Kummasti jengi luottaa Nicehashin postailuihin ja sovelluksiin, kun niiden oma historia on tätä:
Wikipediasta:
Service disruptions[edit]
On December 6, 2017, approximately 4,700 Bitcoins (US$64 million at the time of the hack) were stolen from NiceHash allegedly by a spear phishing attack.[9] Due to the open and transparent nature of the blockchain, the security breach received an influx of attention as the stolen sum and movement of bitcoins were visible to anyone on the internet.[10]
On December 21, 2017, Marko Kobal resigned as the CEO of NiceHash.[11] On that day, the company also re-opened their marketplace after the December 6th hack.[citation needed] NiceHash has decided to reimburse the affected users through the Repayment program, 100% of the stolen funds were reimbursed on December 16th 2020.[12]
Controversies[edit]
NiceHash's founder Matjaž Škorjanc is a creator of malware Mariposa botnet, which infected over 1 million computers with Butterfly (mariposa in Spanish) Bot. The goal of Butterfly Bot was to install itself on an uninfected PC, monitoring activity for passwords, bank credentials and credit cards. Slovenian police arrested Matjaž on charges of distributing the malware in 2010. Matjaž was found guilty and had served four years and ten months in a Slovenian prison. On June 5, 2019, US law enforcement opened a case in the operations of the Mariposa (Butterfly Bot, BFBOT) malware gang.[13] FBI has moved forward with new charges and arrest warrants against four suspects including Matjaž Škorjanc.[14]
Onneksi sentään maksoivat takaisin menetetyt bitcoinit vaikka aikaa menikin, taisi olla joillekin hyvä tämä järjestely kun arvo on vaan noussut. Mites kävi Mt Cox tapauksessa.
Maksoivat joo, niille jotka tiesivät/muistivat rekisteröityä NH:n linkistä jne. Moniko jaksoi odottaa pari vuotta moisen tapahtumista?
Eipä taas yllättäny tuo Nicehashin toiminta. Toppahousumainaajat kiimassaan varmaan käyttiksiään asentelivat uudestaan ja tekivät testamentteja valkoisilla käytävillä. Pieni lähdekritiikki olisi joskus paikallaan tässä nykymaailmassa.
Voisi mielenkiinnosta vetää yhdelle setupille tuon trexin testiin, muutenkin vähäisen kaluston myyntiä tällä viikolla ja jossain kohtaa toinen rtx3070 kone siirtyy siskolle tai myyntiin.
Trex on hyvä ja toimiva. Ei nyt kannata konetta myydä, antaa louskuttaa.
Huvittavinta tässä on se että muut "mainauspalvelut" eivät noteeranneet Phoenixminerin latauslinkkien poistumista ollenkaan, koska heillä oli omat serverit missä he säilyttivät uusimpia vakaita versioita softasta.
Jos NiceHash olisi itse hostannut nuo Phoenixminerin tiedostot niin koko asiaa ei oltaisi edes huomattu heidän puolelta.
Ja on kyllä aika epäammattimaista että NiceHash appi latasi tiedostoja Megasta sen sijaan että ne tiedostot oltaisi turvallisesti hostattu heidän omalla serverillä... (source)
Testasin timespy tuloksia tammikuun alun tuloksiin. Eroa graphic scoressa noin 200 pistettä ja sekin johtuu varmaan ajureista jotka on vaihtunut uusimpii aina, kun saatavilla.
Kohta 3 viikkoa 3080 louhittu. Alivoltitettu 732mv joten core on jotain 35c-42c väliltä, kun huoneessa pidetty 10c-15c. Muistit ollu suurimman osan ajasta +1500. Ei kaatumisia eikä hylättyjä shareja minerista. Muistin lämmöt aina alle 100c. Alkuun oli pari viikkoa 92c ja nyt noussut 96. Johtunee thermal padien rasvottumisesta. Avaan kortin tämän tai ensi viikon aikana joten syy selvinnee sitten.
Eli 3 viikossa ei kortti ole menettänyt tehoa, kun lämpöihin on kiinnitetty huomiota.
Oliko Nicehashilla ees mitään näyttöä, että jotain haitaketta olisi tuon kautta levinnyt vai oliko pelkkää spekulaatiota?
Ei, heidän oman minerin kehittäjä oli tehnyt ylipitkän reddit-postauksen missä TL;DR oli että Phoenixminerin viralliset Mega-latauslinkit hajosivat (Mega bannasi PhoenixMinerin tilin ilman selvää syytä) josta he tekivät johtopäätöksen että PhoenixMinerin kehittäjä oli ihan varmasti tekemässä exit-strategiaa missä paskotaan kaikki.
Tällä hetkellä on noitajahti käynnissä sen selvittämiseksi että oliko NiceHash tehnyt temput ja pistänyt tyhmyyksissään (hetkeksi) jakoon phoenixminerin huijausversion 5.5d mitä erinäiset botit postaavat eri foorumeille. 5.5d versiota ei siis ole olemassakaan, se on huijausta.
Eli 100% spekulaatiota ja FUD:ua.
Tällä hetkellä on noitajahti käynnissä sen selvittämiseksi että oliko NiceHash tehnyt temput ja pistänyt tyhmyyksissään jakoon phoenixminerin huijausversion 5.5d mitä erinäiset botit postaavat eri foorumeille. 5.5d versiota ei siis ole olemassakaan, se on huijausta.
Eivät sentään redditin mukaan olleet jakaneet malwarea vaan nicehashin tarjoama phoenixminer update itseasiassa deletoi phoenixminerin ja korvasi sen tyhjällä pluginilla.
Mielestäni olemme phoenixminerin osalta palanneet kohua edeltäneeseen aikaan. Riskit on toki edelleen olemassa anonyymin palveluntarjoajan kanssa, mutta niin ne oli jo ennen eilistä. Ehkä yhteisön jäsenet on nyt vain paremmin niistä tietoisia. Palautin oman dedikoidun 3070n töihin Phoenixminerin kautta. Tiputin toistaiseksi muistien kellot tasolle +600 ja aion seurata kortin 3d suorituskykyä säännöllisesti.
Harmi kun ei ole järkevää pätkä-sopparia tarjolla.
Joo joutuu pistää cash in. Noi puhelinfimat taitaa olla ainoita mitkä tarjoaa kulutonta luottoa. Powerilla plussaksi voi kyllä tässäkin tapauskessa laskea 60p palautus ajan.
Itse sain räävittyä kasaan rahat 5 koneeseen. Vähän epäselvä menikö viimisen kahden tilaus läpi. Ainakin eurot lähti, mutta näyttää samaan aikaan loppuneen varastosta.
Vähän menee mielenvikasen puolelle jo tää mun homma. Alkaa olemaan euroja kiinni sellanen määrä romuraudassa, että heikottaa :D
Yksi mahdollisuus on se, että NiceHash on virallisten linkkien hajoamisen jälkeen autoupdatennu käyttäjille muokatun version jostain likaisesta lähteestä. Onneksi itsellä oli tuo PhoenixMiner disabloituna NiceHashin asetuksista, koska Windows Defender ei tykännyt siitä.
Erikoista on myös, että jengillä Defenderit hälyttelevät tuon kanssa. Itsellä ei ole ollut mitään ongelmia defenderin (ei foorumilta, eikä tuolta epäviralliselta nettisivulta ladatun) kanssa, mutta Chrome pisti tämän kanssa ladatessa vastaan. Käytin IE:tä, niin tuli läpi.
Ehkä nicehash tekee jonkin oman injektionsa? En ole itse heidän soppaansa lusikkaani työntänyt Quickminer softan testauksen jälkeen.
Nooh, kukin tietysti tyylillään. Itteä alkaa heikottamaan siinä vaiheessa jos joku oikeesti ostaa kaikki mahdolliset pakettitietokoneet luotolla louhiakseen niillä rahaa tilanteessa jossa kukaan ei tiedä onko muutaman kk jälkeen mitään jäljellä. :D
Noi telian luotot on ihan jees kun kulut on oikeasti 0€. Saa sijoitetulle pääomalle huomattavasti paremman tuoton. Muuten velkasi näitä kannatakkaan ostaa. Välineenä luottokortit on vaan ihan hyviä kun ei tartte pitää käteistä saatavilla. Toki niidenkin limitit tulee täyteen...
Saapa nähdä tuleeko muutoksia eth:n suhteen myös 3060ti/3070/3080/3090 kortteihin:
Perjaatteessa mahdollista, miksi muuten muuttais SKU tunnuksia kesken kaiken..
Tuskin olemassa oleviin malleihin mitään muutoksia mutta tulevat ti mallit joutuvat varmasti bännään
Ja jos tuleekin nykyisiin malleihin niin sehän vain nostaa ei nerffattujen korttien arvoa :cigar2:
Toisaalta ihan ok saa pelaajat myös näytönohjaimia, vanhoista tulee tosiaan todella haluttuja ainakin eth mainauksen loppuun asti.
Kaksi uudehkoa näyttistä jää jauhamaan ainakin nämä kylmät päivät vielä ja yhden ser koneen parin pisteosan myynti ja loput hyötykäyttöasemalle (sain kortista lähes vuoden mainaustuoton myynnillä)
En ole ihan täysin ymmärtäny tuota nvidian logiikkaa. Tosin, HX sarjan hinnat on edelleen pimennossa niin vaikuttaa tähän aika paljon.
Mutta ongelmahan on siinä että raaka-aineen hinnat nousee -> osien hinnat nousee. Tehdas ei pysty tuottamaan niin paljon kun on kysyntää -> on asiakkaiden vika?
Sitten jos iso osa asiakkaista on louhijoita, niin tavotteena on sanoa sille isolle asiakasryhmälle heihei, teille tehdään omat tuotteet jotka on todennäköisesti sitten kalliimpia kuin näille muille huonommalla jälleenmyyntiarvolla. Sama kuin autoliike sanoisi isolle yritysasiakkaalle että hei me ei myydä nyt näitä normaaleja autoja enään teille, vaan teille toimitetaan autot ilman takaikkunoita ja logomerkkejä ja jätetään lisävarusteet pois.
Ja hauskaa tästä tekee sen, että ETH louhinta tulee todennäkösesti heinäkuussa jo laskemaan huomattavasti kun siirrytään muihin kolikoihin, ja 6-18k aikana se loppuu sitten kokonaan. Nyt jo on puhuttu siitä että komponenttipula tulee menemään vähintään syksyyn saakka. Miksi nyt käytetään siis aikaa rahaa ja resursseja estämään osien tietynlainen käyttö kun se loppuu jokatapauksessa hetken päästä..
Käsitin että HX kortit olisi 2000 sarjan prossuilla, tällä Nvidia saisi mainerille työnnettyä vanhan roskan ja pelaajat ostaisi uudet.
Perustan lähteeni myöhäis illan surffailuun joten tämä on mutua.
Ei tuosta luulisi olevan kovin paljoa nvidialle hommaa erotella pelikortit ja louhintakortit. Johan ne nyt tekee pelikortit ja ammattikortit erikseen.
Vähän tässä NiceHash käyttäjänä pohtii, että pitäisikö nukettaa Windowsin asennus, kun kuitenkin käyttää konetta muuhunkin, kuin mainaamiseen. NH ei ole ollut kovin avoin, esim. mitään järkevää vastausta ei ole saatu siihen mistä tuo niiden paniikki alkoi. Ainoat selitykset tällä hetkellä se, että ovat itse puskeneet jonkun likaisen PhoenixMiner version käyttäjille tai sitten NH perustajalla on vain kilahtanut joku psykoosi tulille (sen viimeisen vuorokauden reddit ja bitcointalk postaukset viittaa vähän siihen suuntaan).
Jos Nvidia olisi leiponut noista normi-näyttiksiä, niin ne olisivat toki menneet kaupaksi, mutta sitten mainauksen laannuttua olisi ollut aika tiukkaa saada saman luokan uusia näyttiksiä kaupaksi, kun käytettyjen markkinat olisi olleet mainaajien myymistä ihan tukossa. Nythän noilla ei käytännössä ole likimain mitään jälleenmyyntiarvoa mainausbuumin loputtua. Näin saadaan sitten pelaajille myytyä taas lisää uusia kortteja. Käytännössä mainaajat siis nähdään vaan väliaikaisina asiakkaina, mutta pääpaino on pelaajamarkkinassa.
Itsellä kyllä tuossa ärsyttää nimenomaan tuo markkinointi, että "hei me ollaan teidän puolella pelaajat". Jos olisivat vaan sanoneet, että 3060 mainaus rajoitettu ja tässä nippu mainaajille suunnattuja kortteja jolla ei muuta tee, niin mikäpä se siinä.
Miten te jotka mainaatte "käyttökoneella" olette konffanneet näyttiksen kellotaajuudet ja tuuletinnopeudet? Siis lähinnä mietin sitä, että kun ainakin itse käytän konetta hyvin paljon erittäin kevyeen nettikäyttöön, ja mielellään pitäisi koneen mainaamassa aina myös tuon normaalin toimistokäytön aikana. Näyttiksen alikellotus ei ole tuossa käytössä mikään ongelma, mutta tuulettimien säädöt on pienoinen ongelma.
Näyttis: 3060 ti
Core -500
Memory +1000
Power limit 65%
GPU Temp 48,5*C
HotSpot 61*C
GPU Tuuletin 60%
CPU 61*C
Eli siis esimerkiksi tuo 60% on jo melkoinen fööni, ja jos nyt haluaisi laskea tuulettimen käytön kortin oletuskäyrälle, tippuisi nopeus käytännössä 30 prosenttiin ja pysyisi siinä koko ajan samalla kun GPU coren lämpö nousisi jonnekin 60* tuntumaan. Olisiko turvallista tehdä noin, jos tiputtaisi muistien kellotuksen kokonaan pois? Turvallisempaa olisi ehkä tehdä joku välimalli, eli esim. kellotus pois muisteita ja tuuletin esim 45% silloin kun joutuu istumaan ihan koneen vieressä?
Kukaanhan näihin ei tietysti varmaan vastausta tiedä, mutta tällä kortilla ei taida olla mitään tapaa tietä kuinka kuumana ne muistit käy..
Jos GPU mainaajat siirtyy muutenkin jonkun muun crypton perään kesän jälkeen niin rajoituksella ole yhtään mitään merkitystä? Liekö siellä jotain muuta cryptoa paremmilla profiteilla eth nerffin jälkeen? Redpanda ainakin haukkui viime striimissä eth:n. Tosin se liittyi täysin tuohon, että karkaavat alkuperäisestä hajautetusta mallista keskitettyyn.
Mitäs mieltä arvon raati on:
Loppuuko PSU:ista potku kokoonpanolla 2xrtx3080, 1xrtx3070 ja virtalähteet on 850w ja 550w.
Ongelmia tuottaa tuo 3070, joka ei millään suostu toimimaan noiden 3080: kanssa. Laitehallinnassa on ajuriongelma vuorotellen 3070:llä tai toisella 3080:llä.
Riseriliitoskortteja on kokeiltu ristiin rastiin eri väylissä, mutta ei kolmikko suostu toimimaan.
Koneena toimii Asus Z170-A emo, i7-6700k ja 8g muistia.
Samaa olen mä ajatellut, kun lähes aina käyttänyt nvidian kortteja pelaamiseen. Nythän se mun oma "tavarantoimittaja" sanoo mulle että hei, en halua sua asiakkaaksi, osta näitä ei varusteltuja autoja ennemmin.
Siis ymmärrän toki sen että ei välttämättä lähdetä rakentamaan uusia tehtaita nyt tän hetken buumin takia. Mutta toisaalta, luulis niiden nyt olevan ajantasalla sen verran että hoksais mikä on ETH:n tilanne. Rajotukset kun koskee vain sitä yhtä algoritmia.
Kyllä ne tilannetta seuraa. Ethereum Price Index — CoinDesk 20
Kuten moni mainaaja myös. Tehtaita varmaan tehtäisi, mut niiden rahoitus? Ei ilmaista rakennella.
Koskee vaan yhtä ja hiljalleen siirrytään muihin kolikoihin.
Ei lopu.
Ei minunkaan laskujeni mukaan.
Mistä ihmeestä lähtisi ongelmaa purkamaan...tuohon pitäisi mennä vielä kolme korttia lisää, tietenkin sitten tarvitaan lisää potkua, mutta nyt ei edes näitä kolmea saa yhteen kokoonpanoon...
Kannattaa testata HiveOS jos ei saa windowsia toimimaan. Yksi rigi on siinä ilmainen vaikka louhii mihin tahansa pooliin. Siinä toimii hyvin eri malliset kortit samassa rigissä ilman konflikteja. Siihen verrattuna NicehashOS on ihan paska.
Tässä ihan ok ohjeet hiveos:n pystyyn laittamiseksi:
Täytyy jossain vaiheessa tutustua tuohonkin...
Sen verran vielä että 5600 xt toimii kuitenkin noiden kahden 3080:n kanssa ilman mitään ongelmaa.
Ei tarvitse, tai riippuu mitä kortteja lisäät.
Mikä mineri käytössä? Ja kokeiltu pelkkää 3070?
Nicehash, mutta ongelma on heti win10 käynnistyksessä, kun laitehallinassa on ongelma joko 3070 tai 3080 kanssa , pelkkä 3070 toimii kaikken muiden kanssa ok, paitsi kahden 3080. Jompikumpi putoaa kyydistä 3070 tai toinen 3080
Täällä oli sama homma 3080 & 3060 Ti kanssa.
Ilman riseria toimi ok, mutta 3060 Ti kun kytki riseriin niin joko windows ei enää bootannut, tai laitehallinta/ajurit tekivät mielettömiä temppuja jatkuvasti.
Koneesta tuli käyttökelvoton.
Siirsin 3060 Ti:n riserin kanssa toiseen koneeseen, jossa päänäyttiksenä radeon ja ei mitään ongelmia.
Pitäisiköhän koittaa laitaa tuo 3070 suoraan emolle ja muut riserilla... On tää yhtä turaamista prkl :)
Kyllä ne kirjoittelee ajatuksiaan.
En ihmettele "ylilyöntiä" jos 70 miljoonaa taalaa on viety 2017 hakkeroimalla. Kovat paineet tuollaisilla summilla ihan varmasti.
Missähän aineissa ne on tuon tekstin kirjoittaneet? Vilisee kirjoitusvirheitä ja ihmeellisiä väittämiä (maksetut shillit hyökkää NH vastaan jne). Sama homma bitcointalkin foorumilla, NH perustaja syyttelee muita palkkamurhayrityksistä, kiristyksestä jne. Taidan formatoida levyn ja asentaa Windowsin uudelleen ihan vaan sen takia, että on ollut NH softa koneella...
PhoenixMiner
Täältä haettu linkki:
Ja lataus täältä:
Homma ok?
Vai trex?
Ei TRex oo myöskään open source tai tekijä tiedossa(kai?), eli yhtä "vaarallista" molempien käyttö. Ite kyllä käytän phoenixia ja jos uudestaan lataisin nii noudattaisin just noita ohjeita ja käyttäsin edelleen phoenixia. Koko kohun pääpointti nyt on se että anonyymin tekijän closed-source koodit voi olla mitä vaan.
T-rexillä rauhoittui jopa hp pakettikoneen stalet ei enään läheskään niin paljoa kuin phoenixminerillä. Tuohon kortin lahoamiseen ajoin nyt sitten oikein benchmarkin ja vertasin iotekin tuloksiin ja antaa osviittaa että oliko kuviteltua suorituskyky lasku? Kuukauden päivät louhinut.
Mielenkiintoinen havainto, että 3070n kanssa Phoenixminerilla nyt löysemmillä asetuksilla (+600mhz, 129w) ja nimellisesti heikommalla laskentateholla tulee kuitenkin toistaiseksi ihan htä hyvää ellei parempaakin tulosta kuin kireämmillä +1000 asetuksilla:
Itsellä ihan samaa vaikka tuntui että 1000-1200mhz muistinopeuksilla sai parhaan reportedin, 600-800 muisteilla taas menee useammin paremmalle puolelle. Kyllä on iso ero 3070 tuf malliin ja hp omen 2 tuuletin mallin välillä metelissä ja lämmöissä. Jostain syystä tuo pakettikoneen 3070 saa pienemmällä watilla paremmat hashit mutta taas stalet on ollut ongelma.
UseTheFours
