Xbox Series X + Series S -keskusteluketju
Hyvää settiä vaikutti olevan. :tup: Etenkin uusien IP:den määrä ilahdutti, ettei sieltä ole tulossa vain jatko-osaa jatko-osan päälle. Sitten vain odotellaan sitä MS:n 1st party-esittelyä, joka taisi olla kesä-heinäkuun tienoilla.
Peruuntuneiden E3-messujen aikoihin monella firmalla (EA, Activision, Rockstar yms) on sitten varmaan monia omia striimejä tai julkaisevat videoita, joissa esittelevät tulossa olevia pelejä.
Tuossa vielä mielenkiintoinen haastattelu: The big interview: Xbox Series X development chief Jason Ronald on power, price and that new boot screen
Hinnasta:
Everything you've talked about makes the Xbox Series X sound incredibly powerful for a console, but I wince when I think about how much it's going to cost. What should people expect?
Jason Ronald:
I think Phil [Spencer]'s been pretty transparent. We designed the system with a price point in mind. We're confident in the system we've designed, but at the same time, we're going to be agile on price.
Tehoista:
From your perspective, how important is the teraflop debate, which I assume you're enjoying at the moment?
Jason Ronald:
To me, it's about the end-to-end performance of the system. It's not one aspect versus another. What was critically important to us was sustained levels of performance, unlike anything you've seen before. And we designed the system to be a well balanced system with no bottlenecks or no compromises in any area... whether it's the CPU performance or the GPU performance - we were at the upper bounds of what was capable with a traditional rotational drive, so we knew we had to invest in things like SSD level IO performance. We designed the Xbox velocity architecture to be the ultimate solution for asset streaming.
449-499€ konsoli sieltä taitaa olla tulossa ulos tuon ensimmäisen kommentin perusteella, arvaan ma.
Medium ja Scorn ilmeisesti Series X(/PC) -excluja. Onko timed excluja vai todellisia, aika näyttää. Aika näyttää myös julkastaanko Scorni oikeasti ikinä :lol:
Hyvältä näyttää jos ei ole kalamiehen puheita.
Tuossa tippuu ainakin itselleni merkittävin pc hyöty jos kaikki pelit 60fps.
Faktuaalisesti tuo ei ole vale edes silloin vaikka peli olisi 30fps peli. Nimittäin output on silti HDMI 4k/60Hz oli framerate mikä tahansa. Kuten on aina ollut.
Melkein kannattaa markkinointimies-suodattimen kautta vetää kyllä nuo Greenbergin jutut sitten. Viime genissä oli kaikki pelit 4k ymsyms.
Tai siis nykyisessä genissä ;) Ja siinäkin vain tehomalleilla eli Xbox One X ja PS4 Pro. Perusmallit oli sitten mukamas FullHD konsoleita. Tosiasiassahan millään konsolilla ei kuin jotkin pelit päässyt lupauksiin.
Mikä tämä fetissi on edes saada jotain gameplaytä? Sama kuin Nvidia julkaisisi videon "RTX 3080 Ti gameplay". Samoja pelejä kuin ennenkin mutta inasen paremmilla grafiikoilla ja ehkä paremmalla fps:llä. Tulee sitten kun tulee ja ostetaan jos ostetaan. Itse ainakin miellän uuden konsolin vain rautapäivitykseksi. Tänä vuonna ostoslistalla Series X ja RTX 3080 Ti.
No jos kerran hypetetään tapahtumaa gameplaylla, niin luulisihan sitä sitten olevan tarjolla? Vai eikö Mikkiksellä ymmärretä näiden kahden eroa? Samalla olisi voinut esitellä näiden high profile 3rd party pelien Series X -versioita, niin olisi saatu samalla painetta kilpailijan päätyyn, mutta kun ei. Nyt oli tyytyminen pienempien kehittäjien tekeleisiin, joissa ainakin itselleni jäi epäselväksi mikä tämä Series X:n tuoma etu nyt oikein oli, kun ei se varsinaisena visuaalisena silmäkarkkina ilmennyt. Uutta IP:tä sentään oli tarjolla, mutta kovin jäi esitys torsoksi muilta osin.
Kommentit tämän osalta hupaisaa luettavaa. No Greenberg ehti jo pyydellä asiaa anteeksi:
Gameplay kun kertoo itse pelistä paljon enemmän kuin itse traileri, ei luulisi tulevan uutisena. Uusi konsoli parhaassa tapauksessa tarjoaakin uudenlaista tapaa pelaamiseen, ellei sitten tyydytä vain sisuskalujen päivitykseen modernimmaksi.
Pelkäänpä pahoin että tuossa tarkoitetaan 120 Hz outputtia, ei olisi ensimmäinen kerta kun Greenberg sekoilee teknisissä yksityiskohdissa. Silmämääräisesti katsottuna Second Extinction näytti 30 fps peliltä, sen verran maltillista oli liike pelin osalta + aimo kasa motion blurria tätä peittämään.
Tämä on kyllä hieno juttu, että 3rd partyt lähtevät kehittämään pelejä suoraan Series X:lle. Näin saadaan konsolin tehot kunnolla käyttöön ilman cross-gen kehityksen kompromisseja.
Tarkoitin siis ylipäätään näitä että esitellään uuden raudan gameplaytä. Sitä samaa se on ollut viimeiset 20 vuotta mutta grafiikat on parantunut vähitellen. Kai tämä on PC-puolelta tulevan ajatusmaailma kun PC:llä rauta päivittyy vuosittain eikä 7-10 vuoden välein.
Joo, niin taidetaan tarkoittaa kun asiaa vähän enemmän miettii. Eli 60hz/120hz output mahdollisuudet ja fps on sitten mitä on riippuen pelistä ja tilanteesta. Vihervuorella termit ja/tai tietämys sekaisin.
Tuolla kattauksella olisi kyllä tuon eventin voinut jättää pitämättä. En usko, että tuosta nyt hyötyivät em. pelien kehittäjät saatika MS.
Reactions: MAD
Kyllä indie-kehittäjät tuosta varmasti hyötyivät, kun saivat paistatella uutisten valossa ilman muita isoja poikia. Microsoft hoiti tämän huonosti XSX:n kannalta ja Ubisoftikin meni möhlimään, mutta MS:llä on se "oikea" esitys tulossa heinäkuussa. Esityksen mielenkiintoisin tieto itselleni oli, että osa kehittäjistä ei halua roikottaa Xbox Onea enää mukanaan ja täten tekevät pelejä pelkästään seuraavan sukupolven konsoleille ja PC:lle, mikä on hyvin tervetullutta.
Luulenpa että suurin osa kehittäjistä ei halua enää kehittää pelejä nykygenille sen tuomien rajoitusten vuoksi, mutta julkaisija haluaa varmistaa selustansa saamalla pelin mahdollisimman monelle alustalle. EA:han ilmoitti ainoastaan next gen -konsoleille (+PC) tulevan BF6:n tulevan vasta ensi vuonna juuri tästä syystä.
Ei tuossa eventissä itsessään ollut mitään vikaa, se oli vain väärin markkinoitu suurelle yleisölle. En myöskään ymmärrä miksi tuossa piti lähteä keulimaan tuolla "optimised for Series X" -sloganilla, kun pelit eivät olleet mitään varsinaisesti mitään silmäkarkkia paria poikkeusta lukuunottamatta.
Itse en alkuunkan ymmärrä tuota hirveää ulinaa väärästä markkinoinnista. Eikös sitä luvattu, Gameplayta, Trailereita ja sneak peakkeja ja mitä saatiin... Gameplayta, trailereita ja sneak peakkeja... Toki oikeaa gamaplayta oli todella vähän, mutta itselle se ei ollut mikään yllätys. Jos luvataan esitellä iso joukko pelejä lyhyessä striimissä, niin on sanomattakin selvää, että ei siellä tulla näkemään mitään kovin pitkiä asiaan syventyviä gameplay videoita.
Ei missään luvattu, että juuri esim. AC valhallasta näytettäisiin gameplayta tai jos luvattiin, niin se oli Ubisoftin sanomaa ja heidän kämmi.
Toki ihmisillä on tapana innostua liikaa ja kuvitella asioita, mitä ei olla luvattu.
Eihän tuo tilaisuus nyt tosiaan mikään tajunnanräjäyttävä kokemus todellakaan ollut, vaikkakin muutama ihan mielenkiintoinen peli sieltä esiin nousikin.
Ongelmahan oli juuri siinä, että eventissä hehkuttiin isolla olevan juuri sitä next gen -gameplayta, mikä jäi käytännössä kokonaan puuttumaan. Ei liene sattumaa että Greenberg joutui pahoittelemaan aiempia hehkutuksiaan:
Ihme juttu että näinkin ilmiselvästä asiasta pitää alkaa vänkäämään.
edit: The Ascentista saatavilla ihan sitä tapetilla ollut gameplaytakin IGN:n toimesta:
Hyvältä näyttää alphaksi, vahvat Alienation vibat tulee tästä. :thumbsup:
Juu, pelit voivat pyöriä 0-9999 fps aivan kuten nykyisessäkin sukupolvessa. Mutta vaikka Xbox One X:llä pelo pyörisi 120fps niin konsoli ulostaa kuvaa 60hz. Eli hyöty frameista jää pienempään ohjausvasteeseen.
Series X voi ulostaa kuvaa 120hz eikä sillä ole mitään tekemistä fps:n kanssa, peli voi renderöidä 5fps ja silti konsoli lähettää sitä 4K120hz kuvaa tukevaan telkkariin.
Pointti oli että tuo Greenberg ei tiedä mistä puhuu.
Tuota noin, kannattaakohan alkaa pätemään jos faktat ei ole hallussa..? Xbox One X tukee 120hz tilaa, on tukenut jo toukokuusta 2018 alkaen.
Ok, olin lukenut vanhan artikkelin tuohon liittyen. Ei kuitenkaan vaikuta mitenkään viestini pointtiin.
Niin siis esityksen anti olikin karrikoiden läjä cross-gen pelejä, yksi kickstarter peli vuodelta 2014 (Scorn), Nätti yhden kehittäjän 5 € FPS (Bright Memory: Infinite) ja se viimeinen jäljelle jäävä ja n. ainoa mielenkiintoinen pelikin tulee PC Gamepassillekin (The Medium).
Ei nyt varsinaisesti mitään, mikä saisi vetämään ostohousuja XsX:n suhteen jalkaan?
Onko vika minun koneessani, mutta onko tuo peli 30fps?
Itse pitäisin todellisena rimanalituksena jos joku uuden genin vehkeille tulevista peleistä olisi 30fps. Ne ei nyt vaan enää kuulu tälle vuosikymmenelle.
Aika luottavaisin mielin voi olla että parhaimman näköiset pelit seuraavalla genillä tulevat olemaan 30fps pelit. Faktahan on että karkkia saadaan tuplasti lisää vs. 60fps tai nelinkertaisesti vs 120fps.
Oli kyllä tuo "gameplay" aika vitsi. Siitä kun joku täällä huutelee, et miksi halutaan nähdä gameplayta, niin onhan se nyt hienoa nähdä miten pelit tuolla oikeasti toimii. Valhallan gameplay olisi ihan hyvin voinut olla jotain esirendattua pätkää, kuten loputkin "gameplayt", joissa luki "expected performance on series x" tai jotain siellä alakulmassa. Siitä on oikea konsoli ja oikea peli kaukana, kun joku rendailee gameplayta kasaan 2x tehoisella PC:llä. Toivottavasti tulisi aitoa pelikuvaa, niin näkee onko screen tearing edelleen samanlaista ja onko se 30fps lähinnä targetti ja oikeasti dipataan jonnekin 20 pintaan. Toivottavasti ei.
Ai onko jossain konsolipelissä screen tearingia jopa? Ei ole itsellä tullut vielä eteen missään. Pelit toimii sitten sillain kuin toimii. Eipä se mitään tule muuttamaan. Promomateriaali myös on aina tehty sellaiseksi että kaikki näytetään paremmassa valossa joten ei niistä ole mitään iloa todellisen käytön arviointiin.
Vitsiksi meni tuo esitys. Tässä vaiheessa jo toivoisi näkevänsä sitä aitoa pelikuvaa kun puolisen vuotta on aikaa laitteen julkaisuun. Toivotaan nyt, että ensikuussa olisi jotain oikeaa esiteltävää vaikka odotukset eivät ole korkealla senkään suhteen.
On sitä joissakin peleissä. Digital Foundryn videoissa esittelevät jos niitä on. Tässä yksi esimerkki kohdassa 11:48
Ja mielestäni gameplay on vähemmän kuin esirendattu promomateriaali. Se on aitoa kuvaa siitä, mihin konsoli kykenee. Nyt ei sellaista nähty? Eli gameplay reveal on vähän sama jos sanottaisiin et paljastetaan uusi Octavia ja sen tilalla näytettäisi konseptikuva jostain ratista ja todettaisi "simply clever".
Microsoft myöntää mokanneensa viime viikon Xbox Series X:n pelitarjontaa esitelleen Inside Xbox -lähetyksen kanssa.
Tilaisuuden kerrottiin etukäteen esittelevän pelikuvaa esimerkiksi äskettäin paljastetusta Assassin's Creed Valhallasta, mutta lopulta varsinaista pelikuvaa nähtiin trailerien joukossa vain vähän. Tapahtuman anti saikin varsin kriittisen vastaanoton seuraavan konsolisukupolven pelikuvaa odottaneilta faneilta. Xbox-markkinoinnista vastaava pomo Aaron Greenberg on kommentoinut tapahtumaa twiitissään, jossa hän kertoo yhtiön asettaneen selvästi virheellisiä odotuksia tilaisuuden varalle.
Kesäkuussako se uusi esittely oli?
Luotatko todella siihen että se video joka julkaistaan gameplaytä esittelemään on täysin puhtaasti tuotantokonsolilla tuotantoversiolla pyöritettyä ilman mitään valikointia että näyttää parhaalta? Sanoisin että aika sinisilmäistä. Devausboxilla näppärä vaikka kuvata nuo kun niissä on yleensä enemmän tehoa kuin retail konsolissa.
Nyt ei nähty edes devausboxilla kuvattua videota. En odota aina gameplaylta 100% samanlaista hengentuotosta, mikä nähtiin mm. Watch_Dogsinkin tapauksessa, mutta nyt ei nähty yhtään mitään. Siinä on kuitenkin ero. Mielestäni koko Microsoftin esitys oli turha, koska siinä juuri painotettiin GAMEPLAY videoita ja saatiin esirendattuja kohtauksia PC:llä. Tämä tässä kismittää. Eikä mua kiinnosta selitykset jälkikäteen, jos kerta edes sitä devausboksin tai vaikka PC:n gameplaytakaan ei nähty, vaan ainoastaan jotain jonka linkki koko Series X:n olemassaoloon on nollan ja mitättömän välimaastossa.
Kovat on paineet onnistua seuraavassa tapahtumassa, Halo pelikuvaa saa vähintään tulla.
Watch dogs julkistettiin 2012 ja konsolit tuli yli vuotta myöhemmin. On myös huomattavaa että ei ne pelit sen paremmalta näytä yleensä näytä vaikka kuinka kovalla raudalla pyöritellään esim. medium -> ultra asetusten ero on usein ihan marginaalinen, pois lukien tekstruurit ja lodit, jotka yleensä voidaan pitää niin sanotusti tapissa kuhan vain rammia riittää ja occlusion culling yms. vastaava toimii hyvin.
Mä sain käsityksen, että Bright memory infinite olisi ollut devaajan pelaamaa materiaalia.
Joskus jonnena noita tapahtumia vielä jaksoi katsoa. Ei peleissä ole juuri mitään kehitystä tapahtunut kohta 15 vuoteen niin ihan sama :) Kyllä sen itseä kiinnostavan pelin nimen sitten jossain näkee kun on julkaisu lähellä tai tullut myyntiin.
Eli aluksi sillä ei ole väliä, että gameplay tapahtumassa ei ole gameplayta ja lopuksi ne oli kuitenkin suunnattu Jonneille, niin ihana sama? Ilmeisesti kuitenkin katsoit tämänkin, vaikkei juuri mitään kehitystä olekaan tapahtunut 15 vuoteen peliskenessä. Pointti oli kuitenkin siinä, että se mitä luvattiin ja se mitä näytettiin oli kaksi eri asiaa.
En katsonut koska ei kiinnosta. Halo Infinite ja uusi Forza sieltä sitten joskus tulee ja ostelen. En tarvitse siihen mitään videoita. En myöskään sanonut että suunnattu jonneille vaan että itse olen noita jaksanut viimeksi siinä iässä seurata.
Eurogamer Portugal: Assassin's Creed Valhalla vai correr no mínimo a 30 FPS na Xbox Series X
Ubisoft responded to Portuguese Eurogame and said that Valhalla will run at minimum 30FPS in 4K. We don't know if there will be other modes yet.
:geek::geek::geek:
Ehkä se oli vain hyvä, ettei sitä gameplay kuvaa tullut..
Jarppab
