Myydään Samsung SM863a 3.84 TB 2.5" SATA, 2 kpl, Oulu
Richard
Platinum-jäsen
Tuote: Samsung SM863a 3.84 TB
Hinta: 260 e / kpl
Tuote ostettu (mistä ja milloin): eBay 8/2025
Kuitti löytyy (takuu voimassa): Eip, toimivuustakuu
SMART-logit, löytyy alta mut tl:dr n. 350/390 TB kirjoitettu (jos oikein tulkkasin), 6 vuotta käyttötunteja, eli vielä on kestoa jäljellä rutkasti (5600 TBW)
1.
Koodi:
$ sudo smartctl --all /dev/sda
smartctl 7.5 2025-04-30 r5714 [x86_64-linux-6.19.11-1-cachyos] (local build)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Samsung based SSDs
Device Model:     SAMSUNG MZ7LM3T8HMLP-00005
Serial Number:    S2TYNX0K802316
LU WWN Device Id: 5 002538 c40b3c7a9
Firmware Version: GXT5404Q
User Capacity:    3 840 755 982 336 bytes [3,84 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic, zeroed
Device is:        In smartctl database 7.5/5706
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4c
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Apr  9 11:05:00 2026 EEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x02)    Offline data collection activity
                    was completed without error.
                    Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (12000) seconds.
capabilities:              (0x53) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    No Offline surface scan supported.
                    Self-test supported.
                    No Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 200) minutes.
SCT capabilities:            (0x003d)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   089   089   000    Old_age   Always       -       52606
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       57
177 Wear_Leveling_Count     0x0013   098   098   005    Pre-fail  Always       -       107
179 Used_Rsvd_Blk_Cnt_Tot   0x0013   100   100   010    Pre-fail  Always       -       0
180 Unused_Rsvd_Blk_Cnt_Tot 0x0013   100   100   010    Pre-fail  Always       -       13063
181 Program_Fail_Cnt_Total  0x0032   100   100   010    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x0032   100   100   010    Old_age   Always       -       0
183 Runtime_Bad_Block       0x0013   100   100   010    Pre-fail  Always       -       0
184 End-to-End_Error        0x0033   100   100   097    Pre-fail  Always       -       0
187 Uncorrectable_Error_Cnt 0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0032   075   052   000    Old_age   Always       -       25
194 Temperature_Celsius     0x0022   075   052   000    Old_age   Always       -       25 (Min/Max 18/48)
195 ECC_Error_Rate          0x001a   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       0
199 CRC_Error_Count         0x003e   100   100   000    Old_age   Always       -       0
202 Exception_Mode_Status   0x0033   100   100   010    Pre-fail  Always       -       0
235 POR_Recovery_Count      0x0012   099   099   000    Old_age   Always       -       28
241 Total_LBAs_Written      0x0032   099   099   000    Old_age   Always       -       753632354184
242 Total_LBAs_Read         0x0032   099   099   000    Old_age   Always       -       1045783692592
243 SATA_Downshift_Ct       0x0032   100   100   000    Old_age   Always       -       0
244 Thermal_Throttle_St     0x0032   100   100   000    Old_age   Always       -       0
245 Timed_Workld_Media_Wear 0x0032   100   100   000    Old_age   Always       -       65535
246 Timed_Workld_RdWr_Ratio 0x0032   100   100   000    Old_age   Always       -       65535
247 Timed_Workld_Timer      0x0032   100   100   000    Old_age   Always       -       65535
251 NAND_Writes             0x0032   100   100   000    Old_age   Always       -       913031555072
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
  255        0    65535  Read_scanning was completed without error
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
2.
Koodi:
$ sudo smartctl --all /dev/sdb
Serial Number:    S2TYNX0KB07044
LU WWN Device Id: 5 002538 c40bba8fc
Local Time is:    Thu Apr  9 11:07:13 2026 EEST
                    been run.
                    command.
                    power-saving mode.
  9 Power_On_Hours          0x0032   089   089   000    Old_age   Always       -       52767
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       167
177 Wear_Leveling_Count     0x0013   098   098   005    Pre-fail  Always       -       102
180 Unused_Rsvd_Blk_Cnt_Tot 0x0013   100   100   010    Pre-fail  Always       -       13086
190 Airflow_Temperature_Cel 0x0032   072   050   000    Old_age   Always       -       28
194 Temperature_Celsius     0x0022   072   050   000    Old_age   Always       -       28 (Min/Max 19/50)
235 POR_Recovery_Count      0x0012   099   099   000    Old_age   Always       -       31
241 Total_LBAs_Written      0x0032   099   099   000    Old_age   Always       -       705793282858
242 Total_LBAs_Read         0x0032   099   099   000    Old_age   Always       -       1259604046129
251 NAND_Writes             0x0032   100   100   000    Old_age   Always       -       866923681280
No Errors Logged
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     52599         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Suunnitelmien muuttuessa joutavatkin kiertoon, kai näitä joku tarvii.
Paikkakunta (ilmoita myös otsikossa ja tagissa): Oulu
Toimitustapa: Nouto, posti ym.
Maksutapa: Käteinen, MP, tilisiirto jne.
drantik
