Tässä myös Ukrainan toiminassa olevista ydinreaktoreista kartta:
Saa nähdä mitä vaikuttaa maan sähkönsaantiin kun venäläiset "rauhanturvaajat" ottavat ne "turvattavaksi".
En tiedä miten ajantasaisesti Ukrainan verkko-operaattorin sivut toimivat, mutta ovat ilmeisesti "saarikäytöllä" eli sähköverkko ei ole enää yhteydessä muihin maihin. Verkon toimintaa seuraamalla voi vähän päätellä, onko voimalaitoksiin hyökätty.
EDIT:
On Thursday, February 24, from 7:00 am to 4:20 pm, the level of consumption in the power system decreased from 18.3 GW to 15.8 GW. Currently, the level of consumption begins to increase before the evening peak: as of 17:00 – 16.1 GW. The load of the NPPs is 10.98 GW, TPPs – 3.3 GW, HPPs – 1.39 GW.
Large-scale generation facilities, except Luhanska TPP, are operating in a normal way. Despite the explosion near the power plant and damage to the high-voltage line, currently, there are two power units (№1 and №4) operating at Trypilska TPP with a total load of 203 MW.
13 out of 15 NPP power units are in operation. Only 1 power unit №10 of Luhanska TPP is in emergency repair, due to lack of fuel 2 power units at Trypilska TPP are not operating, as well as one at Kharkiv CHP-5, Kyiv CHP-5, and CHP-6.
Operation of power grids
OHL Trypilska TPP – Novokyivska was damaged. At the same time, Trypilska TPP operates at full capacity (209 MW).
OHL 35 kV Verkhnya Typlovska – Plotyna was disconnected from the distribution network of Luhansk Energy Association LLC at 7 am due to the damage, and OHL 35 kV Raihorodska-Shchastya was disconnected at 8 am.
Dispatch service personnel of DTEK Odesa power grids was evacuated due to explosion.
Dispatch service personnel of Bakhmut regional network service centre of NPC Ukrenergo was evacuated due to hostilities.
RES curtailment
From 8:56 to 13:38 due to the significantly reduced level of consumption in the power system, commands were given to unload RES (via RES curtailment management system) for a total of 897 MW, as well as commands for RES unloading due to operational security reasons. As of 17:00, RES load was 80 MW.
Tulkitse se niin ettei venäläiset ole siihen syyllisiä, Putin ja lähipiirinsä ovat syyllisiä.
Venäläiset voivat kyllä kaataa Putinin ja lähipiirinsä jos haluavat että sota loppuu. Moskovassa (Kreml on siellä) on noin 10 miljoonaa venäläistä joista erittäin suuri osa on aseistautuneita. Sinne vaan hakemaan Putin lyhtypylvääseen joukkovoimalla. Tai sitten haluavat sotaa.
Olen tässä kuunnellut Ison-Britannian parlamentin keskustelua ja siellä tunnutaan ottavan tilanne suuremmalla vakavuudella kuin EU:ssa. Ainakin noiden puheiden perusteella kuulostaa, että venäläistä rahaa ollaan nyt kunnolla hävittämässä Lontoon finanssikeskuksesta. Samoin Ukrainan avustaminen jatkuu monin tavoin, myös aseviennit jatkuvat. Haluaisivat myös sulkea Venäjän SWIFTin ulkopuolelle. Ja käytännössä koko parlamentti on täysin yksimielinen pakotteista.
Tosin siellä on omassa pesässä sitten aika paljon pestävää esimerkiksi noiden kultaisten viisumien haltijoiden osalta.
Briteillä on pitkät perinteet tyrannien vastustamisesta. Ja britit tuntevat vielä häpeää Neville Chamberlainista joka antoi periksi Hitlerille.
Oli käytännössä maailman toinen valtio jossa oli järkevät ihmisoikeudet tunnustava perustuslaki (Magna Carta).
Toki ovat harrastaneet paljon imperialismia, mutta kuitenkin keskimäärin kohtelivat siirtomaitaan melko hyvin ja sivistivät niitä jne ja antoivat niille itsenäisyyden rauhanomaisesti yms.
(toki, kyllähän ne aikoinaan perseili, esim. east indian trade company, sodat napoleonia vastaan, sekä viimeisenä shaahin nostaminen diktaattoriksi Persiassa/Iranissa)
Se on hyvä jos kunnolla tekevät jotain, edelliset pakotteet jäivät todella tuhnuksi kovien puheiden jälkeen.
Ai kato, en huomannutkaan. Kiinnostaa ehkä tietää, miten Ukraina pärjää ja noista kontaktilinjoista ja menetetyistä alueista voi päätellä aika paljon.
Yksi löytyi kuitenkin.
Löytyy varmaan monia muitakin iltasanomien kuvituskuvista lähtien, mutta mikään ei takaa tietojen luotettavuutta, eikä varsinkaan ajantasaisuutta.
Yksi ajatus, mitä tässä mietin, että miltäköhän tuntuu olla venäläinen euroopassa tällä hetkellä?
Yksilöillä ei varmasti ole tekemistä tilanteen kanssa, mutta voin uskoa, että varmaankin tulee hieman "erilaisia" katseita ihmisiltä, kuin ennen.
Tänään itse kohdatessani venäläisen, niin kyllä lähtökohta oli jo se, että mistä tässä voi puhua ja mistä ehdottomasti ei. Ja en todellakaan halua mitään pahaa tavallisille ihmisille, olkoot he mistä vain, mutta luulen, että jonkinlaista ulkopuolisuuden tunnetta saattaa alkaa esiintymään.
Ja venäläiset ovat syyllisiä siihen, että Putin ja hänen lähipiirinsä on vallassa. Ergo, he ovat syyllisiä tähän sotaan. Sen verran tosiaan annan anteeksi, että jokainen venäläinen, joka tekee kaiken käytännössä mahdollisen Putinia vastaan, on tehnyt riittävästi ollakseen syytön.
No tuohon on hyvin helppo ratkaisu. Jos mä olisin venäläinen, niin pistäisin sinikeltaista rekvisiittaa ylleni, niin eiköhän sillä saa sympatiapisteet kerralla kotiin.
Aika lailla mieli maassa varmasti tavallisilla valkovenäläisilläkin. Venäläiset tulivat, pystyttivät tykistöasemat pihalle, alkoivat tulittaa Ukrainaa ja hyökkäsivät rajan yli. Oman maan hallinto vaan taputti käsiään.
Eihän se käytännössä vaatisi kuin sarkofagin osittaisen tuhoamisen ja pommin pudottamisen vanhan sarkofagin sisään, niin likainen pommi ja päästöreitti olisi auki. Mutta en missään nimessä usko, että tuollaista edes miettivät. Veikkaan edelleen vain läpikulkumatkaa tai tukikohdan perustamista alueelle, jolloin ovat moukaroinnilta suojassa.
Eihän tuolta Tshernobylista ole, kuin muutama sata kilometriä Moskovaan. Äkkiseltään katsoin, että ehkä 400-500 km linnuntietä. Ei venäläiset varmasti sitä halua räjäyttää. Muutenkin muistaakseni on pelätty hiljattain, että tuhoutuneeseen reaktoriin katon läpi vuotava sadevesi voi spontaanisti käynnistää hallitsemattoman reaktion uudelleen. Eli kyllähän siellä tavaraa on vielä sisällä.
EDIT: Piti tarkistaa Google mapsin mukaan 690 km Moskovaan. Minskiin vain vähän päälle 300 km.
Mä vähän luulen että Irlantilaiset on vähän erimieltä brittien hyvästä kohtelusta. Veikkaan että sunnuntaihin menessä ukraina on polvillaan.
Kyllä siellä on raporttien mukaan tehty vähän muutakin kuin taputeltu käsiään, Valko-Venäjän armeija ollut mukana hyökkäyksissä ja ilmeisesti spotattu heidän armeijan joukkoja myös rajan toisella puolen.
Varmaan ihan samalta kuin olla jenkki milloin minkäkin hyökkäyssodan aikaan. Kyllä silloinkin moni katsoi kieroon niitä hyökkäyksiä mutta ymmärsi, ettei se Jimmy konttorilla ehkä jakanut näkemyksiä. Eri asia sitten jos sattuu puolustelemaan kovin kotimaansa tekoja mutta sellasita ei kyllä vielä ole tullut vastaan, ei jenkkiä Euroopassa eikä venäläistä Suomessa.
Mitenkähän sitten tuon kokoisen maan etähallinta toimii kun on aika laaja maa ja 44 miljoonaa ihmistä - miinus evakkoon lähteneet.
Täälläkin ollut linkki, uutisia aika reaaliajassa:
ETYJ:n parlamentaarisen yleiskokouksen Suomen valtuuskunnan pj twiittailee Wienin talvikokouksesta.
Latvialta ihan hyvä kuitti.
Ei se Putin siellä ole pyhällä hengellä vallassa pysynyt. Vuosia olisi ollut mahdollisuus valita toisin.
Ja se tekee venäläisistä syyllisiä mihin? Helppo on ratkaisu, käykää tappamassa Putin?
Vähän voisi miettiä mitä olisi itse valmis tekemään ennen kuin edellyttää toisen maan kansalaisilta toimia. Mutta oletan että lentoliput Ukrainaan on tilattu ja blogit voittoisista taisteluista on kohta meidän kaikkien luettavissa.
Ja sinun suomalaisena ei tarvitse tehdä muuta kuin trollata netissä ja olet kansalaisvelvollisuutesi tehnyt?
Täällä testosteronit jyllää ja ollaan valmiita neuvomaan mitä muiden maiden kansalaisten pitäisi tehdä ja tunnutaan tietävän parhaat vaihtoehdot.
Toivottavasti kukaan meistä ei joudu oikeasti kokemaan näitä asioita mitä täällä ehdotellaan.
Esimerkiksi Putinin vastustaminen, onko @taxman tehnyt sitä edes suomessa, saati osoittanut mieltä Venäjällä?
Voidaanko jo puhua 2000-luvun merkittävimmästä tapahtumasta, ainakin Euroopan näkökulmasta? Ei kyllä itseäni esimerkiksi 9/11 ihan näin paljon kohahduttanut.
Saas nähdä, miten tilanne etenee.
Mielenkiintoisia ehdotuksia Jorma Mellinillä maailmalle:
- revoke all certificates given to Russian institutes (financial, energy, other)
- remove Russian CA's from trusted lists (browsers, others)
- revoke DNSSec from .ru
- disable peerings at Russian IXP's
- remove RIPE NCC RPKI service from Russian IP address space
- remove RIPE NCC reverse-DNS for Russian IP address allocations
- remove .ru from root-DNS servers
- disable IP Transit connections to Russian territory
- leak Russian IP address space from multiple locations and blackhole it
- set all ASN's allocated to Russia to bogon lists as false
- disable mobile roaming for Russian mobile operators
Mielenkiintoista nähdä miten jenkit vastaavat kyberhyökkäysrintamalla Venäjälle. Se on kuitenkin pehmeämpi keino kuin sotilaalliset toimenpiteet ja helpompi kiistää myös.
On toki paljon vaadittu, että venäläiset ryhtyisi konkreettisiin toimiin Putinin syrjäyttämiseksi, mutta se ei ole paljon vaadittu, että hemmetti reilusti suurin osa kansasta edes vastustaisi Putinia ideologisella tasolla!!! Sitä voidaan kyllä vaatia, koska ei Venäjä nyt sentään täysin eristyksissä ole ulkomaailmasta vaan esimerkiksi Internet pelaa aika vapaasti, eikä ihmisten ole mikään pakko uskoa Putinin propagandaa. Esimerkiksi kiinalaiset ja pohjois-korealaiset on jo paljon enemmän eristyksissä informaation suhteen ja sikäli syyntakeettomampia.
Internetiä ei pidä liikaa rampauttaa venäjällä koska se on myös kanava jossa putinia vastustavat tahot tiedottavat. Iranin kanssa tässä mokattiin jo pari vuotta sitten, kun hallintoa arvostelevilta tahoilta suljettiin pääsy joillekin jenkkiläisille some-siteille kun kiellettiin niiltä liikenne iraniin tjsp.
Että pitäisi tarkkaan miettiä mitä oikeasti tehdään ettei haitata "vastarintaliikkeen" toimintaa.
Tästä olen samaa mieltä. Siellä on paljon uskovaisia jotka ei kyseenalaista mitään Putinin sanomaa.
Se on totta, mutta tietyille sektoreille nämä haittaavat toimenpiteet voisivat olla ihan toimivia sopivasti listasta poimittuna. Luonnollisesti mediaa ei pidä sensuroida jne.
Mielenosoittajien kiinniottomäärä Venäjällä nousee.. joku tunti sit oli 700, nyt tän perusteella jo 1400
Tämä. Vapaan tiedonkulun rajoittaminen käytännössä poikkeuksetta sata diktaattorien ja häikäilemättömien bullshittaajien laariin.
Ukrainalle aseapua ja kaikkien eurooppalaisten maiden sotavoimien valmius ylös ja budjetit ylös.
Samaa mieltä. Jos tilanne Kremlissä käy joskus tukalaksi, tiedä vaikka itse kytkisivät venäläiset irti internetistä.
Mitenköhän käy muun liikenteen? Jos vastapakotteena Venäjän ilmatila menee kiinni. Finskiltäkin tällä hetkellä 2 Tokion lentoa, Shanghai ja Bangkok menossa Venäjän yllä. Venäjähän siinä häviäisi varmaan tulopuolella, mutta se tuskin Putinia haittaa.
"Suvereeni nettihän" oli jo taannoin Venäjän projekti, en muista testattiinko peräti. Eli maa saatetaan irti Internetisä ja verkko toimii sisäisesti.
Ymmärsin, että noi mainitut asiat koskis nimenomaan venäläisiä sivustoja ja palveluja? edit: no ei. Mut olis tossa toimiviaki juttuja.
Puolassa ja Romaniassa menossa Amerikkalaisilla mielenkiintoinen projekti.
NCHO***
LAGR***
18min jono tällä hetkellä sivulle. Vissiin joku muukin haluaa seurata lentoliikennettä.
Edit. No nyt pari kertaa uudelleen lataamalla sivu aukesi, mutta ei tuo kyllä mitään lentotietoja minulle näytä.
Niin, juuri tämän takia venäjän liiallisesta sulkemisesta internetistä olisi vaan helposti enemmän haittaa kuin hyötyä. Venäläisten yritysten ja hallinnon sivut toimisivat venäläisten omassa verkossa (joka on tiukan hallinnon kontrollin alla), mutta putinia vastustava kansa ei pääsisi organisoitumaan ulkomaisten palvelimien kautta.
Mitä ihmettä nämä selittävät!
"On mahdotonta sanoa, että Tšernobylin ydinvoimala olisi turvallinen venäläisten täysin järjettömien hyökkäysten jälkeen", sanoi kansalian edustaja Mihail Podoljak.
"Tämä on yksi vakavimmista uhista Euroopassa tänään."
Taisteluista Tšernobylissä kertoi aiemmin torstaina Ukrainan presidentti Volodymyr Zelenskyi.
"Venäjä yrittää kaapata Tšernobylin ydinvoimalan. Puolustajamme taistelevat henkensä edestä, jotta vuoden 1986 tregadia ei toistuisi. Raportoin tämän Ruotsin pääministerille. Tämä on sodanjulistus koko Eurooppaa vastaan", Zelenskyi kirjoitti kello viideltä viestipalvelu Twitterissä.
Siis kuka idiootti tuolla näitä kommentteja antaa? Ja hesarin tollo toimittaja vielä kirjoittaa niistä. Tsernobylin ydinvoimala on ollut sammutettuna yli 20 vuotta, ei siellä ole edes polttoaineita reaktoreissa. Paikalla ei ole enää kuin matkailu arvo. Jos Tsernobylin museoon hyökkäys on pahin turvallisuus uhka, niin on ihan hiukan realiteetit kaverilla vinossa.
Hieman naiivisti toivon näkeväni Moskovan kaduilla miljoona sotaa vastustavaa kansalaista perheineen. Ihmismeri istuisi kädet kynkässä ja ympäröisi koko Moskovan keskustan vaatien sodan välitöntä lopettamista ja joukkojen vetämistä Ukrainan alueelta.
Tuommoista väkijoukkoa olisi pamppumiesten paha mennä poistamaan.
Biden puhuu jotain teknologian vientikiellosta, jolla saavat jopa puolet estettyä. Harmi kun ei selittänyt vielä tarkemmin.
USA:n export control säädökset ovat sellaiset että ne voivat estää teknologian viennin jota on kehitetty USA:ssa (tai jopa jos sitä on kehitetty USA:n kansalaisten toimesta, tuosta en ole ihan varma) vaikka sitä varsinaista tuotetta ei valmistettaisi USA:ssa. Etenkin jos kyse on jostain sellaisesta mikä teoreettisesti voi olla dual-use (i.e. käyttää myös sotilaallisesti).
Eli vaikka olisi suomalainen firma niin jos se on kehittänyt osankin jostain teknologiasta USA:ssa niin tuon teknologian viennissä pitää noudattaa USA:n pakotteita.
Tästä sitten voidaan miettiä että kuinka paljon modernia teknologiaa on maailmassa jota ei ole ainakin osittain kehitetty USA:ssa.
Joo, jauhanta Tsernobylistä riittäis jo. Venäjä ei tarvitse likaisia pommeja eikä sellaisen kyhäämistä katsota sen parempana tekona kuin ydinaseen käyttöä.
Joku voisi alkaa koota listaa, miten jokainen suomalainen voisi jokapäiväisessä elämässä boikotoida tuotteita, palveluita tai muita hankintoja, joissa on jokin Venäjä-kytkös. Pienetkin teot merkitsevät isommassa mittakaavassa. Esim. itse en aio enää tankata tai käyttää Teboilin huoltoasemia, koska käsittääkseni kuuluu edelleen venäläisille niiden myymä polttoaine.
Hieman naiivisti toivon näkeväni Moskovan kaduilla miljoona sotaa vastustavaa kansalaista perheineen. Ihmismeri istuisi kädet kynkässä ja ympäröisi koko Moskovan keskustan vaatien sodan välitöntä lopettamista ja joukkojen vetämistä Ukrainan alueeltä.
Putinilla on 400,000 äijän kansalliskaarti, ja jos oletetaan, että ne olisi uskollisia ja tekevät kuten käsketään, niin kylläpä saattaisi miljoonankin siviilin pamputus onnistua... :smoke:
Arppam
