HSUPA, HSPA DC) connectivity HSPA+ and GPS, Gloonass, BeiDou, Gileo protocols.
3. Easy To Use: This module is ideally suited for many applications due to the unique combination of performance, security and flexibility.
4. Uses: Modem plug for 5G laptops, PCIE mode only, not for USB ports. Does not apply to usb adapters, only to SIM cards.
5. Applicable Model: For Lattiude 9420 2 in 1, for Lattiude 9430 2 in 1, for Latitude 9520 2 in 1, for 7560, for 7760.
Specification:
Item Type: 5G Module
Product Material: PCB
LTE Band: 1, 2, 3, 4, 5, 7, 8, 12, 13, 14, 17, 18, 19, 20, 25, 26, 28, 29, 30, 32, 34, 38, 39, 40, 41, 42, 46, 48, 66, 71
LTE 4x4 Band: 1, 2, 3, 4, 7, 25, 30, 38, 39, 40, 41, 42, 48, 66
LTE Category (DL UL) : 20 13
LTE Maximum Speed (DL UL) : 2000Mbps 150Mbps
NR NSA Band: 1, 2, 3, 5, 7, 8, 12, 20, 28, 38, 41, 66, 71, 77, 78, 79, 257, 258, 260, 261
5G: 1, 2, 3, 5, 7, 8, 12, 20, 28, 38, 41, 66, 71, 77, 78, 79
WCDMA: B1, 2, 4, 5, 6, 8, 9, 19
Paikkakunta (ilmoita myös otsikossa ja tagissa): Vantaa
Toimitustapa: posti, nouto
Maksutapa: käteinen, tilisiirto
Kuva:
johanlauren
