Myyty Seagate IronWolf 4TB (3 kpl) - Oulu
  • Keskustelun aloittaja Keskustelun aloittaja muumio
Myytävä tuote: ST4000VN008 (CMR)
Hinta: kaikki kerralla 200€ (+ postituskulut)
Tuote ostettu (mistä ja milloin): Verkkokauppa.com, 2021/09/10
Kuitti löytyy (takuu voimassa): Kyllä, kyllä
Muuta huomioitavaa: Omaan makuun pyörivät pitää liikaa ääntä arkistokäytössä joten suoraan käytöstä kunhan ke/to saapuu korvaavat SSD:t tilalle.
Koodi:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.63-xanmod1] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate IronWolf
Device Model:     ST4000VN008-2DR166
Serial Number:    ZDH9N26N
LU WWN Device Id: 5 000c50 0c97eeee0
Firmware Version: SC60
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5980 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Nov 24 18:13:28 2021 EET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82)    Offline data collection activity
                    was completed without error.
                    Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (  581) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    Offline surface scan supported.
                    Self-test supported.
                    Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   1) minutes.
Extended self-test routine
recommended polling time:      ( 601) minutes.
Conveyance self-test routine
recommended polling time:      (   2) minutes.
SCT capabilities:            (0x50bd)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   100   064   044    Pre-fail  Always       -       1632464
  3 Spin_Up_Time            0x0003   096   096   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       5
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   068   060   045    Pre-fail  Always       -       6090870
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       1798 (31 80 0)
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       5
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   072   069   040    Old_age   Always       -       28 (Min/Max 24/31)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       7
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       27
194 Temperature_Celsius     0x0022   028   040   000    Old_age   Always       -       28 (0 21 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       1797h+42m+01.715s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       2708622799
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1790292998
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Serial Number:    ZDH9N3MN
LU WWN Device Id: 5 000c50 0c97e99cf
Local Time is:    Wed Nov 24 18:13:29 2021 EET
                    been run.
                    command.
                    power-saving mode.
recommended polling time:      ( 613) minutes.
  1 Raw_Read_Error_Rate     0x000f   100   064   044    Pre-fail  Always       -       1622112
  7 Seek_Error_Rate         0x000f   067   060   045    Pre-fail  Always       -       5455345
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       1798 (61 115 0)
190 Airflow_Temperature_Cel 0x0022   072   069   040    Old_age   Always       -       28 (Min/Max 23/31)
194 Temperature_Celsius     0x0022   028   040   000    Old_age   Always       -       28 (0 20 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       1797h+32m+36.625s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       2708619431
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1785230206
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Serial Number:    ZGY969SE
LU WWN Device Id: 5 000c50 0c97da2ba
                    been run.
                    command.
                    power-saving mode.
recommended polling time:      ( 627) minutes.
  1 Raw_Read_Error_Rate     0x000f   100   065   044    Pre-fail  Always       -       1573768
  7 Seek_Error_Rate         0x000f   067   060   045    Pre-fail  Always       -       5420042
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       1798 (94 88 0)
190 Airflow_Temperature_Cel 0x0022   073   069   040    Old_age   Always       -       27 (Min/Max 23/31)
194 Temperature_Celsius     0x0022   027   040   000    Old_age   Always       -       27 (0 20 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       1797h+29m+32.910s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       2708611503
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1795689998
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Ainakaan alkuun EN myy erikseen.
Paikkakunta (ilmoita myös otsikossa): Oulu (Kaakkuri)
Toimitustapa: Nouto, posti
Maksutapa: MobilePay, tilisiirto
Kuva:
Nyt olisi hyvä paikka esittää oma mielipide hinnasta jos tarjouksessani oli jotain vikaa
Tarjouksesi on niin kaukana siitä millä levyistä tällä hetkellä luovun joten en usko että päästään yhteisymmärrykseen kauppasummasta.
Nämä kiinnostaisi... Saisitko kauppakuitista tiedot ja levyistä kuvat?
RetroStack45
