Myydään Muse hifi M4 - bluetooth/usb Dac/Amp- dongle [Hämeenlinna]
Tuote: Muse hifi m4
Hinta: 80
Tuote ostettu (mistä ja milloin): aliexpress 11.2025
Kuitti löytyy (takuu voimassa): ehkä?
Uusi, ylimääräisenä, suoraan paketista. Ainoastaan toimivuus testattu.
Revikkaa; Muse Hifi M4 Review: Catch Them All
Voi käyttää myös suoraan usb johdolla, esim tietokoneessa.
• Bluetooth version: Bluetooth 5.1
• Volume adjustment: The volume of the phone can be adjusted separately
and independently
• Codec support: AAC/SBC/aptX/aptX LL/aptX Adaptive/aptX
HD/LDAC
• Bluetooth chip: QCC5125
• Independent chip: ES9038Q2M
• Independent amp: ES9603Q
• USB DAC: SA9137
• Independent play pause button: Yes
• Independent volume key: Yes
• Independent song before and after adjustment: Yes
• Transmission distance: 12M
•Gain setting: L/H
• Volume steps: 60
•Output power: 3.5>320mw ; 2.5/4.4 > 640mw (32Ω) SNR:3.5>118dB:25/4.4>115dB(A)
•Noise: 3.5 <3uV: 2.5/4.4 <5.5uV
•THD+N:3.5<0.00048%:25/4.4<0.00032(1KHz/6-dB@32Ω)
• Separation degree: 3.5>75dB,2.5/44 107 db or higher
Microphone: Support Bluetooth voice call, built-in omnidirectional microphone, support CTIA headset wire control itself microphone
NFC: Supported
No-drive mode: Supported
Mobile decoding: Supported
In-car mode: Supported
MQA Render: Supported
Plug type: 3.5mm+4.4mm+2.5mm
USB interface: Type-C USB 2.0 (charging) + Type-C USB 2.0 (data transfer)
Battery capacity: 1100mAh
Endurance: 3.5mm>8h; 2.5/4.4mm 7h
Weight:≈73g
Accessory: Type-C USB
Color: Silver
Paikkakunta (ilmoita myös otsikossa ja tagissa): Hämeenlinna
Toimitustapa: nouto/posti
Maksutapa: Käteinen/mobilepay
Temef11
