Jolla/Sailfish
Jolla foorumilla oli muutoslogit ja bugit listattuna. Bluetooth ilmeisesti toimii osittain mutta jotain häikkää siinä vielä on.
NEWS
  • 2017-10-11 2.1.3.5 RC3 : Roll out to all Xperia users. No over-the-air update available. Must be flashed to devices.
  • 2017-10-06 2.1.3.3 RC2 : NOTE: Partitions changed. Must be modified on device before updating to RC2.
  • 2017-10-04 2.1.3.1 RC1 : Initial release to cbeta
FOREWORD
Sailfish X version 2.1.3.5 is the first official OS release for Sony Xperia X devices.
GETTING SAILFISH X AND INSTALLING IT TO XPERIA
Follow the instructions here, please: How to install Sailfish X on your Sony Xperia™ X - Jolla
GETTING THE LICENSED CONTENT FROM STORE
Visit Jolla online shop: https://shop.jolla.com
HIGHLIGHTS OF 2.1.3.5 (Xperia X)
  • Camera: video recording and still camera fixed in Android apps
  • Camera: HW shutter button added
  • Camera: focus modes added; focus of front camera fixed
  • Connectivity: switching from mobile data to WLAN improved
  • Dropbox account: sign in fixed
  • Longer buffers for music playback in use
  • New default ambience added
  • Youtube video playback fixed in landscape fullscreen mode
  • Blueborn CVE fixed
  • Other CVE fixes
  • Fix for phone call mute
  • PIN/PUK dialogs fixed
  • installing local rpm's works now
  • creating ambiences works better
  • gallery with lots of content more robust
  • more CPU cores in use.
  • working sensors: accelerometer, gyro, light, proximity.
KNOWN ISSUES AND FEATURES NOT YET SUPPORTED ON 2.1.3.5
  • Bluetooth: implementation not complete (beta)
  • Waking up the device by double-tap does not work
  • New pictures may appear at the end of the Gallery
  • WPA2 Enterprise connection fails after first entering an incorrect password
  • Sensors:
    • not working: fingerprint, barometer, step counter
    • compass (or gyro?) working in Google Maps, not yet natively
  • Internet sharing (tethering) does not work
  • Issues with video playback and video recording
  • FM radio missing
  • Even though all CPU cores get eventually enabled, foreground apps do not always run on the big cores
Itse sain juuri asennettua Sailfish X:n luuriin ja asennusprojekti sujui varsin kivuttomasti. Vielä en ole kummemmin ehtinyt laitetta testailla mutta laittelen tässä myöhemmin kokemuksia.
Osittain joo toimii. Pebblen löytää, mutta ei pariudu kunnolla.
Edit.
Uudelleen parittamalla sain Pebblenkin toimimaan. Xperia osaa käyttää BLE:tä, joten se varmasti sekoitti alkukokeiluissa.
Autostereoihin ja langattomiin kuulokkeisiin syöttää myös hyvin ääntä, eli hyvin toimii jo ainakin omassa käytössä.
Onko tämä nyt jotenkin estetty etten pystyisi laittamaan tuota imagea useampaan puhelimeen?
Imagen voinee laittaa mutta jos pitäis veikata niin android/exchange jne. ominaisuudet vaatinevat kirjautumista jolla tilille/kauppaan?
Olisiko se tehty henkilökohtaiseksi eli en pystyisi myymään tuota puhelinta kaikilla ominaisuuksilla...
Aika harvaa softalisenssiä saa virallisesti jälleenmyydä vaikka se teknisesti olisikin mahdollista.
Luin Jolla blogista, että se on sidottu tuohon jolla tiliin. Jos myyn puhelimen niin minun täytyy olla yhteydessä Jollaan joka vapauttaa lisenssin uudelle omistajalle.
Sailfish X:n ostotapahtuman yhteydessä täytyy ensin kirjautua Jolla tilille. Tällä tavoin Jolla tili sidotaan maksun suorittamiseen. Varsinainen Sailfish X image ei käsittääkseni pidä sisällään mitään lisensointijuttuja. Android-tuki, Microsoft Exchange ja ennustava tekstinsyöttö ladataan sitten jälkeenpäin kyseisellä Jolla tunnuksella puhelimeen Jolla Kaupasta. Jos maksullisia ominaisuuksia haluaa käyttää useammassa laitteessa, niin jokaiselle laitteelle pitäisi ostaa uudet lisenssit. Samaa tunnusta ei siis pystyne käyttämään useamassa laitteessa (?).
James Noori on October 12, 2017 at 4:34 pm
Hello Louis!
Thank you for your comment.
The license is tied to your account, but is definitely transferable if you write to us on Zendesk before you sell your device so we can help you out. And yes, if you get a new phone, it is definitely possible to transfer Sailfish X to it as it is tied to your Jolla account.
Cheers,
James
James Noori on October 11, 2017 at 6:50 pm
Congratulations!
If you need the paid features, you need as many licenses to as you have devices.
Mielenkiinnolla tulee seurattua, miten tuo Sailfish X lähtee toimimaan ja kehittymään. Heti en uskalla lähteä mukaan. Juuri kuukausi sitten päästin omani ja vaimon Jollat eläkkeelle ja tilalle hankittiin Moton G5:et. Kyllähän sailfishin eleitä ja loogisuutta on ikävä, mutta mennään nyt ainakin hetki androidilla.
Toki multa löytyy Jollan tabletti ettei aivan pääse unohtumaan :)
Tuli, sitten itsekin tämä hommattua, kun tuo Jollac:n näyttö hajosi, muuten meni ihan mallikkaasti, mutta eihän tuo mun sim-kortti tuohon sovi eli joku päivä ettimään Elisalta pykälää pienempi sim-kortti.
Ei viitti leikellä edellisen yritin leikellä microsimmiksi hajos nyt tarviin puhelinta, niin en haluu ottaa riskiä, eikä tuolla vielä oo niin kiire joku sais keksiä, miten tuohon saa playstoren asennettua.
Jos ei jaksa kikkailla Play Kaupan kanssa, niin voi asentaa Yalp Storen F-droidista. Yalp Storesta voi ladata Play Storesta löytyvät sovellukset apk-tiedostoina Googlen palvelimilta.
EDIT: Jos joku kaipaa WiFi-jakoa Sailfish X:ssä (tai Nexus 5:ssä), niin siihen on tehty toimiva skripti:
maemo.org - Talk - View Single Post - Sailfish OS (officially) on Sony Xperia devices
Näillä ohjeilla sain itse asennettua. Päivität vaan Play Storen versioon 7.3.25.K, ennen kuin estät kaupan päivitykset. Play Servicen voit päivittää helposti Jollan Android kaupasta.
Milläs tuon kaupan saa pysäytettyä tuohon tiettyyn versioon mulla ainakin, jos kauppa sammuu seuraavaksi käynnistyy 8.3 jotain?
edit poistin playstoren ja asensin tuolta Google Play Store 7.3.25.K-all [0] [PR] 142209747 (240-480dpi) (Android 4.0+) APK Download by Google LLC - APKMirror oikean version ja sitten pysäytin nuo päivitykset
Eli sait toimimaan?
Maemosta sain tällaiset ohjeet stoppaukseen:
You would need to stop store updating by one or other of these:
https://talk.maemo.org/showpost.php?...0&postcount=27
https://talk.maemo.org/showpost.php?...3&postcount=51
joo, kyllä tai olettaisin en viitti sulkea ennen kuin saan tarvittavat asennettua.
Jolla on aloittanut tablet kampanjan korvausten toisen palautuskierroksen. 83 satunnaisesti valikoitua henkilöä on saanut rahansa nyt kokonaisuudessaan takaisin eiliseen mennessä.
Jolla kertoi myös mielenkiintoisia lukuja Sailfish X:ään liittyen. Jollan mukaan yli 800 henkilöä on hyväksynyt Sailfish X:n osakorvaukseksi rahallisen korvauksen sijaan. Lisäksi ennakoivalla tekstinsyötöllä on Jolla Kaupassa 1000+ latausta (käsittääkseni ladattavissa vain Sailfish X:llä). Jolla Kaupassa seuraava porras latauksille olisi 5000+. Voidaan siis laskeskella, että Sailfish X:n hankkineita on sellaiset 1000-5000 kappaletta, joista reilu 800 on ottanut Sailfish X:n vastaan hyvityksenä tablet kampanjaan liittyen.
Mä otin ainakin osa hyvityksenä, siinähän olis voinu saada kaksi noita X:ä.
Itse en oo muuta ongelmaa huomannu, mutta ilmeisesti muistivuoto, jossakin kun alkunäkymää joutuu aika useasti käynnistämään uudelleen lähinnä Android appit lopettaa toimimisen.
Kehittäjät ovat ilmeisesti saaneet kasaan ensimmäisen jossain määrin toimivan version X Compactille (f5321).
Tuesday, 2017-10-24:
stephg: if you want to test my 2.1.3.5 image I can share
naytsyrhc_: to stephg: i flashed the image you provided and it worked like a charm. Don't know, why my built didn't work though. Maybe the third image I build will work out ;-)
Friday, 2017-11-03
14:20: naytsyrhc_ stephg: have been quiet a while. sorry for that. was busy. you seem to make progress with automated builds for f5321? anything you need someone else to test?
14:55: stephg naytsyrhc_: at the moment not really, just waiting for OBS to be fully functional again
14:55: stephg hope things are going well tho
naytsyrhc_ ok. so I'll just enjoy the current working version ;-) thx.
Kutkuttaa - tuon kun saavat toimimaan niin Compacti menee ostoon. X:ääkin harkitsin, mutta kun kävin Verkkokauppa.comissa hipelöimässä, niin tuntui aika möhköltä + en tarvitse isoa näyttöä..
X Compact buildin pitäisi valmistua tässä piakkoin :).
Saturday, 2017-11-18
08:41: Stephg Mikayx: the X compact is very very nearly ready
08:41: stephg I have one last problem building to solve and then we can announce
08:43: Mikayx OK. That sounds good. Is that an official Jolla release or Community built at first?
08:47: stephg Mikayx: community; but it's fully functional
Ne taitaa tulla vain virallisessa versiossa. Se on yksi "maksullisista" osista.
Kysyin vähän hassusti väsyneenä. Eli asian ydin oli, että saako tuota maksettua osuutta käyttöön community porttaukseen, vaikka jollain purkkavirityksellä?
Tuolla Sailfish Porters kanavalla oli asiasta aiemmin keskustelua. Ilmeisesti alien dalvikin (=Android tuki) porttaaminen community buildeihin on mahdollista mutta hieman kyseenalaista lisensoinnin kannalta. En tiedä, olisiko tuohon jotenkin mahdollista neuvotella jokin ratkaisu Jollan kanssa.
popeye Will alien dalvik ever come available for community ports? 20:26
popeye I'm sure every SFOS port user would buy it if that was an option 20:28
r0kk3rz ever is a long time 20:29
jakibaki I think that if you own sailfish-x adding the aliendalvik repo should be enough to get the package. 20:30
jakibaki Getting it to work on that specific device is an other question though 20:31
guhl well we could start a crowd funding project to take over the Myriad group 20:31
popeye I'm for it. Take my money!!! 20:31
r0kk3rz might be cheaper to buy AD instead of the whole company 20:33
jakibaki Not sure how legal using the sailfish-x-repo would be though because you paid only for using it on one xperia-x :( 20:34
mal or make anbox working properly 20:34
jakibaki mal: or that :D 20:34
guhl r0kk3rz, yeah but a hostile take over is more fun 20:36
jakibaki Can someone please confirm/deny if the [credentials-store] section of /etc/ssu/ssu.ini is the same on multiple devices with the same jolla-account? 20:38
guhl but we would have to act fast as they are going to delist from the stock exchange in April 2018 20:39
Mister_Magister jakibaki: if you want aliendalvik just download it on the official device and use rpm wherever you want 20:40
mal but that is still highly questionable legally :) 20:41
jakibaki Mister_Magister: I know. What I would like to research is if it's possible to use a Sailfish-X license to get Alien-Dalvik without owning an Xperia-X (or pirating the rpm) 20:41
Mister_Magister mal: if you bought device then you bought that rpm too 20:41
Mister_Magister it's yours 20:41
mal Mister_Magister: I'm pretty sure the license is per device 20:42
Mister_Magister well whatever rpm is yours :D 20:42
Mister_Magister nobody will check that really but posting that rpm somewhere is piracy 20:42
mal Mister_Magister: that's not how software licenses work :P 20:44
Mister_Magister :D 20:44
Mister_Magister mal: but still nobody will look into your device if you have pirated aliendalvik from your other device :D 20:45
jakibaki No, the cyber police is out to get you! 20:45
Mister_Magister like when i posted video and photos with aliendalvik everybody with james as jolla was hyped about it 20:45
Mister_Magister and everybody did know that it's not available for x force 20:46
Mister_Magister wow aliendalvik is working on x force but not on g2 how sad 12:52
Android sovelluksien ajamiselle epävirallisissa Sailfish OS -laitteissa on kehitetty myös vaihtohtoisia tapoja kuten SFDroid.
Sailfish X asentui eilen Xperia X:ään suht kivuttomasti, mutta tutorialin jälkeen käyttöjärjestelmä jää jumiin lataamaan jotain. Pitää vielä yrittää flashailla uudemman kerran.
Edit. Nyt on flashailty puhelin uudestaan ja nyt vaikuttaa toimivalta. Aikaisemmalla kerralla Sailfish käynnistyi normaalisti ja kysyi suojakoodin määrittämistä. Tämän jälkeen olisi ollut vuorossa internetyhteyden määrittäminen ja Jolla -tilin määritys. Internetyhteyden kohdalla ainut vaihtoehto oli ohittaa toimenpide. Tämän jälkeen päädyttiin tutorialiin. Tutorialin lopussa oli näytetty herätyksen ja ajastuksen asettaminen. Näiden jälkeen ruutuun jäi latausympyrä, joka jäi pyörimään ikuisesti.
Mitä tein toisin? Asensin Sonyn Emmaa käyttäen uudestaan version 34.3.A.0.228 -> puhelin käyntiin, skippasin kaikki asetukset ja suoraan kehittäjätila ja usb debugging päälle. (Aiemmin en ollut tätä tehnyt tässä vaiheessa) -> Puhelin kiinni ja flash-on-windowsin ohjeiden mukainen toiminta. Puhelin käynnistyi ja nyt kysyikin jo nettiyhteyksiä ja Jolla -tiliä. Myös tutoriali oli erinäköinen.
Toimiikos Sailfish Xssä jo Bluetooth? Aattelin että jos kokeeks hankkis luurin nyt kun on tarjouksessakin tuo sailfish.
Jolla tabletin uusi tuleminen (Youyota Sailfish Tablet) näyttää saavan saman kohtalon kuin alkuperäinenkin joukkorahoitus:
chenliangchen sanoi:
I'm trying to push Michael for a refund. This is the most I can do.
I personally don't think this project can go any further - It relies solely on Michael/Youyota side, and that shouldn't be like this.
He has purchased a few Ks of certain components at own cost, but a lot of parts has increased price dramatically recently. Especially memory. Now it all comes to cost, and opportunity cost.
This project has gone wrong from beginning - I connected Youyota and "the other party" (yes as certainly they will not be happy for me mentioning their name) in the hope of bringing this product back to real. But "the other party" was in such a deep trouble with their own version of this product, they seem not motivated in taking part in too much of this one - for whatever reason.
So it all comes down from a project suppose to contribute jointly, down to Youyota's own game. But Youyota is just the manufacturer, there is no investment on PR, marketing, and they cannot afford to have it.
And because of the above reason, Youyota can't start production because the number is way too low. I did push them to invest for a minimum quantity, and they did. But this time of the year, everything has become much more expensive, and they are spending extras which to be honest, they should not do so. But they did.
The problem is now the cost was even higher than their expectation, and they are struggling as they need to spend money and efforts generating revenue.
Why should any of a healthy business cooperation invest money and effort, to a project that cannot make any revenue in a while, instead of doing something else?
And to be honest, I spent a lot time and efforts in the beginning connecting two parties, and I did sort of the avocation in the beginning. Youyota has spent money and deposits and efforts buying components. And negotiating with the factory. It wasn't successful, but I know they tried. The community backed the campaign...
What the F*CK did "the other party" do? I can't remember anything.
This is the end. I will do my best to make this project to an end, either refund, or production, I don't know. But I personally think refund makes sense.
It's holiday period now in China, I will push for an update after new years' day. Hopefully early Jan.
(linkki)
Ainakin LG:n valmistamia näyttöpaneeleja on jo ostettu muutama tuhat kappaletta mutta muista komponenteista ei ole tietoa. Nyt näyttää siltä, että kaikkia komponentteja ei saada ostettua kokoonpanoa varten.
Kokonaisuudessaan Jolla Tabletteja valmistettiin virallisesti reilu 1000kpl, joista 661 päätyi joukkorahoittajien käsiin. 400 kappaletta meni jälleenmyytäväksi epävirallisia reittejä pitkin ja muutamia demokappaleita lienee lähetetty arvostelijoille jne. Lisäksi projektin kanssa yhteistyössä toiminut tehdas valmisti omin päin X määrän epävirallisia Jolla (ja Ango) tabletteja, jotka päätyivät niin ikään epävirallisesti myytäväksi (kts. Jolla Tablets on Taobao: What's happening?). Näissä tableteissa tosin saattaa olla joitain eroavaisuuksia originaaliin nähden.
Jos joku vielä kaipailee "Jolla tablettia", niin paras vaihtoehto taitaa olla Aigo X86 tabletti Sailfish OS:lla asennettuna:
Eli kerrasta ei otettu opiksi.
Kyllähän tämä Jollan touhu näyttää aika epätoivoiselta. Eipä tainnut tästäkään mitään merkityksellistä tulla koskaan.
Tässä projektissa Jollalla tosin ei enää ollut muuta roolia kuin tarjota itse käyttöjärjestelmä. Youyota olisi ollut vain Jollalle lisensointikumppani.
Minusta tämä kuitenkin heijastaa ihmisten kiinnostusta Sailfishiä kohtaa. Kuten Youyotakin on todennut, tilausmäärät jäivät pieniksi. Tuossa laitteessa ei kuitenkaan raudan puolesta vaikuttaisi olevan mitään maatamullistavaa joten eiköhän se Sailfish ole se syy hankkia tuo.
Ja Jollan pitäisi todellakin saada vältettyä tälläisiä epäonnisyumisia koska vaikka syy ei itse Jolla firmassa olekkaan niin nämä ihmisten mielikuviin kuitenkin vaikuttaa.
Happy New Year Jolla fans and followers! | Jolla Blog
Ovat tuomassa Sailfish X virallisen tuen dual-SIM mallille F5122, sekä kolmannelle puhelin mallille, jota eivät vielä ole kertoneet. Myöskin Compact versiolle lähitulevaisuudessa lienee tulossa, koska paljon kiinnostusta. Ja asennukseen tulossa graafinen liittymä, jonka pitäisi mahdollistaa käyttiksen helpon asennuksen.
Saas nährä mitä tuleva vuosi tuo tullessaan...
Itse olen todella tyytyväinen omaan Sailfish X luuriini, ei ole ollut mitään ongelmia, akkukestokin aivan loistava ja tarvitsemani palvelut pelaa täysin.
Tämä on kyllä juurikin se järkevin tapa saada käyttistä maailmalle, noin pienen yhtiön on aivan turha lähteä raudan kanssa leikkimään. Vielä kun muitakin valmistajia saisi mukaan niin suunta olis hyvä, valmistajille kuitenkin lienee suht helppo olla mukana kun jolla hoitaa kaiken softan puolesta?
...ja valmistajat haluaisivat olla (helposti tai ei) mukana koska...?
Erottuakseen massasta ? Tässähän se idea onkin että valmistaja julkaisee vain sen yhden mallin ja jolla hoitaa softan, massoille myydään androidia ja vähän aktiivisemmat voivat kokeilla jotain uutta.
Venäläiseltä INOI:lta on ilmeisesti tulossa kaksi tablettia. Nämä saattavat olla Sailfish OS tabletteja (Venäjälle räätälöidyllä versiolla), sillä INOI:n edellinen tuote oli INOI R7 puhelin Sailfish OS käyttöjärjestelmällä.
Jotenkaan ei oikein houkuttele tuo venäläinen Sailfish tabletti. Olenkohan vain liian vainoharhainen. Toisaalta, liekkö tuolla edes tekee mitään venäjän ulkopuolella.
Kehitys ilmeisesti etenee. Eiköhän tuo projekti vielä valmistu :).
Vaimolla alko kiinnostaa tuo Sony xperia x ja nimenomaan SailfishX:llä. Mikäs sen tilanne nyt on, toimiiko kaikki ominaisuudet kuten hotspot, bluetooth yms..?
Akunkesto reippaammalla käytöllä kiinnostaa ja systeemin yleinen vakaus? Onko kukaan testannu/saanut toimivaksi android pankkisoftia (OP), kun natiiveja ei taida löytyä?
Eniten se käyttää naamakirjaa, instagramia ja spotifyä, löytyykös näille natiiveja versioita vai pitääkö turvautua androidi softiin?
liiger
