Jimm's
Jimm's PC-Store
- Liittynyt
- 17.10.2016
- Viestejä
- 6 983
Sama lukee Silverstonen nettisivulla, mutta siinä perässä lukee: "Please refer to manual for more details."
Manuaalissa:
"A CPU tower cooler can only be installed when using a SFX PSU with depths of 100mm.
It is required to install slim profile air coolers, i.e. SST-AR12-ARGB or SST-HYD120-ARGB.
For single-tower coolers like SST-AR12-RGB, it’s required to install the fans behind the heatsink fins so that the fins face the cables of the PSU to prevent the PSU cables from interfering with the fan.
For dual-tower coolers like SST-HYD120-ARGB, it is recommended to remove the front fan. The removed fan can be installed in the chassis fan mounts instead."
Linkki manuaaliin lisätty.
