Doom (2016)
  • Keskustelun aloittaja Keskustelun aloittaja elmo
Itsellä vielä kaikki pelaamatta. Tai no, sekä Doom että New Order kyllä aloitettu mutta loppuun asti ei ole pelattu. Jälkimmäisessä kyllä vähän ärsyttää 60 Hz lock joten ei hirveesti nappaisi pelata sitä..
Doomiin tullut uusi päivitys. Kaikki DLC:t ilmaisena nykyään ja free weekend alkaa myös.
DOOM Update 6.66 FAQ and Patch Notes
DOOM Update 6.66 - FAQ
What is DOOM Update 6.66?
Update 6.66 brings substantial changes to the game’s multiplayer, with a revised progression system, new rune system for loadouts, enhanced kill notifications and bug fixes. In addition to these improvements, we’re upgrading all existing players’ content to include all multiplayer DLC.
Is all the DLC free with Update 6.66?
Yes, the multiplayer DLC is now bundled into the core DOOM game for free, producing the definitive DOOM experience. All of the DLC maps, weapons, armor sets and demons will be available for all players to enjoy.
What is the revised progression system?
The revised progression system will alter when and how players unlock additional guns, demons, equipment, and all of the player and weapon customization options. Instead of relying on the random distribution of unlocks, items now unlock through specific leveling requirements or through in-game challenges that the player can complete. For example, if there’s a specific helmet you want right now, you can work towards unlocking it by focusing your play style on the requirement.
What is the new rune system?
The all-new Runes replace the Hack Module system. Like Hack Modules, Runes enhance player abilities, but can be persistently equipped, which was not possible with the previous system.
What are enhanced kill notifications?
The death screen is getting an overhaul as well, now calling out how you were killed, not just who killed you. The new death screen will list out the combination of players, weapon types and damage inflicted.
Does the update reset your multiplayer progression?
Yes, Update 6.66 resets all players’ multiplayer level back to 0.
Veteran players will have the option to reset their unlock progression and experience the new progression system fresh, or retain all of their existing guns, equipment, demons and customization options that they’ve acquired or purchased while unlocking some of the new items in the revised progression system.
Do veteran players receive anything after the update?
If you’ve played multiplayer since DOOM’s release, you’ll receive a special badge indicating your veteran status.
When is the release date for Update 6.66?
Free Update 6.66 will release globally on July 19, 2017, prior to our DOOM Free Trials Weekend (details below).
Is Update 6.66 available on all platforms?
Yes, this update is free for all users on PlayStation 4, Xbox One, and PC.
What is the DOOM Free Trial Weekend?
The free weekend is a great time to get hands on with one of the biggest games of 2016. You can play the first two Campaign levels and all of DOOM Multiplayer and SnapMap. The full game can be unlocked.
Will I retain all my multiplayer progression from the Free Trial weekend?
Yes, if you play multiplayer during the Free Trial weekend and then purchase DOOM, you’ll keep all your progress and unlocks.
When is the DOOM Free Trial weekend?
Xbox Free Weekend:
Start: 11am CT on Thursday 07/20
End: 11pm CT on Sunday 07/23.
Steam Free Weekend
Start: 12PM CT on Thursday 7/20
End: 3PM CT on Sunday 07/23
PS4 Free Weekend:
Start: 11am CT on Thursday 07/27
End: 11pm CT on Sunday 07/30.
Update 6.66 Patch Notes:
Multiplayer:
  • Fixed an issue where textures appeared to glow on the player’s character.
  • Fixed an issue in Multiplayer where players would respawn frozen at the beginning of a Freeze Tag round.
  • Fixed an issue in Multiplayer where parts of the player model appeared transparent in some circumstances.
  • Fixed an issue where players would disconnect from a match under certain conditions.
  • Fixed an issue in Infernal Run where picking up the ball when out of ammo would cause problems with passing or receiving the ball.
  • Fixed an issue with the Multiplayer Challenge “Aimbot Hax” where Reaper Longshots would not count towards challenge completion.
  • Fixed an issue in Multiplayer with inconsistent power item spawns on Outbreak.
SnapMap:
  • Added rotate on XYZ axis to the Grab Object manipulate controls
  • Added setting to remove network limitation on single player only maps.
  • Resolved various freeze and crash bugs.
  • Fixed various matchmaking and lobby issues.
  • Fixed visual bugs that result from combining specific HUD elements
  • Fixed various freezes and crashes with using Campaign Model.
  • Fixed coop crash with Bob and Rotate settings.
  • Fixed bug that caused AI to run into blocking volumes set to Block Demons and AI Sight.
  • Improved collision issues causing AI to partially fall into blocking volumes set to Block Demons.
Jahas, Steam rupesi lataamaan tuota päivitystä. On joko suurin päivitys KOSKAAN tai sitten lataa koko Doomin uusiksi. Ladattavaa vaivaiset 34,7 Gigaa :eek:
Xbox Free Weekend:
Steam Free Weekend
PS4 Free Weekend:
Multiplayer:
SnapMap:
No nyt! Onneksi en sortunut "myöhässä" ostamaan noita delsuja. Olivat aika kovan hintaisia.
Loppui sitten iloisesti tila levyltä, update odottaa ja peliä ei pääse pelaamaan. Kevyt 91 Gt kokoinen DOOMin kansio :darra:.
Voisko joku copy pastea tuon sivun sisällön? Mulla ei jostain syystä aukea millään tuo sivu.
Johtuu siitä että Bethesda antoi kirveestä foorumeilleen. Jos sinulla on tuo ongelma niin sen kun vaan käyt varmistamassa että hertsit ovat kohdallaan windowsissa.
Tuollahan oli joku commandline homma.. mul ainakin G-sync ja V-sync päällä rajottaa 60 fps vaikka windowsissta on herzit 100.
Googlen cachesta löytyi vielä.
FIX - GSync and unlocked Framerate, skipping Intro Movies
Dynacorp
May 15, 2016 5:14 AM
Hi everyone,
if your having problem running doom on a 144Hz Gsync Display try out these start commands.
Most are disabling that lovely G-Sync Feature to get an uncapped framerate, well you don't have to disable it to get over 60fps.
FIX #1
in steam - right click your game and click on "start options", then add this and save.
+com_skipIntroVideo 1 +vt_MaxPPF 128 +vt_pageImageSizeVmtr "16384" +vt_pageImageSizeVmtrUnique 16384 +r_displayRefresh 144
credit goes to Neogaf Forums http://www.neogaf.com/forum/showthread.php?t=1208052
FIX #2
oddly enough my game wont startup anymore with those parameters listed above, if you have the same issue with FIX #1 try the following
Go to Control Panel and click on Adjust screen resolution under Appearance and Personalization.
then rightclick on your display go into settings and set its refresh rate to 144hz.
-alternative for win10-
follow this tutorial How to change your screen resolution and refresh rate in windows 10 - YouTube
it looks like Doom doesn't ask the Driver and G-Sync about your Hz but windows to set the Refresherate ingame.
Give it a try
Kokeile laskea windowsissa virkistystaajuus 60hz ja nosta sitten takaisin sinne minne haluat sen. Jos ei auta niin sitten en tiedä.
Aikalailla sama juttu. :grumpy: Eikä itselläni noita Doom tiedostoja voi edes siirtää nyt SSD:ltä HDD:lle, koska "update required". :facepalm: Hienoja nämä nyky pelit kun hyvä jos niitä saa joku 2 mahtumaan Windowsin kanssa yli 200 gigan SSD:lle.
Yksi aika oleennainen juttu liittyen tuohon free weekendiin mikä ainakin itseltäni meni ohi: You can play the first two Campaign levels
Kiva huomata nyt kun eilen illalla siivoilin tilaa kovolle & laitoin yöksi latautumaan :D Ajattelin että olisi voinut viikonloppuna pelailla läpi... Noh ehkä tästä voi sen 15€ maksaakin.
Tulipahan onneksi latautuneeksi. Nyt päälle 34gb jälkeen linjakin toimii, että sillä jopa tekee jotain. Mikä vahinko, etten ole koskaan ollut multi-player-pelaaja. Päivitykset menivät siihen osoitteeseen, etteivät kosketa ainakaan minua.
Kyllä tässä yksinpelikampanja on sitä luokkaa, että maksaisin koska vaan uudestaan täyden hinnan. Mestariteos.
Korkeimmalla vaikeusasteella on vielä läpäisemättä, mutta sekin edistyy pikkuhiljaa eteenpäin :cigar2:
Osaako joku sanoa mistä asetuksesta voisi johtua tuollaiset "katkoviivat" tekstuurien saumakohdissa? Ei mikään iso ongelma, kun ei noita näkynyt muualla kuin parissa kohtaa pelin alkupuolella (ja ainoastaan ulkona)
Aloitin tämän pelaamisen pari päivää sitten asenteella, taas perus räiskintäpeli, hoidetaan nyt pois alta mutta jumalauta, tämä on täyttä rautaa niin äksönin kuin kenttäsuunnitelun osalta.
Pieni kysymys juonesta spoilerin takana
Liittyykö tämä nyt juonellisesti aiemiin Doomeihin? Kun tässä Doom-tyyppi on löydetty helvetistä ns. vangittuna ja raahattu takaisin Marsiin. Aiemmat Doomit olen kyllä pelannut mutta en millään muista loppuiko joku niistä noin.
Itse olen ollut siinä uskossa että Tämä on rebootti tarinalle eli sama aika kuin alkuperäiset doomit. Tai sitten joku Ultra-hyper-remastered-what-if-doom-was-made-in-2016 -edition.
No häh!
Ei sen enempää keskustelua pelistä?
Ostin eilen steamista 5.99e hintaan vaikka pelasin ps4pro:lla doomin aikaisemmin läpi.
Voi smoothgamingexperienceorgasm mikä kokemus kaikki ultralla 1440p:llä 140fps:llä!
Se on vaan fffffhssttpphhh fffffssstppph kun PC Master Racella jyrää menemään, ai jumaliste kun on nannaa.
Miten ihmeessä hakkasin tateilla tämän läpi. En kyllä varmasti edes nauttinut.... Anteeksi Herra Doomguy.
Nyt jos joku ei ole vielä peliä tietokoneelle ostanut niin nopeaan steamista 5.99e hintaa hakemaan.
Se on ilmaista tästä herkusta!
Himppasen vajaa 70h näyttää steamin pelikello, joten onhan sitä tahkottu! :D Loisto peli edelleen.
Ihtel 25h joista varmaan 5-6 moninpeliä. Yksinpeliachievementeista jäi
Earn a gold rating in Arcade Mode, muuten moninpeli- ja snapmap achievementit keräämättä pääosin. Ihan hyvä peli, mut ei tää itellä nyt mitää orgasmeja herätellyt. Wolfenstein The New Order oli omalle kohalle se iskevämpi kokemus. Ehkä olis ollut toisinpäin jos olis pelannut toisinpäin.
Kelpo pelihän tuo on, yksi lemppareistani. Oma steam kello sanoo että olisi 330+ tuntia kasassa, vaikka ei pelissä ole kuin 13 kenttää, mutta huimasti siinä on (ainakin itselleni ollut) udelleenpeluuarvoa ja mukavaa haastetta, aivot narikkaan mättöä, puhumattakaan snapmapista ja classic kentistä.
Ei kai kilppari ole varastanut accoasi :lol:
Hieno pelihän se doomi oli kun itse pelasin alkuvuodesta vaikka en ole itse tottunut nopeatempoisiin FPS peleihin mutta kiva oli pelata sopivalla vaikeusasteella ohjaimen kanssa PC:llä käsin.
Kyllä, loistava peli edelleen vaikka varmaan 6 kertaa pelattu läpi :tup: moninpeliin en ole koskenut kuin kerran ja se ei maistunut.
Tuli tämä ostettua juuri jostain tarjouksesta ~4€ (kortti laskutus lisineen) josko tämän pelais kun ihan jees pojoja/arvioita saanut, rupes tekee mieli jotain aivotonta räiskintää. Eikö tässäkin ollut vulkan? Tämän jälkeen sitten voikin ostaa Mafia ykkösen remaken ja sitten sen jälkeen sen Doom Eternalin...
Edit: Käsittääkseni viel ihan hyvä engine tässäkin et pyörii hyvin ja ikäisekseen ihan hyvännäkönenkin.
Parempi tää on joka osa alueelta kuin Eternal, Eternal ei tunnu doomilta tämä tuntuu.
Myönnettäköön et viimenen FPS peli mistä olin fiiliksis ni oli duke nukem neverever (kusi, jo "mekaanisesti") floppihan se oli, sitten myös oli doom 3 (en vaan jaksanut ku se oli mielestäni enemmän kauhupeli ku fps) nykysin ei kiinnosta tarina fps peleis ku ARPG/RPG on se mun juttu.
Mutta hieman mietteitä ku nyt tuli pelattua loppuun, pari ärsyttävää bugia oli, yksi oli kun välillä juostessa esim. portaita ni yhtäkkiä se ukko saatto vaan jumahtaa, kai se kompastu johki risuun tai jotain ja vikassa kentässä ihmettelin et miten ne vikat ovet aukee, no tutkin varmaan 10 minuuttia ja sit oli pakko mennä kattoo tubesta, no lopputulos oli et ku kaikki on tapettu ni pääsee eteenpäin, sitten etin lisää ja löysin yhestä sellasesta kivi paasista roikkumasta yhen mobin se bugas siin ei tehnyt mitään=ammuin sen ni sit portit aukes. Viimeinen bossi oli aika blaah, muita bosseja sain yrittää useammankin kerran mut vika meni ekalla. Noita edellä mainittuja asioita lukuun ottamatta olihan se aivan timanttia räiskintää ja hienoja lopetus liikkeitä, tätä lisää kiitos=kai se on ostettava jossain välissä se Eternalkin. Sanotaan nyt vielä loppuun et pelimoottori oli aivan loistava, sen mitä välil kerkes FPS mittaria kattoo ni ei tainnu kertaakaan tippua alle 146, yleensä oli siellä tapissa sen 200 tai lähelle, asetuksina oli ultrat 1440p, (kone on ryzen 3600 ja RTX 2070) taisin ottaa kyl motion blurrin pois käytöstä ku yleensä en peleis pidä siitä/sen toteutuksesta.
Kumipensseli
