Lancool 216 Daddy's white Boomerbuild
  • Keskustelun aloittaja Keskustelun aloittaja Vmale
Eli menee englanniksi koko setti koska selitän paremmin sillä kielellä mutta tyytyväinen olen tähän asti vaikka nyt viime rakentelusta onkin 4-5 vuotta
Maalina oli rakentaa tehokas/budjetti/EI sähköä vievä kone 1440p pelaamiseen.
So been building PCs since early 1990s but since my 9600k build I haven't done anything crazy and even that build was in a Corsair 600T case from 2012 that I modded.Anyways, took the plunge and built this one for casual gaming when I have time between the kids soccer practice and work etc..And I'm aware that I probably should have gone with Am5 platform but I really had to keep the budget for this one and wanted a white theme and if the time arises to swap Mobo/CPU/RAM combo i'll just do it I also wanted to make the system very energy efficient and the 5700x/4070 certainly fits the bill(pun intended )
1440p (144hz) Fps/Rpg games mostly and some Cs go also.Coming from 9600k/2060 6gb I'm like a small kids itching to try new AAA titles.
Parts: Lancool 216
MB: Asus B550-A Strix
CPU: Ryzen 5700x
Thermal paste: Fuzeice plus (13.5 mWk)
GPU: KFA 4070 Ex gamer White Argb
Ram: Corsair 32gb 3600 cl 18 RGB Rt
SSD: Firecuda 520 1gb nvme
(Will be adding a second 2gb m2 asap)
PSU: Corsair 750RMe
Cooling : Cooler master 240 Illusion
3* Cooler master Halo 120 fans
140mm Lian Li fan as GPU Exhaust.
Turned out nicely,haven't yet checked load temps for CPU/GPU but I'm really not worried with this case.
    290,4 KB · Luettu: 147
    299,1 KB · Luettu: 147
    310,7 KB · Luettu: 139
    278 KB · Luettu: 158
    203,1 KB · Luettu: 152
amppis
