ZTE MF286 -kokemuksia
nonii tuli hommattua. Selittäkääpäs miks saan parhaat nopeudet lukituksella 800, enkä 1800+800? Jos lukitsen 1800, niin saan melkein yhtähyvät lukemat kuin 800:lla, mut noiden yhdistelmä on hitain. DNA
Hi,
I am writing in English because I am from Croatia. I am using ZTE MF286 with our national provider (Tele2) and I tried to flash a new firmware from DNA ( https://www.dna.fi/documents/753910/853450/DL_MF286_DNA_EN_EUV1.00.00.zip/4cf4f785-6c32-01f6 -7b80-28547954b072). The flashing got to 5% and then returned the error that version is not supported (see below).
Afterwards I did a reset on my router. I can connect to the router and everything seems like before but it won't connect to any mobile network. I tried two different SIM cards and when I press connect it tries and after a few seconds just says failed. Both of the SIM cards worked without any problem before. The web interface looks exactly as before but I can't connect to the network (it scans the provider networks but won't connect).
So I suppose some part of the DNA firmware got flashed and that is the problem, it messed up something.
I need your help in trying to flash some new firmware, does somebody know the procedure?
I also have telnet (shell) access to the MF286 router so I can post any configuration needed. Or I can change any configuration through the shell but I need to know what to change? Can I force the router to accept the firmware from DNA with changing some of the parameters in the shell?
Thanks!
: Sblush:
I think you have tied to flash MF286 f/w to MF286A model (srtiker on the bottom) and it dosent work !
Latest DNA f/w (only OTA) is ZTE_DNA_MF286_B16 for upgrade device must be in router mode. (not bridged)
MF286(A) firmware
Try hard reset with push button >30s
Hi! That pop-up tells that the firmware you are installing is not compatible with your device.
It asks you to do the firmware update again - should the problem persist, see the usermanual and update releasenotes.
Usually there are some variations to radio domain regulations per country. This usually affects LTE channels that are in place per country. So lets say your operators have support for 800MHz, 1800MHz 2600MHz etc. But the actual band widths per these different frequencies varies by the way operators want to provide their services and allso by the per country agreements how every operator can operate.
Most likely, there is difference between Finland radiodomain sharing model and the same model in place at Croatia. My reference is this; meaby google translater could help you more with content of this page.
But see how Band 3 and Band 4 are both on same frequency - yet their band width is different. Upload and download channels are quite differently organized.
According Lemy from Croatia MF286(A) works well with DNA firmware also in Croatia
He used Google translation :) at DNA forum
The fimware (exe program) you have tried was an exepection because DNA/ZTE had serious promlems with stability in MF286.
In my knolidge it is is not possible to upgrade device manually. only ota
Etätyön ongelmia... onkos kellään havaintoa, että 286A:n tarjoilema netti hidastuu käytön myötä (lopulta n. 1/50 4G:n luvatusta) ja virtanappi palauttaa netin nopeuden normaaliksi (jopa n. 1/2 4G:n luvatusta) kellonajasta riippumatta? Lykkäsin purkin jo ajastimen taakse eli buuttaa joka yö, mutta iltapäivästä ollaan aina hitaana. Purkissa on telian simmi, lieköhän siellä jotain datamäärään perustuvaa hidastusta käytössä?
Ei täällä ainakaan Telia hidastu, vaikka purkin edellisestä boottauksesta on 52 päivää ja dataa liikkuu 350 gigaa kuukaudessa.
Purkkikaan ei hidastele, mutta kyseessä onkin vanilla-286 vanhalla firmwarella bridged -tilassa.
DNA Hesingissä toimii kiitettävästi siltaavana f/w ZTE_DNA_MF286_B16
Muuten vaikea sanoa boottaus vaihtaa yleensä myös WAN IP osoitteen, tästä tuskin kyse.
Ja jos "mulla toimii" kehujen lisäksi testausehdotuksena:
Reitittävänä kytkee WLAN:n pois ja kytkee eth johdon lan2-4 porttiin (lan1 on "monitoimi" portti jota käytetään myös varayteyden pollaamiseen)
ZTE:stä tullut uusi malli MF286D ja löytyy nyt myynnistä:
  • Teoreettinen maksiminopeus LTE-verkossa 600/150 Mbit/s (Cat12)
  • Teoreettinen maksiminopeus DC-HSPA+ -verkossa 42/5.76 Mbit/s
  • LTE FDD 700/800/900/1800/2100/2600 Mhz + TDD 2600Mhz
Sen verran eri laite että olis voinut vaihtaa mallinumeron.
MF286 ja MF286(A) mallien ero taitaa olla vain WiFi piireissä ?
Sinänsä Cat12 kiinnostanee monia toivottavasti Elisa ei ole tehnyt mitään tyhmää ominaisuuksiin ?
Itsellä on alkuperäinen MF286 ja tämä kyllä kiinnostaisi, aika vähän vain tietoa tai arvosteluja laitteesta.
On todella vähän tietoa tuosta MF286D-mallista, Elisan ohjekin menee vanhaan malliin.
Hinta yrityksille 0% alv. näkyy olevan 149€
Kuvasta päätellen tuossa voisi olla paikka akullekin, kun on samannäköinen luukku takana kuin vanhemmassa mallissa.
En oo hetkeen MF286:sta hypistellyt mutta eikös tuossa ole ihan sama mekaniikka paitsi että tuo väliosa on sininen. Merkkivalopaneelista näyttäisi BAT puuttuvan, vaikka takaluukku löytyykin.
Mahtaakohan tässä uudessakin olla yhtä idioottimainen se antenni ratkaisu että laite ei osaa käyttää kuin yhtä ulkonantennia kerrallaan ,
monethan tosin modas siitä vanhemmasta ne molemmat ulkoliittimet "toimimaan"samaan aikaan.
Vaatisi käytännössä testauksen. Tosin modeemipiiri on uusi, joten toivotaan että suunnittelijat ovat nyt tehneet paremman ratkaisun antenniasiassakin.
Taitanee olla järkevintä odottaa ja toivoa että tulee myyntiin DNA:lle... kun muistelee millainen farssi oli Elisalla saada vanhempiin malleihin uutta softaa. DNA veti tuolloin Elisaa softan päivitysnopeudessa kuin pässiä narussa.
Satelite,ota sitten huomioon että dna:lta tuntui ainakin noihin vanhempiin tulevan bugisia päivityksiä,kun taasen elisalta niitä ei pahemmin ole tullut.Kannattaa lukee niistä zte286 dna brändättyjen päivitys ongelmista,(itellänikin sellainen oli aikoinaan ja jäi viimeiseksi dna laitteeksi) ,10 bugista vai 1 toimiva....siinäpä kysymys .
Itsellä ei kyseiset bugit aiheuttanut harmia ja Elisan laitteista puuttui joitain ominaisuuksia firmiksestä mitkä olisi uudemmasta löytyneet mutta Elisa ei firmistä saanut ulos tai sai mutta aivan helvetin hitaasti.
Minulla oli 2 viikkoa DNA:n MF286. Onneksi kerkesin palauttamaan sen ja lopettamaan netti- ja puhelinliittymän DNA:lle. Siellä ilmeisesti joku koulutyttö (ainakin palstan kuvasta päätellen) vastaili valituksiin luvatuista mutta puuttuvista ominaisuuksista aivan puutaheinää:
Ostin sitten Elisalta MF286 akun kanssa hintaan 169 €, lieneekö ollut hetkellinen virheellinen tarjous. Suurin vika sen ohjelmistossa (kuten DNA:nkin) oli alussa modeemin jumittuminen saapuvaan tekstiviestiin, mikä sitten myöhemmin korjattiin. Muuten Elisan versio ei ole pätkinyt lainkaan näiden yli 3 vuoden aikana, mikä ei näköjään ole ollut asianlaita jatkuvien DNA-päivitysten kohdalla.
Ei tuota usb-jaon puutettakaan (SMB- tai printterikäyttöön) ole enää vuosiin tullut kaivanneeksi.
Itse en onneksi ole ollut niin tyhmä että ottaisin kaikenmaailman viestejä vastaan mokkulaan... ainoat mitä on mokkulaan tulleet on ollu liittymän vaihtoa koskevia.
Ongelmia on ollut varsinkin MF286 ei niinkään MF286A mallissa ?
Nyt kun ketju on ylhällä tuli mieleen syksyllä DNA:lta tullut tekstiviesti:
Hyvä asiakkaamme, käytössäsi ollut DNA Kotimokkula (ZTE MF286) vaatii ohjelmiston päivityksen, joka on välttämätön laitteen toiminnan varmistamiseksi jatkossa täältä dna.fi/dna-kotimokkula-4g-wlan-mf286#päivitykset HUOM! jotta varmistat laitteesi toiminnan jatkossa päivitys tulee tehdä viimeistään 11.10.2019 mennessä.Joslaite ei ole enään käytössä sinun ei tarvitse tehdä mitään. Pahoittelemme asian tiimoilta koituvaa hatmia. Terveisin, DNA
Epäluuloinen luonne vois kuvitella että ota päivitykset on loppuneet.
Koitin kysellä asiasta DNA:n palstalla mutta jostain syystä eivät vastanneet ;)
Muuten olen kyllä tyytyväinen sekä modeemin että DNA:n toimintaan.
Mikäs on sit tämän hetkinen DNA firmisversio?
Minulla on Telian sim-kortti ja DNA:lta joskus saatu ZTE MF286. En saa Telian kortilla muodostettua verkkoyhteyttä. Sain Telian asiakaspalvelusta asetukset mitkä laitan mokkulaan, mutta en löydä paikkaa mihin ne voisin syöttää, DNS-osoitteet jne.
Mitenköhän tässä pitäisi nyt edetä?
Tietokone näkymässä paina siitä 4g - asetukset, yhteyspiste ja apn kirjoitetaan siihen yhteyspiste kohtaan.
Puhelimen sim on myös telialta ja kokeilin eilen mokkulassa, mutta ei mitään eloa.
Tunnistaa molemmilla kyllä että on Soneran simmit...
Factory reset varmaan tehty laitteelle painamalla siitä reset kolosta 15 sekunttia? Jos oot niin koitappa tehdä se kahdesti putkeen...
Nyt on tullut uusi Elisan Mf286d laite, ohessa muutama mielenkiintoinen kuva hallinnasta.
Suuret pahoittelut kuvien laadusta, suunnitelma muuttui ja piti heti viedä, ovat siis pikaisia räpsyjä...
    3,1 MB · Luettu: 486
    3,5 MB · Luettu: 492
    4,6 MB · Luettu: 487
    3,6 MB · Luettu: 448
    3,9 MB · Luettu: 423
Eli sama juttu antennien kanssa. L antennissa ylätaajuudet B7 B38 ja R antennissa matalammat.
Ruumiinavaus suoritettu uudelle mf286d mallille. Muuten aika identtinen vanhan mallin kanssa mutta muutama pcb antenni tullut lisää sekä modeemi kortista löytyy nyt 5 erillistä antenni liitäntää. Vanhassa mallissa oli 3kpl liittimiä.
Vielä ei ole päässyt testaamaan kunnolla 4x4mimoa mutta ensi viikolla pitäisi tulla uusi 4x4mimo paneeliantenni testaukseen.
Nyt kytketty kahdella ankannokalla niin nopeudet ja signaali arvot aika samoja kuin ennenkin.
ZTE MF826D:stä on tuetut taajuusyhdistelmät täälä listattuna: ZTE MF286D (MF286D) | 4G/5G Bands & CA Combos
Tuki 4x4:selle vain yhdellä taajuudella 1,3,7,38 + toinen taajuus 2x2. Laitteessa lisäksi 256QAM/64QAM tuki ja UL-CA myös intra-taajuuksilla, joten 100Mbit/s uppi voisi olla aika arkipäivää pian paitsi Elisalla, kun liittymissä 50Mbit/s lähetysnopeusrajoitus kuluttajapuolella.
Tuostakin apua jo jos saa korkeille taajuuksille 4x4 mimon käyttöön ja b20 taajuudella 2x2 nii voisi haaveilla 200mb dl nopeudesta ja vakaasta 50mb upista. Kylillä telia, elisa ja dna samassa tolpassa ja kaikilla samat taajuudet käytössä.
Jos tukiasemassa on 4x4 MIMO, mutta sitä on aika harvassa. Elisalla esimerkiksi 4x4 MIMO:a on Helsingissä, Vantaalla, Turussa, Tampereella ja Seinäjoella pelkästään. Mikäli otat DNA:n tai Telian niin voit saada parempaa uppia kun eivät rajoita 50Mbit/s kuluttajaliittymissä. Todennäköisesti laite suosii kolmea taajuutta latauspuolella kuin 4x4 MIMO:a.
Onkohan tuohon mitään työkalua millä näkee noista mf286 modeemeista enemmän tietoa? Nythän siitä näkee muutaman signaali arvon ja käytetyt taajuudet
Valitettavasti 3CA-lukkoja ei ole laitteessa, ainoastaan 2CA. 256QAM kyllä on mukava tässä MF286D laitteessa. 3CA 2x2 tai 2CA 4x4+2x2 tuottaa kyllä hyviä nopeuksia.
MF286D näyttää lähes kaikki mahdolliset tiedot, vanhemmista tuskin saa kovin paljoa irti.
Noihan on ihan perustietoja mutta ei sen kummempia. Näyttää olevan softa lähes identtinen vanhojen mallien kanssa
Eikös peruskäyttöön riitä ihan ne ledit siinä purkin taulussa.
huawei b2338-168 mallissa näki hyvin perustietoja signaaleista mutta muuten purkki ei oikein soveltunut suomen
verkkoihin.
Noihin 4g purkkeihin ei taideta panostaa kovin kummoisesti jos verrataan edes perus kytkinten hallintaan. Tai sitten operaattorit karsivat suurimman osan ominaisuuksista pois.
Xivion Oy
