My Summer Car
Aika hankalaa on sähköjen veto eikä ehkä kauheasti edes innostanut minua,ainakaan alussa. Mutta onhan tuolla muitakin uudistuksia, osa ihan hyviäkin, esim tunkin saa vihdoinkin taitettua niin se mahtuu paremmin autoon jne.
Reactions: Foz
Näinhän se meni, että kesäautolla jatkettiin talvetkin. Ei mitään mullistavaa ole luvassa ilmeisesti, mutta toivottavasti jäälle pääsee ajamaan ja hanget on edes suunnilleen oikeanlaiset.
Jaahas ja uutta beta-päivitystä. Piti jo vähän käydä testailemassakin, grilli tulille ja Sisuun kävin hakemassa tankin täyteen löpöä. :vihellys:
WARNING: Valve adjustments have changed, so you might need to re-adjust valves or make Fleetari do it
-Fixed issue (again) with in-game clock not working correctly when sleeping
-Fixed issue with front wheel alignment resetting into incorrect angle upon every game load
-Fixed issue with Teimo sometimes heading back to home right after opening the store
-Car should now slide less when on top of a Floor Jack
-Fixed issue with battery terminals self-tightening the bolts in some cases
-Increased useful battery life when running engine without working Alternator
-Highway traffic is now more randomized
-Decreased possibility of AI car veering off to oncoming lane towards Player
-Added Fuel Oil pump to Teimo store, note that it is in most cases illegal to use Fuel Oil as Diesel alternative
-Fuel prices are now subject to change
-Added new grilling system, grilling with open fire makes food burn, so grill on embers instead
-Added Brick Grill (uses Firewood) to Cottage and moveable Ball Grill (uses Charcoals)
-Dead moose can be now chopped into meat chunks with Axe
-Moose meat can be eaten after it has been grilled, similarly to fish
-Moose travel paths are now much more randomized
-Added garbage barrel to burn trash
-Added alternative mounting point for the Tachometer on top of the Dashboard
-Added Satsuma charge warning light to indicate if Alternator is not charging properly
-Adjusted Satsuma valve settings, you might need to re-adjust valves or make Fleetari do it
-Made Satsuma valve adjust more precise with smaller tolerances and decreased loose play at both ends
-Adjusted Satsuma engine heat output, overheats easier now
-Getting suspension damage from crashing might now also cause tire puncture
-Improved both Truck and Tractor Parking Brake systems
-Added Beacon light to Truck
-Added Saturday night "dance" and related fist fight mechanics
-Grandma can now call about food deliveries
-Fixed bug with not being able to light a cigarette while sitting on a chair
-Added Coffee Pan for making coffee on open fire or grill
-Map changes
-GUI changes
Palasin taas toviksi peliin, onkos tuossa mitään ihmeellistä mihin n. 1v jälkeen kannattaisi tutustua? Ainakin muutama kymysys olis:
1. Ajelin kylälle päin, rykipohjan tiellä (?) tuli joku talo vastaan jota ei aikaisemmin ollut
2. Onkos kylällä uutta nähtävää pl. 2 amista
3. Voiko poliisit vihdoinkin tulla kotiovelle?
1. Mummon talo on vasemmalla Rykipohjaan päin ennen junarataa, sitten kauempana lähellä lentokentälle vievää asfalttitietä oikealla on mansikoidenpoiminta paikka.
2. Kylälle on tullut toimiva jäteveden puhdistamo mihin lietekaivojen sisältö pitää jättää, sitten urheilukentällä on pari poikaa pelaamassa jalkapalloa, sitten siellä on rivitalo jonne paidaton juoppo pyytää muuttoapua jossain vaiheessa
3. Poliisit on tulleet jo aikoja sitten ovelle jos jätät liikennesakot tai ympäristörikesakot(lietteen dumppaus maahan) maksamatta.
Autoon on tullut muutama uusi osa tai ominaisuus, siihen pitää asentaa nyt sähköjohdot, virranjakaja(ajoitus) ja nokka-akseli(asento) pitää säätää myös, renkaat ja vanteet ostetaan erikseen(vanteet lehdestä ja renkaat fleetarilta), sitten renkaissa on kuluma ja ne voi puhjeta kolareissa, samoin iskarit voi vääntyä kolareissa ja silloin ne vaatii korjauksen fleetarilla, ralli on kaksipäiväinen(la 1ek su 1ek, yhteisaika ratkaisee, parc ferme alue).
Aha, talo paloi sitten kokonaan kun jätin saunan päälle. :confused:
En ole pelannu sitten viime kesän, vissiin tullu muutamia uusia juttuja. :think:
Oho, itellä on ollut sauna päällä koko ajan pelin alusta lähtien. Täytyypä käydä naksauttamassa pois päältä, jahka seuraavan kerran menee pitkästä aikaa pelailemaan.
Imo taloa ei saa enää takas. Kävi kyllä mielessä että saunoisi jatkossa mökillä mutta olis menny aika vaivalloiseksi joten alotin alusta.
Enkä tiedä miten tuo puhelimenkaan käyttö enää onnistuis siellä talon raunioissa.. :D
Siinä olisi se ohje.
Saunahan vähentää vain stressiä nykyään jonka voi hoitaa
- tupakalla (neg: riippuvuusongelma jos aina hoitaa stressin tupakalla, stressipalkki täytyy nopeammin kun saa riippuvuudun)
- puita halkomalla (melko hidasta)
- spämmää kiroilunappia (hidas)
- juomalla viinapullon halkoladosta (nopeasti koko palkki tyhjäksi, neg: humalatila ja seuraavana päivänä nukkumisen jälkeen krapula nostaa stressitason nopeasti maksimiin, en tiedä jos odottaa että humala menee ohitse niin tuleeko nukkumisen jälkeen krapulaa)
Jos ei edes pelaa permadeath päällä niin sitten ihan sama kuolla kotona stressiin kun spawnaat uudelleen kotitalon taakse
edit: saunasta aiheutuvan tulipaloriskin saa ehkä poistettua jos alentaa termostaatin max lämpötilaa, joku 4pykälää maksimista alaspäin niin sauna ei ehkä lämpene yli 100asteiseksi
Reilut 70 tuntia pelattu, pelissä olen kuunnellu aina pelin omaa radiota mainoksineen ja vasta nyt tajusin että Erkki Armas Hokkanen tarjoaa 40 vuoden kokemuksella "sonnin lypsäntää". :confused:
Itsellä meni 140h. :P
Tosin nyt 353h mittarissa. Nyt vituttaa, kun muut ei tiedä kaikkea.
Miten vaikea saada Xbox One - ohjain toimimaan MSC:n kanssa? Lähinnä parempi puolisko haluis pelata ja on henkeen sekä vereen ohjainpelaaja, niin mietin saako liikkumista (muuallakin kuin autossa) toimimaan ohjaimella?
Ei tätä saatana jaksa kyllä enää pelata, fysiikat on edelleen niin rikki välillä että ei mitään järkeä.. Ihan pikkusen yritin työntämällä oikaista autoa niin otti ihan kunnon voltit.. :facepalm:
Enkä edes aloita kertomaan siitä miten sain Satsuman kuntoon, säädettyä ja olin menossa katsastukseen niin mäntä tuli lohkosta läpi kun sain auton peruutettua tallista ulos.
Siis moottorista joka oli juuri Fleetarilla säädetty ja huollettu. Melko jäätävää paskaa. :rolleyes:
Itselläkin loppui mielenkiiinto tuon Satsuman laittoon, kun se on niin hankalaa ja lisäksi mistään ei saa palautetta, että mikä siinä on edes vikana. Älytöntä nysväystä vaan ja sitten se hyytyi taas johonkin risteykseen, niin aattelin että anti olla. Olis joku tapa vaikka tarkistaa auto, että onko pultit ja mutterit paikoillaan yms niin se auttaisi paljonkin.
Tosin muutenkin tästä pelistä parhaat kokemukset on muita kuin Satsumaan liittyviä. Sellaisia pieniä juttuja siellä täällä, niitä vois olla reilusti enemmänkin.
No siinäpä se tuli se toinen ränttäyksen aihe itelläkin. Tismalleen samat ajatukset noista pulteista.
Helvetin turhauttavaa kasata auto, omasta mielestäsi todella tarkasti katottu kaikki pultit yms ja lähdet ajamaan niin osia putoilee silti pitkin pientareita kunnes matkanteko päättyy syystä tai toisesta.
Olen pelannu nyt reilut 100 tuntia enkä ole kertaakaan saanu Satsumaa edes kilpiin.. :rolleyes:
Alusta olen alottanu varmaan toistakymmentä kertaa kun aina menee asiat vituks noiden fysiikka- tai muiden ongelmien takia.
Enkä edes kuvittele hinaavani tuota mutteriviritystä yhtään mihinkään, pari kertaa olen kokeillu ja sitten onkin noukittu osia pitkin tienposkia ympäri kyliä..
Kun lähdet ajamaan sillä satsumalla niin tallenna peli ennen sitä (ja ehkä ota save kopio talteen). Jos jotain osia putoaa tai auto hajoaa niin katsot mitä osia irtosi/mitä hajosi ja sitten otat esc -> quit without saving -> continue ja tarkistat ne jutut että oliko jotain pultteja/muttereita kenties auki. Sitten taas tallennus ennen ajoa (ja se save talteen).
Käytä ihmeessä jotain ohjetta jotta varmasti kaikki pultit/mutterit löytyy ja niiden tulee olla täysin kiinni, jos on yhden pykälänkin verran joku auki esim. eturenkaan ripustuksessa niin koko höskä voi irrota.
Peliinhän on olemassa msc editor (pelinkehittäjän työkalu) jolla voi tarkistaa pultit, teleportata/resetoida tavaroita jne, mutta tuon ohjelman liiallinen käyttö voi rikkoa saven.
Ja Satsuma ilmoittaa ongelmista erilaisilla äänillä ja muilla tavoin kuten esim. ylimääräisellä savulla(kannentiiviste), jäähdytysnesteen+öljyn nopealla vähenemisellä(kannentiiviste), merkkivaloilla esim. öljyvalo (+tulevassa päivityksessä tulee laturivalo), lisämittareilla, tehohävikillä(liian kuluneet männät), moottorin lämpötilan nopea nousu.
Pelissä pitäs olla joku pelihahmon kaveri joka tulis katsomaan Satsumaa ja auttamaan sen kasaamisessa kaljapalkalla, se auttais jo paljon.
Samallalailla kävi myös. Auto heitti pari volttia autotallin sisällä, jonka jälkeen ikkuna hajalla ja auto aivan rusinana. Tämän jälkeen tallensin pelin ja käynnistin MCS editorin. Editorilla korjasin hajonneen ikkunan ja poistin vielä mesh tiedoston. Ei kannata pikku bugien takia menettää peli-intoa, kun pienellä "huijaamisella" pääsee peliä jatkamaan normaalisti :tup:
MSC editor kertoo suoraan mitkä mutterit on löysällä tai mitkä osat hajalla. Löytyy tools valikosta nimellä satsuma report.
Netistä löytyy tallennuksia joissa satsuma on valmiiksi kasattu. Jos satsuman kanssa värkkäämiseen menee hermot, niin parempi keskittyä pelin muuhun sisältöön. Oma tallennus oli myös täällä jaossa, mutta tällä hetkellä se vaatisi hiukan päivitystä.
Tuo MSCEditor, sillä tuskin saa ihan autoa kasattua mutta kuinka suuri apu siitä on?
En ole ihan varma mutta sillä taitaa saada kasattua koko auton ilman osiin koskemista ja pulttaamisia tmv ja moottorin kuluvat/hajoavat osat voi palauttaa 100% tasolle. Ainakin tuolla steamin keskusteluissa monelle on tullut saven rikkovia ongelmia kun ovat käyttäneet tuota ohjelmaa "liikaa".
Yritin googletella, ei tuottanut tulosta. :D
Pelinähän tämä oli/on mielenkiintoinen. Mutta tuo jatkuva pelin "vaikeutus" tappaa mielenkiinnon. Kyllä mä voin sitä autoa säätää sen +100h, mutta emmä halua joka vitun tunti käydä käydä kaupalla/fletarilla hakemassa/korjaamassa autoa.
Sais olla joku säädettävä vaikeusaste, + paremmat fysiikat.
Kasaa auto fleetarilta ostetuilla osilla yht. 6389mk (ei tarvi ostaa uutta lohkoa tai öljypohjaa) niin ongelmia ei ihan heti tule. Hinaat ne kolme romuautoa fleetarille niin saat rahaa(9700mk) noihin vaihto-osiin(6389mk), parempaan jäähdyttimeen(1215mk), rekan tankin täytettyä(n.1300mk) ja vielä jää n.800mk.
Minä kasasin muuten auton fleetarin osilla ja pistin seosmittarit sun muut ja silti se hyytyi kesken ajon. Lisäksi se sähköjen veto ei kyllä innostanut yhtään, harvinaisen rasittavaa hommaa. No kyllä varmaan silti tulee pelattua joskus puolen vuoden päästä taas uudestaan, kun on ihan kiva nähdä mitä uutta on peliin tullut.
Oletko varma että asensit kaikki johdot (esim. jos unohdit asentaa laturin johdon niin akku hyytyy nopeasti)? Johdotus on siinä mielessä helppo että niitä ei voi laittaa väärin, jos joku ei toimi niin sieltä ehkä puuttuu joku johto.
Itsellä ei ole mitään hajua kuinka kauan sen pitäisi kestää ongelmitta uusilla osilla mutta veikkaisin että joku 500-1000km (n.40-70kertaa valtatielenkki ympäri) ennenkuin sieltä moottorista hajoaa jotain. Suosittelen kyllä sen paremman jäähdyttimen ostoa jos autolla haluaa ajaa yli 100km/h, muuten ne korkeammat lämmöt voi kuluttaa moottorin osia enemmän ja ne hajoaa nopeammin.
Laitoitko venttiilien, virranjakajan ja kaasarin säädöt kuntoon?
Etkä löytänyt selkeää syytä vikaan, ennen hyytymistä ei kuulunut mitään ylimääräisiä ääniä?
Jos ei kuulunut mitään ylimääräisiä ääniä eikä lämmöt nousseet niin silloin se ei voi olla kuin että
- akun varaus loppui koska johto laturista puuttui
- tai sytytystulppa(tulpat) hajosi(vat), en tiedä voiko virranjakaja huonossa säädössä rikkoa ne nopeasti
- tai bensa loppui
Saa sillä auton kasattua alusta loppuun ilman pelin käynnistämistä. Itse olen kasaillut ja virittänyt useita Satsumia editorin avulla ja mitään pahempia ongelmia ei ole tullut vastaan.
Aika yksinkertaista tuota on käyttää, koska jokaiselle osalle/toiminnolle on järkevä nimi. Vähän aikaa vaan kestää että oppii löytämään (nopeasti) sen mitä hakee.
E: Editorin avulla voi myös:
-poistaa stressin, nälän yms...
-lisätä rahaa
-muuttaa aikaa ja päivää
-teleportata osia, autoja ja itsesi
-korjata talon tulipalon jälkeen
-nopeuttaa/vaikuttaa erilaisiin töihin
-jne
Mulla menis kyllä viimenenkin maku jonkun editorin kanssa, mitä tästä enää saa irti jos parilla hiiren napautuksella saat kaiken mahdollisen? :confused:
Pelissä on vikansa ja buginsa eikä tuo editori mikään ratkaisu ole.
Laitetaan peli odottelemaan taas parempia aikoja, tätähän tää näiden early accessien kanssa on, kunhan vaan tämänkin kanssa tapahtuu jotain ettei jää ikuiseen early access-looppiin.. :rolleyes:
- tai bensa loppui
Pitää ihan muistella kun on vähän aikaa tästä. Ainakin oli koneessa kokonaan uutta osaa melkein kaikki, olikohan jopa lohkokin, tulpat, jäähdytin kisamallia,seosmittarilla oli säädöt kohdallaan. Mielestäni sähköt oli myös kaikki, toki se on ehkä sellainen missä voi puutteita ollakkin, mutta laturista ainakin oli akulle virta, uusi akku oli myös. Ajoin kämpältä sinne isolle tielle asti pikkuteitä, kunnes se kesken ajon hyytyi. Ei lähtenyt enää käytiin, siellä se on varmaan vieläkin tien poskessa tallessa. Virranjakajan säädin kyllä ja oliskohan fleetari sitten säätänyt venttiilit kuntoon.
Ihan tarkkoja mielikuvia ei kyllä ole kun tästä on aikaa. Vois kyllä taas kun päivitys tulee niin pelata tätä peliä ja ajella vaikka mopolla auton luokse/korjata se editorilla kuntoon.
Nimittäin mullahan oli tästä pelistä n. vuoden tauko ja sen aikana peliin oli tullut vaikka mitä uutta ja mukavaa. Esim se mopo on tosi hyvä keksintö ja aika nopeakin ajella.
Jos hyytymisen jälkeen yritit käynnistää ja starttimoottori pyöri niin silloin akussa oli virtaa riittävästi edelleen.
Eikä bensa loppunut? Asensitko johdo bensatankista takaosan yhdistämispaikkaan(mihin takavalotkin tulee) jotta mittaristo kertoo bensan määrän?
En osaa sanoa tulpista kun en tiedä voiko virranjakaja niitä jotenkin hajottaa edes tai ne kuluu vain ajomäärän mukaan.
Jos fleetari jotenkin sääti venttiilit väärin niin silloin sieltä kuuluu nakutusta ja jos venttiilit hajoaa niin se ääni on korkeampi taajuista tikitystä ja moottori sammuu melko nopeasti sen jälkeen.
Fysiikat täs pelissä kyl kaipais kipeesti parannuksia. Pitkästä aikaa availin tuossa pelin ja meni maku muutamassa tunnissa kun paskarekkaan hypätessä kävi muutaman kerran niin, että auto hyppäs taivaalle ja tippui johonkin niin, ettei sitä sieltä saanu enää ajoon. Ennen sai kaljakorilla tms kikkailtua noi autot pusikoista pystyyn mutta se ei näemmä enää toimi kuten ennen. Ehkä ihan hyväkin ettei toimi mutta jokin keino voisi olla sitten tilalle. Ainakaan traktorilla en saanu paskarekkaa pystyyn. Enkö sitten vain osannut vai oliko vain väärä väline ja jossain parempi työkalu tuohon?
Satsuman fysiikoita on viime näkemän kyl mielestäni parannettu. Kasailleissa ei tainnut hajota vielä mikään, eikä auto kääntyny yllättäen kyljelleenkään. Pysyi myös ihan mukavasti traktorin haarukassa, paitsi mitä nyt saven jälkeen saattoi siitä tippua randomisti maahan. Viimeksi kun olen satsumaa kasaillu niin jatkuvasti pellit kolisi ja rungolla tuntui aina olevan tarve olla liikkeessä. Kasaan saadessa oli yleensä pellit aivan mutkalla ja ensimmäisenä saikin viedä auton laitettavaksi, ellei halunnut pellit mutkalla ajella.
Jos kaataa rekan tai jää jumiin johonkin tmv niin otat sen esc->quit without saving->continue, ja kannattaa tallentaa melko usein jotta ei menetä edistymistä pelissä (niitä ulkohuussi tallennuspaikkoja löytyy mm. fleetarin paikasta, kaupan takaa, kaatopaikalta). Jos menet tyhjentämään kaivot esim. Lopesta(2kaivoa) tai kylältä(2kaivoa) niin tallennat ennen kaivojen tyhjennyksiä ja kun olet tyhjentänyt niin tallennat ehkä vielä uudelleen.
Traktorilla pystyy nostamaan ainakin tyhjän rekan pystyyn hinaamalla suht tasaisessa maastossa tai nykyään voi onnistua etuhaarukallakin. Kyllä se kai pelihahmon push-jutullakin voi vielä onnistua, mutta se voi olla tuurista kiinni että saa glitchattua juuri sopivasti. Kannattaa käyttää valtatietä rekalla ajoon mahdollisimman paljon koska traktorilla sitä rekkaa ei pysty hinaamaan pois mistään soratien syvistä rotkoista(hinausköyden pituuskaan ei noissa tapauksissa yleensä riitä).
Löytyiskö keltään savea, jossa olisi vakiosatsuma ja jonkun verran pätäkkää?
Ei sillä tarvitse antaa kaikkea mahdollista :confused:
Muutenkin pelin fysiikoissa olevat virheet tuntuvat melkein ominaisuudelta joka kuuluu peliin. Tätä kun on tullut pelattua satunnaisesti julkaisusta lähtien. Pahimmat ongelmakohdat on jo oppinut tietämään.
Eilen kävi juuri niin että tyhjensin 4 kaivoa ja auto lähti lentoon hyttiin noustessa. Turhauttavaa aloittaa kaivojen tyhjennys alusta, vaikka olisi seivannut juuri lähtiessä. No tuli kuitenkin kaivot tyhjenneltyä uudellee ja tallennettua fleetarille tai kaupalle. Sen jälkeen tankkasin auton, ostin kaupasta kaikellaista ja pakkasin kyytiin ja ajelin kotipihaan. Sain auton lähes tyhjäksi ostoksista ja taas auto lähti lentoon. Laskeutui taloa vasten niin, että perä jäi talon katolle ja nokka terassin eteen. Ei liikkunu senttiäkään traktorilla.
Tuommoinen jatkuva bugaaminen vaan alkaa tympiin ja mielummin pelailee jotain muuta, vähemmän bugista. Noh pitää odotella taas jonkin aikaa päivityksiä, onhan tuo edelleen early access, josko tuokin korjaantus. Mielestäni aiemmin tuo paskarekka ei lähteny noin herkästi lentoon. Jotain on muutettu fysiikoissa ja se on satsumasta korjannu juttuja mutta tuohon on sitten taas tullut pahempia bugeja kuin aiemmin.
Toivottavasti ei tuo talvipelin kehitys lähe liikkeelle ennen kun tän pelin saa hyvään pakettiin. Hieno peli kunhan nuo ärsyttävimmät bugailut ja muut jutut korjattas.
Päivitin oman tallennuksen, jossa vakio Satsuma kasattuna ja toimivana. Muuten kaikki kuten uuden pelin aloituksessa.
Kannattaa ladata myös items file, jos ei halua itse asentaa öljynsuodatinta, akkua ja sytytystulppia.
Tallennus vaikutti toimivan myös Experimental Test Branch puolella, mutta venttiilit pitää säätää uudestaan.
Dropbox - My Summer Car Saves - Simplify your life
Oliko käsijarru rekassa ollut päällä jos traktorikaan ei pystynyt liikuttamaan sitä? Sen rekan käsijarru on kait tehty sellaiseksi että se ei hievahdakaan vaikka renkaat(osa/kaikki?) olisi ilmassa jos käsijarru on päällä.
Itsellä on yli 300h pelattuna ja rekka ei ole kuin muutaman kerran hypännyt kyljelleen. Viimeksi kun rekka meni kyljelleen se tapahtui silloin kun olin poistumassa siitä. Ja useasti kun menen rekkaan sisälle käyttäen jump-nappia niin sen käsijarru menee jostain syystä pois päältä.
Kannattaa varoa liikkumasta lähellä rekan kylkeä koska pelihahmon näkymättömän kropan osuessa sopivasti siihen voi aiheuttaa ilmalentoja ja kun menee rekkaan sisään niin pyrkii tekemään sen ehkä mahdollisimman kohtisuorassa siihen oviaukkoon, en tiedä kannattaako välttää jump-napin käytööä siinä vaikka se tekee sisäänmenosta ainakin joskus nopeampaa, mutta voi olla että jos painaa jumpia sen hahmon kroppa osuu rekan hyttiin ja aiheuttaa rekan ilmalentoja myös.
Sen rekan ovet kehittäjä voisi fiksata että ne pysyy paremmin auki. Nyt ne on aina tiellä ellei maasto ole täysin tasaista tai sopivaan suuntaan kallellaan ja sisäänmenoa voi joutua yrittämään monta kertaa ja tuo ainakin vain lisää rekan ilmalentojen riskiä.
Suomi-simulaattori My Summer Car sai jättipäivityksen – mukana kesägrilli - Respawn.fi
Pitänee taas pelata kun päivityskin tuli peliin, mihinköhän päin karttaa se Satsuma hyytyikään...
EDIT: Onkohan tuo päivitys nyt virallisessa pelissä vai beta-versiossa?
Betan puolella vielä.
docci
