Windows 10 keskustelu
Hae-välilehti, aukeaa kun klikkaa sitä hakukenttää -> Edelliset haut -> Tyhjennä hakuhistoria?
Kiitoksia neuvosta, näin ne tyhjee helposti. Mä meinasinkin, et on oltava helpompikin tapa tyhjentää hakuhistoria, kuin poistaa niitä yksitellen.
Itse ajattelin elää veitsen terällä ja en aio ottaa backuppeja tai mitenkään muutenkaan valmistautua päivityksiin vaan asennan ne heti kun ne vaan on saatavilla omille koneille :cool::cigar:.
Rohkeaa vai mitä :D?
Nyt tuli KB890830 + KB4088785, ei näkynyt vielä KB4088776
March 13, 2018 - KB4088776 (OS Build 16299.309)
Applies to: Windows 10 version 1709
Improvements and fixes
This update includes quality improvements. No new operating system features are being introduced in this update. Key changes include:
  • Addresses issue where Internet Explorer stops working when using F12-based developer tools.
  • Addresses issue with printing XML documents with Internet Explorer and Microsoft Edge.
  • Updates legacy Document Mode cell visibility in Internet Explorer.
  • Addresses issue with pinch and zoom gestures on some hardware in Internet Explorer.
  • Addresses issue where Internet Explorer is unresponsive in certain scenarios when a Browser Helper Object is installed.
  • Addresses issue to prevent media and other applications from becoming unresponsive or failing when upgrading graphics drivers.
  • Addresses issue where customers receive "Check your account, you don't own this content” errors when attempting to play or install owned content. This issue can also result in customers getting kicked out of a game in the middle of play.
  • Addresses issue where, after installing KB4056892,KB4073291, KB4058258, KB4077675, or KB4074588 on a server, you may not be able to access SMB shared files in directory junction points or volume mount points hosted on that server. The error is "ERROR_INVALID_REPARSE_DATA”. As a result, editing some group policies using GPMC or AGPM 4.0 may fail with the error "The data present in the reparse point buffer is invalid. (Exception from HRESULT: 0x80071128)".
  • Addresses issue where an AD FS server issue causes the WID AD FS database to become unusable after a restart. This might prevent the AD FS service from starting.
  • Addresses issue where, after installing KB4090913, the Mixed Reality Portal may fail to initialize. This results in an “SXXXXXXX-X” error or a “We couldn’t download the Windows Mixed Reality Software” message may appear after the software is successfully downloaded.
  • Lifts the Anti-Virus (AV) compatibility check to expand the number of Windows 10 devices that are offered cumulative Windows security updates. This includes cumulative Spectre and Meltdown protections for 32-Bit (x86) and 64-Bit (x64) versions of Windows, except the KB4078130 update that was offered to disable mitigation against Spectre Variant 2.
  • Addresses issue that only affects some versions of antivirus software and only applies to computers on which the antivirus ISV updated the ALLOW REGKEY.
  • Security updates to Internet Explorer, Microsoft Edge, Microsoft Scripting Engine, Windows Desktop Bridge, Windows Kernel, Windows Shell, Windows MSXML, Device Guard, Windows Hyper-V, Windows Installer, and the Microsoft Scripting Engine.
Täällä näky lähtevän lataamaan koko settiä, mukaanlukien tuo KB4088776. Pitikös tässä päivityksessä olla jotain ihmeellistä, kun täällä sitä niin on odoteltu? :D
Sehän se Cumulative update on tälle maaliskuulle, että sehän niitä korjauksia tekee.
Ei asennu millään tuo Kumulatiivinen päivitys Windows 10 Version 1709 x64 -pohjaisille järjestelmille (KB4088776).
Asentaa 35% tilaan asti -> hyppää 100% ja sitten Asennus epäonnistui ‎14.‎3.‎2018 - 0x80092004. Kokeiltu myös asentaa erillisellä asennustiedostolla, eipä ei. Ei löydy kuukkelilla muilla olleen tällaista ongelmaa.
Antaa sitten olla. Laitoin vain tänne, jotta jos jollain muulla on ongelmia, niin tietää että muillakin on. Yeah.
Olen kahta eri Kymppimyllyä käytellyt tänään ja toiseen tuo päivitys ilmeisesti ei ns. ygöisellä asentunut, vaan Update historyyn tuli ekana Failed to install ja errori 0x8024200d, mutta sitten kuitenkin täsmälleen sama KB4088776 olikin asentunut eli update Successfully installed. Muistaakseni tässä samaisessa koneessa siinä päivitettäessä mukamas Adobe Flash Playerin päivitys kusi, mutta Update historyssa sen failauksesta ei ole mitään merkintää ja se on successfully installed.
Tiedä näistä sitten.
Monesti joku tietty päivitys ei vaan millään asennu, mutta sitten seuraavat asentuvat normaalisti. Hyvä puoli kumulatiivisissa päivityksissa on juuri se että ne sisältävät kaikki edellisten korjaukset. Itsellä ei mikään kymppiä käyttävä pöytäkone ole kussut näitä päivityksiä mutta läppärissä kävi monta kertaa juuri noin kun siinä oli vielä vanhempi 1607- build.
No, itselläni se on kuitenkin vain epäonnistunut.
Tämä kone taas on pöytäkone, jos sillä nyt on mitään merkitystä. Läppärillä en ole jaksanut kokeilla, kun on ihan varakone ja käyttämättömänä (vihaan läppäreitä) jäänyt useampikin päivitys tekemättä.
Mutta ei suuria ongelmia päivitysten asentumisessa ole aikaisemmin ollut. Itse päivitys on saattanut joskus, nykyään harvemmin, ongelmia aiheuttaa. Mutta ne ovat sitten olleetkin ihan yleisiä ja muillakin esiintyneitä asioita. Tätä omaa KB4088776 0x80092004 -ongelmaa, en ole löytänyt googlettamalla (eilen ainakaan. Edit. tänään yksi osuma.).
Sun virhekoodi on luultavasti sertifikaattien asennuksesta tuleva. Onhan kello oikeassa ajassa ja päivämäärässä? Se ei asenna certiä jos se on kellon mukaan vanhentunu tai liian kaukana tulevaisuudessa.
On. Aina. :)
Aika rohkee väite. Sulla on kuitenki windows 10 käytössä... Jos boottaa esim. usbilta linuxiin niin win10 ei osaa säätää kelloa oikeaan aikaan ennenkuin käy kellon asetuksista ottamasta automaattisen päivityksen pois päältä ja takaisin päälle. Mulla on pysynyt kello väärässä ajassa monta tuntia ellen ole tuota automaattisen päivityksen togglaamista tehnyt.
No minä puhunkin omasta kokemuksestani ja ympäristöstäni. :) Minä en boottaile USB:ltä tai muultakaan Linuxiin, käyttelen sen vähän mitä kerran 10 vuodessa kokeilen niin VirtualBoxissa. :)
Tosin jos joudun jostain ihmeen syystä käyttämään ShadowProtectin Linux-pohjaista palautusmediaa, niin tiedän kokemusta olla erityisen tarkkana aikojen kanssa, niin itse palautuksessa (aika aina väärässä siellä Linux-pohjaisessa ilman asettelua) ja palautuksen jälkeen Windowsissa. Mutta yleensä aina Windows PE -pohjainen palautus toimii (toki tällöinkin aika on hyvä tarkistaa).
En sammuta/käynnistä konetta muutenkaan kuin ani harvoin, esim. päivitysten yhteydessä, vaan käytän lepotilaa. Ja, kaipa se tärkein, tarkistan usein aikaa oikeasta alanurkasta, koska siitä tiedän milloin lähteä vaikkapa tapaamiseen tai soittaa jonnekin tms. Ovat ne toki kalenterissakin, lahopää kuin olen, mutta joo.
Omassa käytössäni, on käytännössä aina aika oikeassa. Ugh. :happy:
Ei asennu myöskään täällä työkoneessa. I3-4130T
"Viimeisin epäonnistunut asennusyritys ‎15.‎3.‎2018 – 0x80092004"
@Jamo66 Kiitos. Eli kyllä näitä sitten on.
Itsellä W10 Pro x64 jos sillä on merkitystä. Varmaan suurella osalla on.
Itsellä läppärin (UX430UQ) SD-muistikortinlukija lakkasi toimimasta (Windows ei enää tunnista ollenkaan) uusimman kumulatiivisen päivityksen jälkeen. Itse päivitys onnistui tällä kertaa ekalla yrittämällä.
Tota päivitysvirhettä teki yhdellä koneella koko ajan. Koitti vaan asentaa mutta ei mennyt sisään vaikka mitä teki. Ratlaisuna toimi, että Windows upgrade toolilla w10 uusiksi sisään, ilman että tuhoaa datoja. Sen jälkeen taas toiminut päivitykset.
Win 10 preview lakkasi käynnistymästä, en tiedä oliko yöllä päivityksiä tullut.
Tulee vain ensiksi sininen ruutu : ( "Windows insider -esiversio havaitsi ongelman jne.... , sitten boottaa ja sama ilmoitus vihreällä pohjalla ja siihen jää.
Saakohan tuota enää pystyyn? Vissiin bootatessa ei ole enää näppäintä jolla koneen saisi vikasietotilaan?
Ja sitten jos ei saa:
Minulla on vanhassa
nuhapumpussa win 7 lisenssi, ja aikanaan siihen tein sen "varauksen" ilmaiselle kympille.
Jos nyt joudun tuohon parempaan koneeseen asentamaan seiskan, niin sitä ei varmaan ilmaiseksi saa päivitettyä kympiksi enää? Jos ei, niin mistähän saa halvimmalla äkkiä kympin?
Ja jos jostai saisin vaikka usb tikulle win10 täyden tai preview -version, niin saakohan sen asennettua tuohon päälle niin, ettei tiedot katoa, vai täytyyköhän minun käyttää kiintolevyä toisessa koneessa että saa esim pelien savegamet talteen?
Lyhyt kysymys. Nykyisessä pöytäkoneessa Windows 10 Pro aktivoituna. Alunperin ollut ilmeisesti 7, lisenssitarrasta ei saa selvää. Koneessa yksi HDD ja tarkoitus olisi korvata tämä SSD:llä. Voinko ladata täältä asennuspaketti USB-tikulle, asentaa Windowsin tyhjälle SSD:lle (asennus ilman product keytä) ja todeta kuinka käyttis aktivoituu nätisti ilman mitään kikkoja?
EDIT: Täältä siis: Lataa Windows 10
Jos olet liittänyt aktivoidun paikallisen käyttäjätilisi Microsoft-tiliin niin silloin W10 haistelee sen lisenssin netistä automaattisesti kun kirjaudut sillä Microsoft-tilillä ja aktivoi wintoosan. Muuten tarvitset sen lisenssikoodin.
Ei tarvi jos rauta ei muutu. Se lisenssi on sidottu rautaan tai ms tiliin. Kovoa ei lasketa rautamuutoksiin.
Puhdas uusi levy kyseessä kyllä. Ja haluaisin ns. fresh installin enkä edes yrittää kloonata nykyistä levyä SSD:lle. Hankin koneen käytettynä, johon oli juuri asennettu käyttis. Takuutahan ei ole miten se oli tehty ja kuinka legit on. Verkossa kone ei ole käynyt ollenkaan. Ehkäpä nappaan siihen verkon kiinni ja liitän se omiin tunnuksiin. Sen jälkeen SSD kiinni ja sinne asennus jonka jälkeen microsoftin tiliin kiinni. Kaippa se sillä menee.
Ja olikos niin, että asennus ilman product keytä?
Jep, yhdistät sen koneen nettiin, liität tilin MS-tiliin jolloin se automaattisesti siirtää sen käytetyn lisenssin MS:n servereille, sitten tuuppaat SSD:n sisään ja asennat W10 ilman lisenssiä ja kirjaudut sille MS tilille kun netti on päällä. Siinä se.
Juu, mutta jos siitä lisenssikoodista ei saa selvää ja windowsia ollaan asentamassa puhtaana uudelle levylle?
Mitä sillä seiskan koodilla tekee jos kympin oikeus on microsoftin palvelumilla sidottu laitteiston sarjanumeroihin. Tarkemmin emo on se tärkein osa.
Kiitos! Levy laitettu tilaukseen. Viikko-pari varmaan menee ennen kuin pääsee tositoimiin. Laitan sitten tietoa miten kävi.
Jos meinaat että uusi puhdas windows aktivoituu ilman lisenssikoodia ihan vaan siksi että käytössä on emo jota on käytetty windowsin aktivoimiseen paikallista tiliä käyttäen, niin se on kyllä minulle uutta tietoa.
Kyllä se vaan niin toimii. Oon varmaan lähemmäs sata konetta asentanu uusiks tuolla metodilla.
Katos vaan, sittenhän se on fiksumpi kuin uskalsin luottaa. Siinä tapauksessa @zeniitti ei tarvitse liitellä paikallistiliä MS tiliin aktivoinnin takia, mutta suojaisi se lisenssin emolevyn vaihdon varalta.
Heh, Windows Update Troubleshooter korjasi vian poistamalla päivityksen saatavilta. Käyhän se näinkin. :tup:
Mites se nyt on tossa remote desktopissa, mulla on pöytäkoneessa ja surface pro 4:ssä windows 10 home. Pystynkö käyttämään surfacella remotena pöytäkoneelta lightroomia niin, että kynä toimii täysin?
Deskarille pitää saada W10 Pro, muuten et voi muodostaa yhteyttä... jos siis meinasit Windowsin omaa etätyöpöytää käytellä. Kynän toiminnasta en osaa sanoa.
Joo, hitto kun surfacessa onkin 10 pro mutta se on juuri väärä :D No pitänee hankkia tähän deskariin pro lisenssi kun ei noita varmaan voi vaihtaakaan päittäin...
Googlella kyllä löytää tarvittavat regfixit rdp aktivointiin.
Niin vähän arvelin että vaikka "virallisesti" surfacen OEM lisenssiä ei voisi aktivoida toisella koneella niin käytännössä se kuitenki onnistuu.
Onko tuo rekisterin editointi sen takia että saa sieltä vanhan avaimen siivottua?
Ilmeisesti avaimen deaktivointi onnistuu kuitenkin ihan CMD:stä
How to deactivate Windows 10 and change the product key
E: aivan siis tarkoitit että rekisteriä puukottamalla saa RDP toimimaan myös homella
Juuri tuota edittiäsi.
Omassa virtuaali-Windowsissa tähän KB4088776-ongelmaan auttoi seuraava:
lataa päivityspaketti manuaalisesti
netti pois päältä (itse disabloin verkkokortin)
net stop wuauserv
c:\windows\SoftwareDistribution\Download-kansio tyhjäksi
net start wuauserv
--> Windows powershell käyntiin admin-oikeuksin
--> päivitys shellin kautta sisään --> boot --> netti takas päälle
Voi olla, että tuolla Download-kansion tyhjäämisellä ei ole asian kanssa mitään tekemistä, mutta laitoin sen kuitenkin tähän kun itse niin tein.
Yhdessä koneessa missä ei automaattisesti tippunut tuo uusin update sitten millään, niin latasin vain tämän erikseen ja ajoin normaaliin tapaan sen siitä sisään. Tätä ennen kokeilin tyhjätä pysäyttämällä palvelut tuon SoftwareDistribution mutta tämä ei auttanut, toki laitoin sen jälkeen palvelut päälle ja annoin updaten hakea kamat uudelleen.
Outoja ongelmia kyllä tullut näissä viimeisimmässä päivityksissä ja ihan randomisti vielä tulee vastaan eri koneilla.
flawice
