PC, PlayStation, XBOX & Nintendo - yhteinen väittelyketju
Ja silti mitään ei ole tapahtunut vaikka montako vuotta nämä konsolit ovat jo olleet markkinoilla? Kuulostaa tosiaan todella vakavalta ongelmalta... jos nyt on edes totta ylipäätään. :D
Et edes lukenut artikkelia?
What’s the problem?
The root of the coming issue has to do with the CMOS battery inside every PS3 and PS4, which the systems use to keep track of the current time (even when they're unplugged). If that battery dies or is removed for any reason, it raises an internal flag in the system's firmware indicating the clock may be out of sync with reality.
After that flag is raised, the system in question has to check in with PSN the next time it needs to confirm the correct time. On the PS3, this online check happens when you play a game downloaded from the PlayStation Store. On the PS4, this also happens when you try to play retail games installed from a disc. This check has to be performed at least once even if the CMOS battery is replaced with a fresh one so the system can reconfirm clock consistency.
Why does the PlayStation firmware care so much about having the correct time? On the PS3, the timer check is used to enforce any "time limits" that might have been placed on your digital purchase (as confirmed by the error message: "This content has a time limit. To perform this operation go to settings date and time settings set via internet"). That check seems to be required even for downloads that don't have any actual set expiration date, adding a de facto one-time online check-in requirement for systems after their internal batteries fail.
On the PS4, though, the timing check is apparently intended to make sure PSN trophy data is registered accurately and to prevent players from pretending to get trophies earlier than they actually had. You'd think this check could be segregated from the ability to load the non-trophy portions of the game, but player testing has shown that this seems to be a requirement to get PS4 games to load at all.
Kerro jos tarvit apua esim. suomennoksen suhteen.
Yksi pelaaja tätä jo testasi irroittamalla CMOS-patterin PS4-konsolistaan ja eihän siinä hyvin käynyt. Sen lisäksi että digitaaliset pelit heitti toimimasta, niin et voi enää pelata myöskään fyysisiä levypelejäsi: PS4's Fatal System Clock Battery Error Reportedly Proven By Player
Mutta jos epäilet että ei ole totta, niin testaa ihmeessä omalla konsolillasi. :tup:
Taitaa olla CMOS-patterin kuoleminen ongelmana vain käyttämättä olevilla konsoleilla, kun patterin virtaa käytetään ainoastaan kun konsoli on ilman verkkovirtaa. Oletuksena kun laite on standby-tilassa, niin taas on saatu aikaiseksi paljon melua tyhjästä. Vai kuvaako sinun mielestä vanhan konsolin vuosien varastointi sellaiselta normikäyttäjän toimintamallilta? En nyt tiedä muista, mutta ainakin meillä vanhat laitteet menee kiertoon uudempien tilalta.
Tämän lisäksi ongelman realisoituminen vaatisi myös sen, että konsoli ei saisi enää yhteyttä PSN-verkkoon ajan synkkaamiseksi. Jos nyt vakavissasi väität että PS4-infra ollaan ajamassa lähitulevaisuudessa alas, niin melkoista FUD:ia olet levittelemässä.
Ei kannata murehtia asiasta sen kummempaa, ongelma koskee lähinnä sitä häviävän pientä vähemmistöä, joka varastoi konsolinsa vuosiksi kaappeihin ja valittelee sitten kun laite ei enää toimikaan vastaavasti kuin vuonna miekka ja kivi. Vastavuoroisesti voitaisiin ulista kuinka esim. Black ops 2 on pelikelvoton netissä huijareiden vuoksi, koska Mikkistä ei kiinnosta paskaakaan modattujen X360-konsolien bannaaminen livestä enää.
Ihan vinkkinä tästä kyllä kannattaisi nostaa kunnon myräkkä että pätsäävät poikkeen eikä puolustella. Se paristo sieltä rapistuu verkkovirrassa tai ei.
Niin kauan kun mun ja 115 miljoonan muun konsolit toimivat ongelmitta, en jaksa näistä FUD-höpinöistäsi oikein välittää.
Konsolit hajoavat paljon ennemmin muista syistä niin kuin mikä tahansa elektroniikka ennen kuin artikkelin doomsday-skenaario käy toteen. Ja siinä kohtaa jos näin käy niin kuten artikkelista sanottiin, on tuo helposti korjattavissa.
Eli mikä tässä nyt on ongelma? :vihellys:
Ei kannata, ei ole ongelmaa, pelkkää höpinää, valetta ja FUDia. :rofl:
Sulla kannattaa ottaa artikkelin kirjoittajaan yhteyttä eikä meikäläiseen purkaa pahaa mieltä. Don't shoot the messenger :D
Ei se ongelma ookkaan nykytilanne, vaan se tilanne kun vuosien päästä noi patterit alkaa kuolemaan väistämättä. Tai sitten useemman vuoden päästä, kun jonkun PS3:n PSN palvelimet on kokonaan poissa pelistä ja koitat digipelejä pelata, niin ei onnistukkaan.
PS4 osalta en näe kovin suurta ongelmaa, sillä 99,9% peleistä toimii uudellakin konsoleilla. Ongelma nousee esille PS3 kanssa. PS3 Storea ollaan jo sulkemassa ja samalla muutama digital only peli on yhtäkkiä saamattomissa, ellei sitä jo aikasemmin ostanut. Päivityksienkin lataaminen on jo jokseenkin ottanut osumaa, mutta tästä mulla ei suurempaa tietoa ole et koskeeko kaikkia pelejä, vai vaan osaa. Jokatapauksessa ei hirveen hyvä juttu, sillä PS3:lla on muutama yksinoikeus joka on lukittuna vaan sille konsolille, ilman että mitään remasteria tai muuta sen suuntasta ollaan tehty uudemmille vehkeille. MGS4 nyt tulee ekana mieleen.
PS3 osalta onneks tosin levyltä pystyy pelaamaan vaikka se CMOS paristo oliskin jo luovuttanut, et sinällänsä hyvä et se puolisko on ainakin turvassa. Ja toki PS3 softamodaaminen on nykypäivänä käsittääkseni mahdollista about jokaiselta firmisversiolta, niin en nyt välttämättä lähtis noista digipeleistäkään murehtimaan ihan liikaa, mut sitä ei voi kieltää et se on helppokäyttöisyyden kannalta ongelma, ei kaikilla oo riittävää osaamista tai halua nähdä sen verran vaivaa mitä tohonkin hommaan menee, ihan vaan sen takia että pääsee pelaamaan peliä jonka on jo aikoinaan ostanut.
Mut vastapainona myös sen verran täytyy myöntää et on se ihan ymmärrettävää ettei noiden kauppapaikkojen pyörittäminen 14v vanhalla konsolilla voi olla hirveän kannattavaa puuhaa, ja se töpseli on jossain vaiheessa vedettävä seinästä. Varsinkin jos jokasen konsoli kauppapaikka pyörii erillään toisistansa, eli PS3, PS4 ja PS5 omaa jokanen oman alustansa. En tosin tiedä et mikä se totuus on PS4 ja PS5 kanssa, mutta PS3, PSP ja PS Vita nyt ainakin pyörii omilla alustoillaan joka nyt sit aiheuttikin sen tilanteen et töpselit vedetään seinästä. Toivoa sopii et PS4 ja PS5 ja tulevaisuudenkin konsolit pyörii samalla alustalla, niin ei sit tulevaisuudessa tule samaa tilannetta vastaan et joitakin tiettyjä pelejä ei vaan oo mahdollista ostaa enää tietyn päivän jälkeen. Ainakaan laillisin menetelmin.
Useimmillehhan tää nyt ei käytännössä tarkota mitään, mutta PS3:lla on kyllä muutama peli johon näen vielä joskus palaavani uudestaan, eikä niitä pelejä ole oikeen mitenkään muuten mahdollista pelata kun aidolla konsolilla. Ongelma toki saattaa ratketa myös itestään jos emulaatiopuoli PS3 osalta kehittyy tarpeeks, mutta siihenkään ei oikeen ole mitään lupausta. Fakta nyt kuitenkin on se, että ellei tietyt porukat napsis noita PS3 storen pelejä talteen jotta niitä on mahdollista tulevaisuudessakin pelata ilman et on sen ajoissa tajunnut ostaa, ei niitä vois yksinkertaisesti pelata enää sen tietyn päivän jälkeen.
Nähtäväks kuitenkin jää mitä tapahtuu. Toivottavaa olis et Sony julkasis PS3:lle sen viimesen päivityksen joka mahdollistaa sen ettei tolla paristolla ole mitään väliä, mut toisaalta en myöskään jaksa pidätellä henkeä asian suhteen. Ellei nyt oo latomassa euroja tonne PS3 Storen suuntaan, niin ne pelkästään digitaalisesti julkastut pelit vähän niinkuin katoaa ulottumattomiin, ainakin jos laillisista menetelmistä puhutaan.
Huomautus - henkilökohtaisuudet, foorumilla ei ole tarkoitus keskustella toisista käyttäjistä
En minä sinuun mitään pahaa mieltä pura. Perjantai huomenna, palkkapäivä ja kevätaurinko paistaa, voiko enää paremmin asiat ihmisellä mennä? :vihellys:
Lähinnä huvittaa kuinka aikuinen mies (?) ottaa näin tosissaan nämä konsolien väännöt ja pyrkii mollaamaan toista konsolia taukoamatta samalla palvoen sitä omaa muovilaatikkoa. Missä mentiin vikaan?
@Raxama ihan asiallisesti sisäisti ongelman, kiitos siitä. Eli ilmeisesti pelkona on, että joskus hamassa tulevaisuudessa ihmisten 20 vuotta vanhat 720p30fps masiinat eivät enää pelejä pyöritä. No en voi sanoa kuuluvani siihen ryhmään joka PS3:lla pelejä pelailee enää tuolloin. Oikeastaan en ole sitä tehnyt enää vajaaseen 10 vuoteen. PS3 meni siskon tyttärelle heti kun PS4 saapui talouteen.
Missäs tässä oli mitään puolusteltu? Toin vaan esille ongelman todennäköisyyden normikäyttäjän vinkkelistä FUD:n levittämisen sijasta. @Raxama kuvasi asian selvästi yksityiskohtaisemmin mitä tämä tarkoittaa eri konsolien vinkkelistä.
Jos haluaa pelata varman päälle niin vaihtaa nyt PS3 cmos patterin. Jos esim 20v päästä ei enää pääse PS3:lla verkkoon (niin kuin ei todennäköisesti pääsekkään koska wlan antenni on niin hapan) niin ainakin kello on oikeassa.
Enemmän olisin yllättynyt että kenelläkään eivät olisi konkat pullistuneet muodottomaksi koneen sisältä vuonna 2040. Olisihan se mahtava tunne päästä niin monen vuoden päästä pahastumaan ja sanoa:"Mitä minä sanoin!" Taitaisin itse vain siinä kohtaa ottaa taskusta paperin ohuen laitteen jossa on enemmän laskentatehoa mitä tämän päivän Exaflop-tason supertietokoneissa ja emuloisin Metal Gear Solid 4:sta sillä.
Minäkin annoin vain vinkin miten voi tähän paristo ongelmaan vaikuttaa että sony ottaa huomioon nämä ei normikäyttäjätkin.
Vähän salaa toivon ettei itekkään tartteis tuohon hommaan ryhtyä, elättelen toivoa et emulaatiota saadan runtattua siihen uskoon et noi isoimmat yksinoikeudet jota ei ole porttailtu minnekkään saatais pyörimään jouhevasti. PS3 on mun mielestä auttamattomasti ehkä hirveiten ikääntyny konsoli, sillä se usein tarjos jotain sub-720p ja sub-30fps kokemuksia jokseenkin takkuilevalla käyttöliittymällä. Se on kuitenkin paras ja yks helpoimmista tavoista pelata MGS 1,2,3 ja toistaseks ainut tapa pelata se MGS 4 siihen perään.
Osaan kuitenkin sen verta jo ennustaa tulevaisuutta et tulen kyllä pelaamaan 1-4 osat tostakin sarjasta vielä elämäni aikana useempaankin otteeseen. Ainakin toistaseks se vaatii ton romukasan nurkissa pitämistä, eikä mulla kovinkaan montaa syytä ton lisäks ole minkä takia se vielä nurkista löytyy. Pelikokemus on kuitenkin aika jäätävä nykypäivänä.
Itse ajattelin metal gearit pelata tämän vuoden aikana ps now:n kautta. Huhuja niiden remakeista myös ilmoilla.
Sen verran hifistelijä oon et striimaushommat oon toistaseks jättäny väliin. Samalla raudalla ne kuitenkin pyörii kun sillä oikealla konsolilla, niin koen helpommaks skipata vaan sen netin yli pelaamisen. Toki jos ei enää konsolia omista niin parempihan tuo on kun ei mitään.
Ja joo, ne MGS remakehuhut menee ihan samaan kastiin mitä Silent Hillin rebootin huhut, paljon puhetta mut mitään ei toistaseks vielä ole nähty, niin se on kyllä visusti siinä "uskon kun näen"-kategoriassa :D
Jos jonkin tietotekniikka-aiheisen sivuston uutisointi merkittävästä ongelmasta konsolin käytössä pitkällä tähtäimellä saa tuollaisen puolustusreaktion aikaiseksi, niin voi tosiaan pohtia, että missä mentiin vikaan. :rofl2: @Turre sai heti ideasta kiinni ilman, että piti ensin käydä perus "voiko olla muka totta", "miksi pitää levitellä FUDia" ym. defenssit läpi, ennen kuin asian sisäistäminen onnistui.
Sinä et varmastikaan ole tämän ongelman kohderyhmää, mutta osaisitko pelkän minä-minä-minä-ajattelun sijaan pohtia, että kun noita vanhoja konsoleja on käytössä vielä miljoonia kappaleita eri puolilla maailmaa, niin voisiko tästä olla jollekin muulle harmia?
Pelaajia on monenlaisia. Kyllä minä voisin kuvitella pelaavani PS3:lla tulevaisuudessakin. Se on kuitenkin ainoa konsoli jolla voi pelata kaikkia tähän asti julkaistuja GTA pääsarjan pelejä aina ykkösestä viitoseen. (Jos on niitä ensimmäisiä PS3 versioita joissa vielä PS2 tuki.) Vitosta voi pelata uudemmalla konsolilla, muita ainoastaan striimaten. Ja monta muutakin peliä löytyy, joita ei ole remasteroitu uusille konsolisukupolville.
Mutta en mä tuosta CMOS patterista kovin huolissani vielä ole. Sehän ei tarvitse kuin että PSN vastaa edes sen verran että antaa kellonajan, muuta toiminnallisuutta ei kai tarvitse olla. Olen kohtalaisen vakuuttunut siitä, että jos/kun joskus Sony päättää lopettaa PSN yhteydet kokonaan PS3 konsolille, niin tulee myös se viimeinen softapäivitys, jossa PSN otetaan pois päävalikosta. Samalla voidaan poistaa vaatimus PSN yhteydestä CMOS patterin loppuessa, kun digipelejä ei saa ladattua eikä trophyt päivity enää, joten tarkasta aikaleimasta voitanee luopua. Turha vielä maalailla piruja seinälle kun ei voi tietää mikä on tilanne.
Mitäs tässä nyt tämmösen savolaisen Ps5-omistajan pitäisi asialle tehdä? Lienee kurjaa monelle joskus hamaassa tulevaisuudessa, mutta niin en kyllä osaa muuta sanoa. :D
Tämäpä juuri. Muilla foorumeilla mitä tulee seurattua, niin porukka on hoksannut aika hyvin mistä on kyse ja aikovat joukolla laittaa pyyntöä/vaadetta Sonyn suuntaan. Tämä softapäivitys pitäisi ehdottomasti tehdä hyvissä ajoin, eikä sitten kun löysät on jo housuissa.
Osa pohti myös joukkokanteen mahdollisuutta, mikäli tähän ei tule minkäänlaista reagointia.
Sama ongelma koskee myös PS4-konsoleita.
COD tai Outriders ei taida edes voida pelata konsoleilla ilman että maksaa siitä online pelaamisesta ?
Mitään ei pysty pelata netissä kummallakaan konsolilla ilman onlinepalvelua. Xboxilla se on se Xbox live ja PS:llä taitaa olla Online nimellä. N. 100e vuodessa menee meidänkin taloudessa Xbox Liveen, jotta pääsee edes konsolilla nettiin. Myös pelit on järjestäen kalliimpia vs PC. Ja Sonyllä taitaa olla kaikista kalliimmat uudet pelit uusilla konsoleilla.
Eihän nuo onlinemaksut hirveästi ole, mutta kyllä tässä matkan varrella on saanut huomata, että kämppiksellä konsolikäyttäjänä palaa rahaa kaikenlaiseen ekstraan, jota PC:llä saa joko ilmaiseksi tai selvästi halvemmalla. Sikäli ne ihmiset on totaalisen idiootteja, jotka vertaa konsolin hintaa vs PC ja perustelee sillä sitä konsoleiden edullisuutta.
Konsoleilla alustat on rakennettu siten, että Microsoft ja Sony tekee massit vasta kun asiakkaalla on se konsoli käytössä. Hardcore -pelaajat voi joutua laittamaan satasia jopa pelkästään ohjaimiin, kun ei nuo kestä kummallakaan pitkään.
Sekä PS5 konsolia... Itse pelaan yhä PS2:lla ja Orginal Xboxilla. Jos PS3 ei toimi kun paristo on kuollut ja PSN3Network on alhaalla, kyllä pistää miettiin tuenko Sonyä. Kun lisäksi osaan peleistä on jo päivitys servut suljettu. Eli porukka on paniikissa kokeillut päivitellä pelejä ennen kesäkuuta ja USAssa sekä Euroopassa on havaittu ettei tiettyihin peleihin ole edes Day one patcheja enää saatavilla.
En tiennytkään, että muuten hyvin toimivassa konsolissa ollaan näinkin paljon jäljessä kilpailijaa mitä tulee share ja capture-toimintoihin.
But looking at the video sharing options on XSX and I'm just baffled. You can only record recent gameplay for up to 1 minute. And clips that are manually initiated can only be a max of 3 minutes if you set it to 720p.
Meanwhile the PS5 is constantly capturing video and lets you capture anything in the last 60 minutes of gameplay and you can even set if you want to capture in WebM or MP4. And the real kicker is that if I want to share a clip on twitter on Xbox I have to sit on the upload screen while the video uploads. On PS5 you can just click share and it just goes.
Minuutin maksimipätkä tai 720p laatu ei kuulosta kyllä sellaiselta miltä sen vuonna 2021 pitäisi olla. Etenkin kun pleikkarilla tuo on 4k60 ja kuva tallentuu viimeiseltä tunnilta automaattisesti.
Auts. Valtaosa on kyllä raivoissaan tuosta. Mitä ihmettä minuutin videotallennuksella edes tekee?
Kyllä tuota on lukemattomat kerrat tullut käytettyä, jos vaikka Halo-matsissa tulee joku hieno triple kill ym. tai tapahtuu esim. joku hassu glitchi pelissä.
Joo, samoin tullut itsellä tehtyä PS4 ja PS5 että nipsauttaa napista viimeiset 30s vaikka talteen, mutta onko tosiaan totta että että Xboxilla en olisi voinut esim heittää kaverille kymmenen minuutin Demons Souls NG+++ bossivääntöä todisteeksi että siinä se nyt on, watch and learn? Miten xboxilla esim napataan talteen speedrunit kavereiden kesken pelin levelille tjms todisteeksi että kuka on paras? Kai nyt esim SD resoluutiolla saa tallennettua vaikka kaksi tuntia jos nyt ei tuota PS5:n 4k60 ole mahdollista tehdä?
Näemmä sama ku xbox onella, ulkoisen levyn ku liittää, nii saa talletella isompia pätkiä.
No hyvä että on mahdollista ulkoisella storagella vaikkakin vaatii nyt rahallista panostusta. Mikähän on lie syynä että sisäiselle kovaleylle ei anneta edes vaihtoehtoa tallennukselle?
Eniten olen raivossani jos tuollaisia automaattisia videotallennuksia ei saa kytkettyä pois päältä. :rage: :rage:
Vahva tämä. Vuonna 2014 otin Xbox Onella jonkun klipin Battlefield 4:stä, mutta en ole sitä katsonut vielä kertaakaan. Mistäköhän se löytyy edes? Switchillä ja PS4 Prolla en ole tallentanut vielä yhtään videoklippiä, vaikka molemmista varmaan ko. ominaisuus löytyy..? Switchillä tulee monesti otettua vahingossa kuvakaappauksia virhepainalluksen seurauksena, jotka pitää käydä sitten erikseen poistamassa. Saakohan tuota kokonaan pois päältä jotenkin?
Mutta hyvä juttu jos asiasta kiinnostuneille tämmönen vaihtoehto on olemassa. :tup: Itse enemmän ehkä arvostan kuitenkin, että pääkonsolin perusjutut on kunnossa, esim. VRR, Dolby Atmos, laajennettava tallennustila jne.
Hyvä artikkeli tuli muuten vastaan teemalla #forthepayers: PS5 isn’t good value compared to Xbox Series X, and I’m sick of it
Hetkinen, pitääkö paikkansa siis, että PS5 kirjoittaa pelatessa koko ajan gigatavukaupalla tavaraa sisäiselle SSD:lle? Kuulostaa kyllä järjettömältä. :confused: Saako tuota kytkettyä pois päältä ja paljonko tuo vaikuttaa SSD:n käyttöikään?
Näköjään porukka netissä pitää tuosta Xboxin mallista aika paljon enemmän:
The Xbox is the best in regards to uploads. I hit the capture button, it uploads, and I save it from the Xbox app and share it or upload it wherever I like and it’s also available on my profile for others to view. If I wanted to customize length to a degree, then I can.
I fucking HATE the PS4/PS5 auto recording and saving clips/screenshots. The Xbox One did this early on and it drove me insane. And I can’t just easily view or save my clips on the PS4/PS5. I don’t want them uploaded to fucking Youtube or Twitter. I want them easily saved on my phone like on the Xbox.
"Yhdysvaltojen pelialaa vahtiva NPD paljasti jo aiemmin, että dollareissa mitattuna Playstation 5 on Yhdysvaltain nopeiten myynyt pelikonsoli. Asiasta uutisoi myös Gamereactor. Nyt sitten NPD:n Mat Piscatella on kertonut Twitterissä, että nopeusennätys koskee myös myytyjä kappaleita.
"US NPD HW - PlayStation 5 is the fastest selling console in U.S. history in both unit and dollar sales (lifetime sales with five months on the market)."
Playstation 5 on nyt siis Yhdysvaltain kaikkien aikojen nopeiten myynyt konsoli niin myytyinä konsoleina kuin dollareissa mitattuna. Konsolia on edelleen hyvin vaikea saada kautta maailman, joten ainakaan lähiaikoina pula ei näytä helpottavan."
Sony jatkaa mihin se viime genillä jäi.
Oho! Oikein "porukka" tykkää xboxin minuutin 720p tallennuksesta enemmän... Melkoinen koneisto lähti päälle että saadaan näyttämään asia omalta kantilta siedettävälle.
Joskus olisi vain helpompi myöntää... heh.
Xbox Series- sarjan konsoleissa video capturen oletusasetuksena on 1080p SDR, eli voit jättää tuon trollaamisen pois. ;) Asetuksen voi halutessaan vaihtaa esim. 4K HDR.
Hyvä kun tämä tuli esille, koska parastahan tuossa on että Xboxilla klipit saa näköjään suoraan tallennettua pilveen, ja voi helposti jakaa sitten vaikka Whatsappilla kavereille. Ilman että vaihtoehdot on rajattu esim pelkästään Twitteriin tai YouTubeen. Mahtavuutta! :tup:
Tässä juuri ihan mielenkiinnosta katselin gigantin sivuja, ni esim xbox series s näyti olevan saatavilla 35 myymälästä.Mutta mitenkä oli pleikkarin kohdalla? no eipä näytä olevan saatavilla kumpaakaan mallia. Kaikki menee sitä mukaan kun saa
Kumpi sitten on parempi kuluttajalle? Kyllä mua ainakin vituttaisi joss haluaisin ostaa kyseisen konsolin enkä sitä millään saisi samalla kun trokarit kasvattaa omia varastoja.
No juu, tuo kyllä totta, mutta onneksi on kesä tulossa, niin eipä muutenkaan tulisi pelattua, ja sen vähän mitä täs pelailee, ni pärjää ps4/pc kombolla. Mutta pointti oli se, että jostain kumman syystä tota huonompaa xbox versiota löytyy joka paikasta..
Oliks tässä mikä se mahtavuus-osio jos itsekään et ole tuota koskaan käyttänyt? Ja kuka oikeasti haluaa jakaa jotain klippejä esim Whatsappin kautta ylipäätänä kenellekään? Ja kuka ihme niitä jaksaisi edes katsoa? :D Ainakin omalla kohdalla täysin turha ominaisuus mutta ehken vaan ole ymmärtänyt sitä mahtavuutta tässä.
Pitänee käyttää jatkossa useammin sarkasmi-tägejä. Ajattelin kyllä että olisi tarpeeksi ilmiselvä. :lonely:
Ei kannata kysellä, tuskin vastausta saat.. Sen mitä tota itse käyttänyt vuosien varrella, ni muutamasta videoklipistä saannut tehtyä youtubeen jonku videon, mut eipä tulisi kyllä mieleen lähetellä kellekkään whatsapissa. pelivideoita.
Kuka edes jaksaa pelata jotain videopelejä tai saatika notkua näillä taistelu foorumeilla? Ihmiset on erinlaisia ja itsellä on kyllä ryhmiä joissa on pelaamisesta kiinostuneita kavereita, kyllä me jaetaan kaikkea pelaamiseen liittyvää.
Noh, PS3 ja PS Vitan storet saivat jatkoaikaa hamaan tulevaisuuteen asti, eli ne digital only pelit on ainakin toistaseks vielä turvassa. Toki vielä on se CMOS-pariston keissi, mutta ottaen huomioon et kun palvelimet pysyy ylhäällä, niin eiköhän konsolilla pelaavat käyttäjät pysty sen verran YouTube videota seuraamaan et saavat sen tarvittaessa vaihdettua. Toki edelleen asia mitä ei käyttäjän pitäs joutua tekemään, mutta parempi vaihtoehto kun se alkuperänen.
#fortheplayers :rofl2:
No paskapuhetta tässä on ainakin se, että MHW kyllä julkistettiin PC:lle samanaikasesti kun konsoleillekkin. Vähän pistää kyseenalaistamaan koko twiitin paikkansapitävyyden muutenkin jos osa faktoista on keksittyjä. Uusin MH Rise ei myöskään ole heti PC:lle saatavilla, vaikka siitäkin ollaan kerrottu että se on tulossa.
Monster Hunter: World
PS4 January 19, 2018
PC Steam 9 Aug, 2018
Kannattaa varmaan tarkistaa nuo lähteesi. MHW esiteltiin konsoleille E3-messuilla kesällä 2017. PC-versiosta kerrottiin tarkemmin tammikuussa 2018 ja sen julkaisu tapahtui elokuussa 2018. Konsoliversiot julkaistiin tammikuussa 2018. Ihan Googlella löytyy nämä faktat.
Ainakin Steam näyttää tuon ajan koska peli tuli ulos
Joo, se kyllä varmaan julkaistiin tuolloin mut kyse ei ollu siitä et millon se julkastiin, se julkaistiin myöhemmin ku konsoliversiot et se oli selvää, mut se kyllä julkistettiin samaan aikaan kun konsoliversiotkin, vaikkei siitä isompaa rummutusta ollutkaan.
Sonyn presiksessä esiteltiin joo, luonnollisesti samalla ei ollu mainintaa edes Xbox-versiosta.
Omalla kanavalla julkaistu reveal traileri sisältää maininnan siitä xbox versiostakin ihan trailerissakin, mutta PC versio mainitaan vain descriptionista. Mut joo, tarkemmin siitä kerrottiin vasta sit tammikuussa konsolijulkasun nurkilla, mut ei sitä varsinaisesti piiloteltu sinne asti et se on PC:lle tulossa.
Niin ja mitäs tekemistä näille on sen kanssa jos Sony maksoi siitä että PC versio siirrettiin kuukausilla ?
Sitä tekemistä et jos twiitissä mainittu PC version olemassaolon pimittäminen ei pidä paikkaansa niin se varmaan asettaa myös loput väitökset ehkä vähän kyseenalaiseen valoon? Toki jos haluaa ilman suurempia todisteita uskoa jotain no-name twitterkäyttävää kolmellatuhannella seuraajalla joka postailee asioita ilman todisteita, niin mikäs siinä, jos se sopii omaan narratiiviin niin mikä vaan kelpaa jne.
Enkä nyt tällä tarkota etteikö se olis mahdollista et tossa on raha vaihtanut omistajaa et PC versiota viivästytetään, se on aika todennäköstäkin eikä sen varmaan nykypäivänä pitäs kellekkään tulla yllätyksenä et ollaan valmiita maksamaan ajallisesta yksinoikeudesta? Mut toisaalta se PC versio oli julkasussa aikamoinen torso ja oli optimoitu ihan miten sattuu, niin ei se välttämättä myöskään aivan koko totuus ole. Ottaen huomioon et missä kunnossa se PC versio oli julkasussa niin jos se ois tullu samanaikasesti konsoliversioiden kanssa niin se lopputulos olis varmaan ollu vielä kauheampi.
Ja mitä noihin cross saveihin ja crossplayhin tulee, niin sillekkin on toinenkin syy olemassa. PC versio laahas konsoliversioita perässä paikoitellen joka ois tehny crossplaysta aika mahdotonta useammassakin kohtaa. Toki se ei ois estäny PS/Xbox crossplayta, mutta Sony on kyllä tunnetusti ollu useemmassakin tapauksessa vastahakonen crossplayn suhteen, tulee nyt ainakin joku Fortnite keissi mieleen mut sen enempää muistikuvia siitä ei oo. Toki täysin mahdollista et Sonylla oli näppinsä tässäkin mukana, mut sille on kyllä toinenkin peruste olemassa. Ei se kuitenkaan salaisuus oo et Sony ei crossplayta halunnut johonkin väliin, nykysestä tilanteesta en tiedä.
Toki en mä nyt sitä sano etteikö kaikki väitökset (paitsi toi yks) voi pitää paikkaansa, mutta kannattaako uskoa suorilta käsiltä jos todisteita ei ole ja välissä on jotain mitä pystyy todistamaan vääräksi? Omasta mielestä ei välttämättä, mut jokanen toki tekee omat päätöksensä.
Luumfi
