FlickFetch
FF tosiaan sanoo tuota DRM-suojatuksi. Mutta mistä python-ohjelmasta oikein puhut? Ja onko YLE Areenassa muka oikeasti 2K laatua?
Suurin osa Areenan tarjonnasta on nykyään 1920x1080 laatua eli 2K.
Eikös videoiden resoluutiot mene suurin piirtein näin:
Low definition:
LD = 240p
LD = 360p
LD = 704x396
Standard definition:
SD = 640x460, 4:3, 480p, standard definition
SD = 720x480
SD = 640x480, 4:3, NTSC DV/DVD playback
SD = 853.3x480, 16:9 NTSC DV/DVD playback
SD = 720x576, PAL DV/DVD: NTSC DV/DVD encoding
SD = 768x576, 4:3.PAL DV/DVD playback
SD = 1024x576, 16:9, PAL DV/DVD playback wide screen
High definition:
1K = 1280x720, 16:9, 720p, HD, high definition, wide screen
2K = 1920x1080, 16:9, 1080p HDTV. Full HD, high definition, 2073600 pixels
2K = 2048x?, 2048x1152, 1:1,77
3K = 2560x1600 or 3440x1440
4K = 3840x2160, 16:9, UHD, 2160p, 4K
4K = 4096x2160, 1:1,9; DCI 4H, 4K
5K = 5120x2180
6K = 6560x3102, 5760x3240
8K = 7680x4320, 16:9, 8K UHD, 4320p
No enpä ole ennen törmännyt missään siihen, että 1080p olisi 2K.
2K resolution - Wikipedia
Comparison to 1080p
Occasionally, 1080p (Full HD or FHD) has been included into the 2K resolution definition. Although 1920x1080 could be considered as having a horizontal resolution of approximately 2,000 pixels, most media, including web content and books on video production, cinema references and definitions, define 1080p and 2K resolutions as separate definitions and not the same.
Although 1080p has the same vertical resolution as DCI 2K resolutions (1080 pixels), it has a smaller horizontal resolution below the range of 2K resolution formats.
According to official reference material, DCI and industry standards do not officially recognize 1080p as a 2K resolution in literature concerning 2K and 4K resolution.
Wikipedian artikkeli kertoo hyvin, että kyse on semantiikasta. 4K, 5K jne. määriteltiin näytönvalmistajien toimesta lähinnä markkinointitermeiksi. Pystysuuntainen resoluutio on tärkeintä kuvanlaadussa. Vaakasuunnassa pixeleitä voi venyttää, kuten YLE tekee 1024x576 resoluutiossa. Jos 4K:n korkeus on 2160 pixeliä, niin eikö 2K:n korkeus ole puolet siitä, eli 1080?
Pixeleiden määrä pystysuunnassa oli tärkeää analogisissa näytöissä, koska se vastasi pyyhkäisujuovien määrää. Nykyisissä digitaalisissa näytöissä vaakasuunnassa olevien pixelien määrä on yhtä tärkeätä kuin pystysuunnassa, joten 4K, 5K jne näytöissä ollaan yhä enemmän siirtymässä määrittelemään myös minimi vaakapixelien määrä. Vieläkin tärkeämpää vaakapixelien määtä on jos jossain vaiheessa CinemaScope 2,39:1 näytöt alkavat yleistyä.
Wikin artikkelissä selvästi sanotaan, että "most media, including web content and books on video production, cinema references and definitions, define 1080p and 2K resolutions as separate definitions and not the same" ja "According to official reference material, DCI and industry standards do not officially recognize 1080p as a 2K resolution in literature concerning 2K and 4K resolution".
Eli IMO, FHD (1920x1080/1080p, pystysuuntaiset pikselit) ei ole 2K (~2048x?, vaakasuuntaiset pikselit). 2K on muutamia prosentteja suurempi kuva.
Helvetinmoinen soppa on kyllä keitetty näistä asioista.
Osaako joku selittää miksi FF väittää tätä Outlander-jaksoa DRM-suojatuksi, mutta tämä mainittu Python -ohjelma pystyy lataamaan sen virheettömästi, tosin vain 360p laatuna, vaikka aikaisemmin kaikki Outlanderit ovat olleet 2K laatua.
Firefoxin fvd-liitännäisellä (Flash Video Downloader - YouTube HD Download [4K] - Add-ons for Firefox) sen pystyy myös lataamaan. On kolme tarkkuusvaihtoehtoa: 640x360, 1280x720 sekä 1920x1080. Luonnollisestikaan fvd:llä ei tekstitys tule mukaan, vaan se pitää kaivaa sorsasta. En itse vielä hakenut, joten en ole aivan varma, löytyykö tekstitykset, mutta joka tapauksessa nuo kolme eri tarkkuutta latautuvat oikein.
Sen sijaan toinen koneistani, jossa on Win 7 ja Firefox, ei kykene toistamaan jaksoa Areenan playerilla. Se jää vain ikuisesti pyörittämään "ratasta". Firefoxilla Win XP -koneella toistuu kyllä. Molemmilla koneilla jakson voi ladata Firefoxin fvd:llä. HTH
Flickfetchin lataussivusto lienee matalana?
Edit: No nytpäs on jännää kerrakseen, kotiyhteyden sijaan kännykällä muodostettu yhteys toimii kunnolla, ja tämän kautta ohjelman latauskin toimii.
Rupesin jo vähän ihmettelemään että mihin katosi tämän flickfetch ketjun keskustelijat sieltä Muro Plazasta :).
Ennen kuin tarkemmalla lukemisella huomasin linkin tänne foorumille.
Kysymys olisi että millä ohjelmalla saa äänitettyä pelkät tekstitykset noista DRM suojatuista Outlanderin jaksoista?
Löysinkin jo sen ohjelman sille videolle mutta se ei äänitä niitä tekstejä. En tarkoita nyt tuota " Python" ohjelmaa.
Pettymys oli suuri kun tuo Outlanderin jakso joka on jo tuossa aiemmassa viestissä mainittu ja myös se seuraavakin jakso joka tuli juuri on laitettu DRM suojatuksi. :(
Ohjelman pitää olla Windows 7 tai 8 käyttöjärjestelmään sopiva. :)
Rosa
Rosa
En onnistunut lataamaan Outlanderia Liisan mainitsemalla Flash Video Downloader -ohjelmalla, joten yritin uudelleen Python-ohjelmalla. Nyt se latasi HD-laadulla teksteineen. Vika oli lataus.bat komentojonossa, joka pyysi huonointa laatua, ei parasta. Tässä oma toimiva komentojononi:
yle-dl.py --vfat -i download_list.txt --sublang all --maxbitrate best --destdir "d:/data/! Downloads"
pause
Tuossa mainittu download_list.txt sisältää luettelon ladattavista Areena-osoitteista ja tallennushakemisto sinun pitää myös valita. Toimii Win 7:ssä.
pause
Niin tuo "komentosarja" RTMPDump juttu :(:(:oops:
( en tykkää "leikkiä" :oops::facepalm: tietokoneella noilla komentosarja jutuilla :eek: )
En tieten osaa käyttää sitä oikein :oops:. Mihin ihmeeseen siinä laitetaan sen halutun areena videon osoite että se rupeaa sitä videota lataamaan talteen.
Muistan jostain ihan vanhasta versiosta ennen tuota FlickFetch ohjelmaa että siinä tuli joku kunnon ohjelma siihen johon laitettiin se ladattavan osoite. Mutta siitä on vuosia kun käytin sitä. :oops:
Minä olen ladannut jo kaksi Outlanderin jaksoa tuolla Flash Video Downloaderilla.
Jakso 5 pystyn kattomaan Media Player Classicilla mutta jakso 6 ei toimi missään tietokoneella tällä hetkellä olevalla ohjelmalla. :(:confused:
Rosa :oops:
Mikäs juttu tämä DRM-hässäkkä YLE Areenan videoissa oikein on? Onko aiemmin ollut "suojattuja" videoita?
FF tosiaan sanoo: "jakso on suojattu, eli sitä ei ole mahdollista ladata millään lataajalla". Mutta kuitenkin joku python skripti nuo kuitenkin osaa ladata?!
Kaikkein uusinkin jakso Outlanderia latautui Pythonilla ilman ongelmia. Silti FF herjaa DRM-suojauksesta eikä suostu lataamaan.
Ylellä oli jonkin verran DRM-suojattuja ohjelmia vanhan playerin aikaan. Ennen Outlanderia sellaisia en ole huomannut uudella playerilla mutta ottaen huomioon että ensimmäinen ongelmallinen Outlander on julkaistu kuukauden ensimmäinen päivä yksi mahdollinen selitys on että Ylellä on säädetty jotain esim. sopimusehtojen tiukennuttua kuukauden alusta. Lienee turha kuvitella ettei Ylellä tiedettäisi kaikkein suosituimmasta latausohjelmasta joten voisivat helposti testata miten se saadaan estettyä ;)
Että olisivat lähteneet estämään vain tiettyä ohjelmaa eikä tekniikan puolelta säppiin kaikilta, hmm..
Mitäs darxide, oletko kerinnyt jo ihmetellä asiaa?
Ei ollut aiemminkaan kaikki suojattuja. Onhan mahdollista että striimauspalvelu laskuttaa DRM-sisällöstä enemmän tai DRM ei toimi kaikissa älytelevisioissa tai Kiinan Androideilla (vrt. Katsomo).
Esim. GoT ei ollut suojattu vaikka tekniikka oli olemassa kun taas Mr. Robot oli (jos muistan oikein). Uusia kv-sarjoja molemmat. Oma päätelmäni oli että jos sopimus ei edellytä Yle ei suojaa.
Taisin kirjoittaa niin sekavasti, että ymmärsit väärin (vai ymmärsinkö minä väärin sinun vastauksesi?), tarkoitin siis ettäkö YLE olisi lähtenyt estämään tiettyä ohjelmaa (FlickFetch) lataamasta (tiettyä videosisältöä), eivätkä tekniikan puolelta olisi estäneet sen tietyn videosisällön lataamista kaikilta? Sitä ihmettelin.
Joo tsori, en oo ehtinyt täällä juuri käydä.
Ylen puolelta on tsekattu ohjelman JSON-tiedoista että jos "data.program.publicationEvent.0.media.contentProtection.0.id" = "22-3", niin jakso on DRM-suojattu, ja siitä tulee ilmoitus. FF ei siis mitenkään muuten tunnista DRM:ää, vaan on tähän saakka luottanut tohon. Tuo tarkistus on nyt siis otettava pois koska se näemmä ei enää pidä paikkaansa ja estää suojaamattomien latauksen.
Eli jatkossa oikeasti DRM-suojattujen jaksojen lataus ei sitten vaan onnistu mutta siitä ei enää saada ilmoitusta että miksi ei onnistu. Tässä on yksi syy miksi en halua (laiskuuden ohella) kaikkiin tilanteisiin yrittää kaivaa sitä oikeaa syytä mikä on vialla, vaan annan FF:n suoltaa niitä sisäisiä virheilmoituksia (jotka ei ehkä käyttäjälle sano mitään), koska niistä on tuhat kertaa helpompi debugata pelkän ilmoituksen perusteella että mikä saattaisi olla vialla.
v3.6.1.8 - 9.11.2017
- Lisätty: Asetuksissa "Lataaja" -sivulla on mahdollisuus ottaa pois päältä edellisessä versiossa lisätty FFmpeg-latauksen aloittaminen alusta jos latauksessa tulee virheitä.
- Korjattu: Joitain Ylen sarjoja ei saanut ladattua virheellisen DRM-varoituksen takia.
@TenderBeef Joo, taisin ymmärtää väärin, ainakin osittain. Ajattelin että jos yksi ohjelma vastaa esim. 95 % latauksista niin jo sen estäminen olisi voitto. Joku syyhän Ylellä on että DRM loppui kun player vaihtui. Jos se on tekninen ts. aito DRM ei ole mahdollista niin jo se että näyttää DRM:ltä riittää. Yle käyttää Kalturan palvelua johonkin mutta itse striimi tullee jostain CDN-tyylisestä palvelusta joten "kilpailija" lataa iloisesti.
Edit: Ahaa, @darxide on herännyt ja syykin oli kirjoittamani tapainen. Tahallinen vai tahaton Ylen puolelta kuka tietää..
Eipä mitään anteeksipyydeltävää, tuskin tämä sinun 1-prioriteetti on elämässä. Tuhannet kiitokset taas!
Eli sama tilanne kuin Ruudun osalta, samahan problematiikka tuli eteen Ruuttuus-skriptissäni (joka ei paljon rakkautta näköjään ole saanut ;)). Jännä miten palveluiden omissa tiedoissa on tuollaista outoa paikkansapitämätöntä tietoa.
Ai niin, kiitos taas nopeasta korjauksesta. Tosin heti löytyi myös parannettavaa :)
Ei varmastikaan uuden julkaisun arvoinen mutta kenties seuraavaan voisi sisällyttää. Epäonnistunut DRM-yritys tallentuu database.txt:hen vaikkei mitään ladata. Myöhemmin ladattaessa, jos ohjelma ei olekaan enää suojattu, FlickFetch luulee että se on jo ladattu. Korjaus esim. 1) parsitaan osumariviä ja jos ohjelman nimi on pelkästään DRM niin se ohitetaan tai 2) valinta käyttäjälle tallentuuko DRM-epäonnistuminen historiaan lainkaan.
Alunperin se tehtiin tarkoituksella ja yleisön pyynnöstä juuri niin että DRM-suojatut tallennetaan tietokantaan ettei niitä turhaan uudestaan yritetä ladata. Onko muuten yksikään suojattu ohjelma muuttunut suojaamattomaksi? :)
Asetus tuolle ei tietysti kovin iso juttu olisi, mutta kun Ylen DRM-tunnistus juuri poistettiin niin hieman turha kai sitä enää on tehdä...
Uusimmassa versiossa haussa on ongelmia. Ohjelman hakeminen tyssää virheilmoitukseen, mutta URL-osoitteen kopioiminen aloittaa ohjelman lataamisen onnistuneesti.
Koodi:
Tuntematon virhe:
Objektin viittaukseksi ei voi määrittää objektiesiintymää.
   kohteessa FlickFetch.FormMain.downloadVideo(String address, String folder, Boolean isList, Boolean force)
Voit halutessasi lähettää bugiraportin ikkunan oikeasta yläkulmasta löytyvällä linkillä.
areena: kotikatu
Tuntematon virhe:
areena: noin viikon uutiset
Tuntematon virhe:
Lataus aloitettu klo 14.34.19
Noin viikon uutiset - 2017-11-09 - Jakso 08 - Ilmastonmuutos meillä ja muualla
Jukka Lindström ja Noin viikon uutiset. Suomen vallattomin ajankohtaissatiiri. Aiheena ilmastonmuutos meillä ja muualla. Vieraana Jari Hanska. #nvuutiset
https://areena.yle.fi/1-4201027
Koodi:
Tuntematon virhe:
areena: kotikatu
Tuntematon virhe:
Tuntematon virhe:
Kokeilitko toimiiko haku sen jälkeen kun oot käynyt Areenan sivuilla? Törmäsin että mulla teki äskettäin niin, mikä oli vähän mysteeri... ehkä joku sertifikaattihomma.
Ihan hyvin toimii. Itsellä on asetuksissa kaikkien tekstitysten tallennus. Tuossa ohjelmassa on kahdet eri suomitekstit, normaalit joissa on vain ei-suomenkieli tekstitettynä (fin), ja suomi huonokuuloisille jossa kaikki tekstitetty (fih).
Mistähän johtuu että tekstitykset ei tallennu areenasta, ainakaan tästä ohjelmasta? Lainkiertäjät paratiisissa 2 | MOT
Asetuksissa on valittuna fin-tekstit. Selaimella ohjelmaa katsoessa tekstit toimii.
Hmm. Itsellä tallentuu hyvin....
Download started at 21.06.08
MOT - Lainkiertäjät paratiisissa 2 (2017-11-14)
Sadat suomalaiset ovat perustaneet yhtiöitä tai sijoittaneet varoja veroparatiiseissa toimiviin yhtiöihin. Usein syynä on verosuunnittelu, mutta joskus taustalla on verokiertoa, rahanpesua tai rikoksia. Toimittajina Jyri Hänninen ja Minna Knus-Galán.
Subtitles saved: Finnish, Finnish for hearing impaired.
https: //areena.yle.fi/1-3849185
No perskeles, niinpä toimii nyt minullakin. Tosin eri kone tällä hetkellä käytössä, pitää vielä illalla testata sillä mikä eilen ei tekstejä saanut ladattua. Kiitos ja anteeksi :)
Eipäs toimi tällä toisella koneella edelleenkään. Asensin Flickfetchin puhtaalta pöydältä uudelleenkin eikä se auttanut. Myöskin asetukset tekstitysten lataukseen saa laittaa miten vain (kaikki tai pelkät fin) ja mitään tekstejä ei tuosta ohjelmasta lataa. Tämä on Win XP ja se missä päivällä tekstit latautui on 7, josko sillä on jotain vaikutusta?
Tuo kyseinen ohjelma latautuu myös HDSdumpilla tai RTMPdumpilla, riippuen kumpi on valittu, ei siis ffmpegillä.
Ja vika ei koske kaikkia ohjelmia areenassa, esim tätä kokeilin niin tekstit tallentui aivan ok: Jakso 1: Kotiinpaluu | Velvet - muotitalon tarina
Siinä videokin tulee ffmpegillä.
:o
Erikoinen ongelma. Tästä ei ehkä ole mitään apua mutta minulla kävi viime lauantaina sillä lailla, että areena.yle.fi/1-3783582 leffasarjan viimeisintä videota FF lähti jostain syystä lataamaan HDSDumpilla ja tuli vain jotain "blocked" tjsp. virheitä vaikka aiemmin sarjan kaikki leffat on tullut oikein FFmpegillä (win8:ssa). FF yritti useamman kerran uudestaan HDSDumpilla kunnes jotenkin jäi jumittamaan. Pysäytin latauksen ja käynnistin uudestaan ja sitten lähti oikein FFmpegillä.
EDIT: Typerä foorumisofta ei anna laittaa yle areenan linkkiä linkiksi, aina tekee embeddauksen..
:eek:
Testasin XP:llä, ei tosiaan löydä tekstejä sillä. Ei oikeastaan hajuakaan miksi näin on...
Areenalataukset hoidetaan FFmpegillä, mikäli latauslinkki sille saadaan. Muussa tapauksessa ladataan automaattisesti "vanhalla tavalla" HDSDumpilla/RTMPDumpilla. Eli joku virhe netissä/ylellä juuri haun aikana niin on FFmpeg-linkki jäänyt saamatta.
Varmaankin noin, eipä tuo haitannut kun lähti sitten kuitenkin oikein tulemaan, ajattelin vain mainita josko olisi jotain yhteyttä SimoL:n ongelmaan.
BTW. On pitänyt kysyä jo aiemmin: kun katsoo jonkun videon tietoja, sellaisen joka ladataan FFmpegillä, niin miksi siinä tietoikkunassa on HDSDumpin latauskomento? Esim. on rivi "Lataajan komento (HDSDump):" ja tekstitystietojen jälkeen vielä "Videon laadut (FFmpeg):". Eipä tuo haittaa yhtään, pistää vaan aina silmään jos katson joskus tietoja.
Voisikohan tuo johtua siitä, että (ainakin minulla) Areenan oma playeri ei näytä tuosta ohjelmasta oletuksena tekstitystä, vaan se pitää panna päälle. Normaaleissa ulkomaisissa sarjoissa tekstitys on (ainakin minulla) Areenan playerissa oletuksena päällä.Tekstitys myös tulee Areenan playerissa erilaisella fontilla tässä MOTin ohjelmassa kuin vaikkapa Silta-sarjan jaksoissa. Ja kun Areenan playerissa katsoo "Inspect Elementissä" tekstityskohtia, tuossa MOTin ohjelmassa ei näy tätä osuutta lainkaan (napattu Silta S03E04:stä Jakso 4 | Silta)
<track kind="subtitles" language="Finnish" srclang="fi" label="käännöstekstitys" id="1_vrlqvp19" fileext="srt" src="https://cdnsecakmi.kaltura.com/api_...sBtYTHZGz-_HiaKBW-sMjf9MEpA1DftvRGTm5uZs/.srt" title="käännöstekstitys" default="true">
Saako tämän tai jonkun muun areena-laturin toimimaan tabletin androidilla?
yle-dl
Vaaditut kirjastot ja ohjelmat: Python 2.7, pip, pycrypto, wget, ffmpeg, PHP-tulkki sekä seuraavat PHP-laajennukset: bcmath, curl, mcrypt ja SimpleXML. Areenan radio-ohjelmien lataamiseen tarvitaan lisäksi rtmpdump (versio 2.4 tai uudempi, mieluiten uusin kehitysversio projektin kotisivulta).
Saattaa olla mahdollista, mutta riippuvuuksien asentaminen voi olla haastavaa.
FlickFetch ohjelman lataus / asennus.
Ohjelman lataus.Täysipaketti,asennusohjelman kanssa.
Tulee liitteenmukainen ilmoitus.
Haittatiedosto,älä suorita.
Onko vaarana saada örkkejä koneelle.
Käyttis Win10
FlickFetch
    17 KB · Luettu: 65
Avaat sivun lähdekoodin, etsit <h2>On-demand</h2> tekstinpätkän jonka jälkeen kaikki ohjelmat on listattu, sieltä sitten poimit linkit, esim. nyt ensimmäinen on-demand linkki on siellä tekstin seassa: http:\/\/objects.fi-1.nebulacloud.fi\/swift\/v1\/rh2017ondemand\/20171130_RHIP_OD.mp3 siitä vain otat takakenoviivat pois niin saat latauslinkin. Jos selain avaa sen soitettavaksi selaimessa eikä lataa suoraan, sitten vaan hiiren oikeasta valikosta tallennat kovalevylle.
Tuhannet kiitokset, tusentals tack
Jos joltakin löytyy Murha Paratiisissa -sarjan kuudennen kauden ensimmäinen jakso, niin voi laittaa yv:tä. :oops:
Paljonko videon pituus on minuuteissa? Minulla Windows näyttää Outlander 3.8 "1,49 GB (1 609 877 643 bytes)" eli ei se paljoa vajaa ole. Vai tarkoitatko tuoreimmalla kuitenkin jaksoa 9 (en ole itse ladannut vielä)??
Joskus tuntuu että Areena yksinkertaisesti pätkii, matalammallakin resoluutiolla 100 Mbit -kuituyhteydellä ladatessa voi vaan pysähtyä. Oletan että Areenan player osaa puskuroida mutta FF ei kestä noita katkoja.
Mikä on vikana kun tuorein Outlander aina keskeytyy 1,48 gigan kohdalla yritti latausta FF:llä tai yle-dl ohjelmalla? Onko kukaan saanut sitä ladattua kokonaan?
Jakso 8: Ensimmäinen vaimoni | Outlander - Matkantekijä
No sen kokoinen se suurinpiirtein tuntuisi olevan. Ainakin lopputekstit lipuvat lopussa...
Minulla pituus on 57:15 ja koko 1,49 Gt (1 600 370 955 tavua). Kokohan kai voi vähän riippua, onko ottanut pois kuten minä, sen uudelleen yrittämisen jos joku virhe huomataan (kun en katsoessa ole koskaan huomannut virheitä). Tai itselle jäi se tuntu että uudelleen yrittämisen kanssa teki hieman suurempia tiedostoja, varmaankin kun ei virheitä sitten ole :) Itselle vaan kesti se virheetön lataus liian kauan, kun yhtä ohjelmaa hinkattiin tunti pari.
Pilkun pökkimistä, mutta ffmpeg huolehtii latauksesta.
Opps! Se on jakso 9 jota yritän latailla ja siinä on vielä 9 päivää latausaikaa jäljellä.
Sen lataus katkeaa aina 52:39.98 :n johdalla, 1,48 GB (1 589 731 456 bytes) eli jää 96.6 prosenttiin.
Jakso 9: Tyyntä myrskyn edellä | Outlander - Matkantekijä
Eikö loki sano mitään? Mutta eipä olisi ensimmäinen kerta kun Areenan videoissa olisi jotain häikkää.
obalz
