AM4 emolevyt
Mites tuo Asuksen X570 Prime Pro, onko siinä jotain selkeästi huonompaa kuin vaikka MSI:n Gaming Edge Wifissä? Wifi-ominaisuuksilla en tee mitään.
Buildzoidin mietteitä asus prime pro lähtee 15:25 kohdalla.
Best Motherboards for Ryzen 3000 CPUs: X570 vs. X470 & B450 : Amd
TL;DR:
If you don't overclock, every board is fine.
If you need PCI4 go for X570.
If you need SLI go for X470.
All others go for B450.
General: VRMs and cooling are most important, BIOS Flashback, WiFi, Intel LAN are nice to have.
X570 picks (not tested, based on paper specs and photos)
  1. 700$: Gigabyte Aorus Extreme (best cooling, only board without chipset fan).
  2. 350$: No clear winner, all boards with massive VRMs.
  3. 300$: Asrock Taichi (best features).
  4. 200$: Asus TUF Gaming (WiFi) TAI Gigabyte Aorus Elite (Flashback).
  5. sub 200$: Gigabyte Gaming X (Flashback).
  6. ITX: Aorus Pro WiFi (like all ITX boards lacks VRM cooling)
X470 picks
  1. If over 200$ go for X570 TUF
  2. Asrock Taichi Ultimate (10G Lan)
  3. MSI Gaming Pro Carbon (also for OCed 3900X)
  4. Asus Prime Pro (for 6/8 core OC max)
B450 picks
  1. Go for MSI. If you don't like MSI, you are fu**ed.
  2. MSI Gaming pro carbon (good VRM, intel lan, WiFi, Flashback).
  3. MSI Tomahawk (like Gaming pro, no Intel lan, no WiFi).
  4. MSI Mortar (like Tomahawk, MicroATX, seems discontinued).
  5. MSI Gaming plus (like Tomahawk, lower class VRM).
  6. MSI Gaming plus MicroATX (only 2 DIMM slots).
  7. ITX: MSI Gaming plus ITX (like all ITX boards lacks VRM cooling)
Everything else has bad VRM/Cooling or awkward feature sets or Buildzoid forgot about it.
Ite meinasin aluksi MSIn gaming edge wifi + kampanja, mutta alkoi huolestuttaa noi revikat...nii päädyin kumminkin Gigabyten Aorus Eliteen, muutama kymppi eroa ja paremmat osat (mm VRMt, enemmän USBei, Intelin LAN...).
Buildzoid ei suosittelle alle 200 x570 emoja kenellekkään.
Noi on sinne päin ohjeita.
Jep, siellä on mm gigabyten lankku 200$ pointissa, jota on melko paha suositella jos valmistaja julkaisee biosseja jotka rikkoo prossuja.
Mulle on tullut antipatioita Gigabyteä kohtaan koska Sound Blaster Zx ei toimi tässä nykyisessä lankussa oikein vaan se katoaa jos kone menee esim syvään unitilaan, on pois päältä pitkään tms, ainut tapa tuon jälkeen saada se toimimaan on hirveä rumba mihin liittyy voodoomagiaa, kuun asentoja, kortin irroittelua ja toiseen slottiin pistämistä ja ajurien poisto asennus poisto asennus -rumbia.
Siksi ei Gigabyteä, Asuksen Prime Prota mietin koska sen väriteema mielyttää silmiä, B450 Mortar Titanium on toinen mitä miettinyt mutta MSI:n 128Mbit BIOS -setit noilla emoilla epäilyttää eikä ole ollut (vielä ainakaan) puhetta 256Mbit mallista.
Mistä tiiät et se toimis Asuksessa?
Kysyisin melkein Gigabytelt suoraa, jos meinaa x570 hommata...ne on kumminki loppupeleis iha eri lankut ku edelliset.
Sekin on tokin vaihtoehto, mutta onko tuossa X570 Aorus Elitessä sitten jotain erityisesti muita parempaa? BIOS Flashback on toki kiva ominaisuus, muttei mikään välttämättömyys (tähän päivään mennessä en ole vielä ikinä joutunut turvautumaan vastaavaan ominaisuuteen)
Tämä on kieltämättä yksi täysin turhista "spekseistä" millä x570 lautoja koitetaan erotella toisistaan.
Mulla odottaa asennusta X570 MSI Gaming Edge. Itse otin MSI:n kun ymmärsin, että sitä chipset fania saa itse säätää ja se varmasti sammuu myös jos ei ole kuormitusta emolla. Yllättävän järeät olivat Vrm- heatsinkit kun emoa käpistelin juuri.
Ensi viikolla raporttia kun saan asennettua.
Kuinkahan hyvin toimisi, jos chipset sirkkeliltä vetäisee piuhan irti(voiko?) ja laittaa siihen jonkun oikean tuulettimen hönkimään?
Videossa saksalainen hermanni mittaa X570 piirin tehokulutuksen ja ajelee omalla passiivisella jäähyllä (aikaleima 15m48s näyttää passiivisen jäähyn). Pitäis siis toimia noinkin jos vaihtaa isomman elementin ja koteloon saa edes yhtään ilmavirtaa kyseiselle alueelle.
https://www.youtube.com/watch?v=qk3PD-4zPN0&t=15m48s
Miten voikaan olla näin vaikeaa emon valinta...
Muut osat on jo aikalailla valittu, mutta kun ei pysty päättämään sitä yhtä osaa. Sinällään ei ole tarkkaa budjettia tai suuremmin väliä onko x470 vai x570, mutta mihinkään 500e hintoihin en ole lähtemässä. Omassa päässä soi, että x570 olisi parempi valinta pidemmällä aikavälillä, niin siksi katsellut niitä enemmän.
Esim. MSI:n x570 gaming pro carbonia oon katsellut, mutta vähän epäilyttää nuo paikat mihin tuulettimet saa kiinni, kun ei ole takatuulettimelle paikkaa siinä sen lähellä.
Gigabyten aorus pro, ja siitä ylöspäin, taas olisi mukavasti noita tuuletinpaikkoja mistä valita. Omaan silmään myös kohtalaisen hyvän näköisiä, mutta onko sitten itse levyn ominaisuudet hyviä muihin verrattuna.
Asukselta taas olisi prime pro ihan mielenkiintoinen, joskin en oikein innostu tuosta valkoisesta väristä. Lisäksi ollut viime aikoina hieman ongelmia muiden asus tuotteiden kanssa niin tiedä sitten uskaltaako yhden asuksen hankkia lisää. :eek:
Chromessa melkein 40 tabia auki, kun koittaa vertailla eri levyjä ja lukea arvosteluja ristiin :nb:
Mulla ois hakusessa hyvä x370/x470/b450 emolevy 2700x kaveriksi jos jää ylimääräisiä x570 piirisarjaan päivittäviltä.
Itse laitoin Asuksen X570 TUF gaming (wifin) amazonista tulemaan samanlaisen arpomisen jälkeen. 240€ suomi alveilla, oli tarkoitus jimmsiltä ottaa wifitön versio, mutta toimitusaikataulu muuttui muotoon ei tiedossa. Tuossa ilmeisesti sama VRM kun kalliimmissa strix f ja e malleissa (buildzoidin mukaan).
Edit. yksi varastossa (https://www.amazon.de/gp/product/B07TPPJ5JZ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1)
Itte oon kans pähkäilly emon kanssa, ja tullu siihen tulokseen että jään odotteleen msi tomahawk maxia josse tulis kuukauden sisään myyntiin, siinä olis kaikki mitä ite tarviin, eikä ylimäärästä tavaraa.
Täällä venailee kiveä kyseinen lankku ja tänään tuli MSI:ltä meiliä et aio hakemus hyväksytty ja se toimitetaan joskus. :D
Tuohon en ollutkaan vielä törmännyt että sitä saa itse säätää. Mukava uutinen. Lueskelin vain että on semi hiljainen ainakin.
Tai sitten vain säätää BIOS:sta tuuletin käyrät mieleisekseen jos vakioprofiili ei miellytä.
Vakionakin yllättävän hiljainen ainakin GigaByten ITX levyn tuuletin.
Kato se tunnin Buildzoidin video, joka on pyöriny täs...sen ja monen muun mukaan $200 hintaluokkaa paras lankku, koska overkill VRMt hintaa nähde, Intelin LANi, se "turha" flashback, myös säädettävä sirkkeli (viimeisin bios kertoo sen), BIOSin UIki näyttää pätevältä, ei niinkun MSIn kuvakikkailu, enemmän I/Ota ym ym...Eikä sitä tiiä, voi olla et lähitulevaisuudes joutuu turvautuu flashbäkil niiku näis edellisis lankuis.
Itteä ei kiinosta näkö, rgb tai muu siihen liittyvä pelleily, vaan puhdas hinta/laatusuhde ja yksinkertaisuus. Koppanaki Define R4 ilman ikkunaa, niin ei paljon sisälle katota.
Ehkä, ehkä ei joudu. Itseä kiinnostaa ulkonäkö tiettyyn pisteeseen (siksi mm. Prime Prota miettinyt B450 Mortar Titaniumin ohella), pitää kysellä vieläkö Sound Blaster Z(x) -ongelmat vaivaavat Gigabyteä
Nii yks huono puoli unohtu sanoo, että debug ledit tai/ja counteri puuttuu noist ainaki <=$200 asus ja gigabyten lankuist, msi lankuis taas on ja asrockist en taas tiiä.
Tässä Buildzoidin emolevyvertailua siitä luokasta alaspäin mennen:
Vanhan mallinen erillisillä komponenteilla oleva VRM jää hyötysuhteessa jälkeen powerstageille, niin jäähdytystä on parempi ollakin hieman enemmän.
Taidanpa pistää tuon aorus pron tilaukseen niin pääsee viimein eteenpäin uuden kokoonpanon hankinnassa.
Jos ostaa vähän paremman luokan emon, niin erillistä äänikorttia ei enää tarvitse, koska niiden integroidut ovat jo niin lähellä samaa tasoa. Tosin noiden hinnat alkaen emojen äänet ovat tasoa "kunhan jotain kuuluu".
Olikos siinä B450 Gaming Pro Carbonissa valmiiksi jo tuo 32MB, kun ei näemmä MAXia tule?
Ainakin x470-f Strix emossa kuuluu superlux hd-660 luureilla ääni hiljaisella jos ei ole ääni korttia:tdown:
Tuli tilattua reilun vuoden inttelin leirissä olon jälkeen tuo 3600 rusina, nyt sitten pitäis joku hyvä 570 lauta kattoa sille :)
Asuksen X570 TUF gaming ois varmaa aika sopiva kun hyvä vrm eikä kovin kalliskaan ainakaa amazonista, mut ulkonäkö on vähän niin ja näin :D
Jos ny malttais katsella ja odottaa vaik alkuviikkoon :btooth:
Voi olla, että kuulokevahvistin on yhdistetty vain kotelon etupaneelin liittimiin eli takapaneelista saa vahvistamattoman signaalin.
Viisastuin vasta tilaamisen (katsoin Buildzoid:n videoita) jälkeen tuosta Gigabyten X570 Gaming X ja aion palauttaa sen takaisin kauppaan heti kun sen saa. Tilalle laitetaan X570 TUF Gaming ilman wifiä.
Ei kestä perse sitä ajatusta, että jos tekee mieli laittaa joskus 16c/32t kiinni, niin ollaan aika rajoilla tuolla gigabyten lankulla
Minullekin tuli tuo viesti. Varsin mainio diili kyllä MSI:llä tarjolla. X570 ACE:lle tulee loppujen lopuksi hintaa "vain" vähän yli 300 euroa, jos myyn jäähyn pois.
Niiku testit ovat osoittaneet, niin AIO:lla tai edes erillisellä coolerilla ei tee periaattees mitään, ku vakiolla kestää hyvin PBOn tai kellotuksen.
Muuten oisin varmaan tilannut Aorus eliten, mutta siinä ei ole t-sensor liitäntää :(
Sama puuttuu asuksen X570 TUF gaming emosta :confused2:
Tarjousmuistit kun nyt tuli ostettua niin konepaketista ei puutu enää kuin kotelo, prosessori ja emolevy. M.2 SSD lähti myös yllättäen Amazonilta tulemaan reilusti etuajassa.
- Kotelovalinnassa päänvaivaa aiheuttava asia on etupaneelin type-C liitäntä, se täytyisi silloin löytyä myös emolevyltä. Taitaa vain olla niin että jos type-C löytyy emolevyn takapaneelista niin silloin etupaneelin tuki on pudotettu pois lankulta, ellei mennä aivan holtittomasti maksaviin lankkuihin.
- Prosessoriksi menee näillä näkyvin Ryzen 3600, sitten jos on tarvetta päivitykseen niin Zen2+ isommalla ydinmäärällä tilalle. Tämän takia katse alkaa lopullisesti valumaan kunnon VRM:n omaavien X570 lankkujen puolelle, kun niissä pitäisi Zen2+ tuki olla parempi kuin mitä MSI:n pelleily tällä hetkellä on Zen2 osalta vanhoissa lankuissa.
Lankuista X570 Asus TUF Gaming Wifi ja Gigabyte Aorus Elite ovat kiikarissa.
Gigabyteä ei tunnu mistään saavan järkihintaan joten vaakakuppi kallistuu Asuksen puolelle.
- Gigabytessä olisi etupaneelin type-C liitäntä, tosin se puuttuu kokonaan takapaneelista.
- Asus omaa takapaneelin type-C liitännän mutta siitä vastaavasti puuttuu etupaneeli-tuki...
- Lisäksi vielä se että wifi täytyy saada lankkuun jollain tavalla, joko omalla vanhalla pcie-kortilla toteutettuna tai sitten valmiiksi lankkuun integroituna...
- Aikaisemmin olin myös miettinyt integroidun äänikortin käyttöönottoa mutta sitten löysin tämän pienen ihmeen: Silverstone ECP01. Tuolla saa hyllyssä lojuvan DAC+amp vehkeen toimimaan koneella ilman ylimääräisiä virtalähteitä/virtajohtoja joita on muutenkin pöydän alle teipattuna niin perkeleesti (kaiutinvahvistimen virtalähde, näytön virtajohto, TV-antennin vahvistin, PC virtajohto, jne.). Eli nyt ei tarvitse miettiä integroidun äänenlaatua kun etsin mieleistä lankkua.
Kai se on TUF ostettava kun sitä saa järkihintaan Amazoniasta inhimillisillä toimitusajoilla (230€+veroero, toimitus 28. päivä). Type-C etupaneeli-tuen puute korvautuu takapaneelin liitännöillä ja samalla voi ottaa hyvillä mielin kympin halvemman mallin kotelosta missä ei ole type-C liitäntää.
Tosin kyllähän tuo kirpaisee kun satkun halvempi MSI B450 Carbon AC käytännössä ruksaisi kaikki muut vaatimukset toimintavarmaa BIOSia lukuunottamatta (nyt ja tulevaisuudessa Zen2+).
Gigabyte X570 Aorus Elite AMD X570 So.AM4 Dual Channel DDR4 ATX Retail
Gigabyten X570 Aorus Eliteä saa ihan järkevään hintaan Mindfactorysta, tosin MailBoxDE-palvelua tms. joutuu käyttämään välissä kun eivät lähetä suoraan Suomeen. Arviolta jotain ~10-20e olisi varmaan lisähinta tuolle, riippuen millaisessa paketissa lähetetään, aika samaan hintaan menee tuon Amazonin Asus TUFin kanssa.
(Viidenkympin hintaero suomihintoihin ja nopeampi saatavuus kyllä laittaa harkitsemaan isomman erän kimppatilausta jo hiljalleen..)
Tosin kyllähän tuo kirpaisee kun satkun halvempi MSI B450 Carbon AC käytännössä ruksaisi kaikki muut vaatimukset toimintavarmaa BIOSia lukuunottamatta.
Onko Asrock x470 taichi ihan no no? Olis wifi, eteen ja taakse usb-c, hinta tosin taitaa pyöriä tuon tuffin kanssa samoissa.
No kyllähän tuokin käy, mutta millä mallilla BIOS on tällä hetkellä?
Kun muut osat alkavat tipahtelemaan postiluukusta etuajassa niin ei jaksaisi (toimivaa) emolevyä jäädä odottelemaan kuukausitolkulla.
EDIT: niin, unohtui tuo BIOS-flashback. Ei jaksaisi veljen custom-vesijäähdytteisestä ITX-romusta alkaa repimään 1700x kiveä BIOS-päivityksiä varten. Eli Taichi on tässä tapauksessa no go (ellen ole masokisti ja vapaaehtoisesti ala käyttämään tuntitolkulla aikaa toisen kokoonpanon purkamiseen ja kasaamiseen).
Tuota aikaisemmin sain semmosen käsityksen, että näis kaikissa X570 emoissa olisi aiempia paljon laadukkaammat VRM:t mutta viime sivuilla puheista jää vähän semmonen käsitys, että niissäkin on eroja ja siksi porukat raakkaa pois esim. halvemman pään MSI:n emot, koska ei riitäkään tai jotain? Onko noin tosijaan?
Asrock B450pro4 ja 3600 ainakin lähti käyntiin ihan mukavasti (Jimms hoiti Bios-päivityksen), muistit eivät defaulttina tunnistautuneet kunnolla (2133MHz 3200:n sijasta), mutta näyttäisi että XMP:n laittamalla päälle nekin menivät oikeille taajuuksille. Eli ihan lupaavalta vaikuttanut, mutta toki pitää vielä hieman säätää että pääsee pelikäytössä kokeilemaan.
TUO MSI:n beta-BIOS vanhoille laudoille ei muuten sitten tosiaankaan ole kunnolla toimiva (buustit ei toimi kunnolla tai ollenkaan). Virallista BIOSia lupailtiin jo viimeviikolle, mutta eipä ole näkynyt. Saas nähdä miten pitkään jaksaa odotella, ennen kuin tulee mentyä emolevyostoksille...:mad:
Joo toi flashback on kyllä vertaansa vailla olevaominaisuus, pojalla on 1600x ni ei haittaa. Proshopin toimitusvaikeudet x470 taichiin ajoi kokeilemaan 3700x 350 pro 4:seen.
MSI:n halvemmissa on käytännössä sama VRM kuin monissa nykyisissä MSI:n AM4 lankuissa.
The AMD X570 Motherboard Overview: Over 35+ Motherboards Analyzed
Eli pelkästään OK tasoinen.
Emolevyjen virransyötön rakenteeseen tutustuminen tuotti runsaasti yllätyksiä, tai paremminkin järkytyksiä enemmän tai vähemmän jokaisen testatun emolevyn kohdalla. Vertauskuvallisesti näkymä oli kuin neuvostoliittolaisesta supermarketista, jonka hyllyt valittavat tyhjyyttään ja muutaman tarjolla olevan tuotteen kelpoisuus ihmisravinnoksi on pienoinen kysymysmerkki.
Jokaisen testatun emolevyn virransyöttöä yhdistää yksi seikka: niiden ainoa suunnitteluprioriteetti on ollut komponenttikustannusten minimointi. Jokainen testatuista emolevyistä käyttää erillisen ylä- ja alapuolisen mosfetin käsittävää, nykystandardein vanhanaikaista ja heikomman hyötysuhteen tarjoavaa perinteistä virransyötön rakennetta.
Testissä AMD B450 -emolevyt (ASRock, Asus, Gigabyte & MSI) - io-tech.fi
Tällä kertaa taas aiemmissa AM4-emoissa kusettaneella Asuksella on sitten malliston alapäässäkin hyvä VRM moderneilla integroiduilla powerstageilla.
matopurkki
