My Summer Car
No eiks toi järkkä nimenomaan ole Fleetari?
Peräjärvellä kaikki on niin samannäkösiä muutenkin että taitavat olla aika sisäsiittosia :rofl:
Nyt on tullut jakoon se iso päivitys joka on jo muutama viikko sitten julkaistu beta-versiolle:
UPDATE 18.08.2018
18.elokuu - Toplessgun
WARNING 1: Valve adjustments have changed, be careful not to rev the car until you or Fleetari has fixed it!
WARNING 2: Satsuma 3d model has changed, so delete your meshsave.txt file to avoid graphical glitches
-Fixed issue (again) with in-game clock not working correctly when sleeping
-Fixed issue with front wheel alignment resetting into incorrect angle upon every game load
-Fixed issue with Teimo sometimes heading back to home right after opening the store
-Fixed several bugs with tires when they were replaced by Fleetari while installed to the car
-Car should now slide less when on top of a Floor Jack
-Fixed issue with battery terminals self-tightening the bolts in some cases
-Fixed FPS slowdown issue when having random objects under Satsuma wheels
-Fixed free fuelling exploit
-Increased useful battery life when running engine without working Alternator
-Highway traffic is now more randomized
-Decreased possibility of AI car veering off to oncoming lane towards Player
-Added Fuel Oil pump to Teimo store, note that it is in most cases illegal to use Fuel Oil as Diesel alternative
-Fuel prices are now subject to change
-Player does not die from fatigue anymore, instead getting sleepy or getting black outs (shake mouse to wake up from blackout)
-Added new grilling system, grilling with open fire makes food burn, so grill on embers instead
-Added Brick Grill (uses Firewood) to Cottage and moveable Ball Grill (uses Charcoals)
-Dead moose can be now chopped into meat chunks with Axe
-Moose meat can be eaten after it has been grilled, similarly to fish
-Moose travel paths are now much more randomized
-Added garbage barrel to burn trash
-Added alternative mounting point for the Tachometer on top of the Dashboard
-Added Satsuma charge warning light to indicate if Alternator is not charging properly
-Adjusted Satsuma valve settings, you might need to re-adjust valves or make Fleetari do it
-Made Satsuma valve adjust more precise with smaller tolerances and decreased loose play at both ends
-Adjusted Satsuma engine heat output, overheats easier now
-Satsuma Grille and Hood options now affects engine air flow cooling efficiency
-Getting suspension damage from crashing might now also cause tire puncture
-Improved both Truck and Tractor Parking Brake systems
-Added Beacon light to Truck
-Added Saturday night "dance" and related fist fight mechanics
-Grandma can now call about food deliveries
-Fixed bug with not being able to light a cigarette while sitting on a chair
-Added Coffee Pan for making coffee on open fire or grill
-Made kitchen stove hot plates functional
-Fixed issue with Cigarette causing a fire even after dumping the Cigarette but outhaling smoke
-Added visible smoke before Player's house bursts into flames
-Added smoke detector
-Map changes
-GUI changes
My Summer Car :: UPDATE 18.08.2018
Ja kaikki tuo vain 12.7Mb Steamin mukaan.. :D
Hyviä fiksejä, varsinkin tuo auton liukuminen tunkin päällä, helvetti että oli raivostuttavaa.
Palaillaanpa taas tämän pariin hetkeksi. :)
Onko jotain syytä miksi en saa työkalu laatikkoa auki?
edit:
piti näköjään laittaa näppäimet "reset to default"
Pitkästä aikaa aloin Satsumaa kasailemaan. Tähän asti mennyt hyvin mutta wiring mess otti ja katosi kun eka kerran klikkasin sen kanssa fuse boxia :dead: Yhden kerran auto lähti lentoon kun sohin sitä öljysuodattimella. Eikä tippunut tunkiltakaan kuin pari kertaa. Kehitystä on selvästi tapahtunut!
Mikäköhän tätä Satsumaa vaivaa?
Ostin pelin heti sen ilmestyessä ja nyt kasaan autoa toista kertaa. Edellisellä kerralla sain sen juuri kasattua mutta sitten kyllästyin säätämään ja dumppasin sen järveen.
Tällä kertaa sain myös Satsuman kasaan, wiring mess tosin tuli hieman yllätyksenä kun seurasin vanhentunutta ohjetta. Ensimmäinen käynnistys, kuuluu jotain kilkettä mutta käynnistyy lopulta. Ei ehtinyt käydä montaa sekuntia kun sammui ja onnistuin samalla irroittamaan kojelaudan mittaristo-osan, oli jäänyt mutterit kiristämättä. Laitoin sen kiinni ja tämän jälkeen ei inahdakaan. Kokeiltu vaihtaa akku tallissa olevaan mustaan, alunperin laitoin Teimolta ostetun. Öljynsuodatin on myös Teimolta. Kaikki kaapelit tarkistettu.
Kilke viittaisi siihen ettei venttiileitä ole säädetty oikein?
Laitoitko camshaft gearin oikeaan asentoon? Jos se on väärin niin se hajoittaa melko nopeasti rockershaftin(venttiilinjousia irtoaa) jonka jälkeen auto ei käynnisty. Ota rocker cover pois ja katso rockershaftin tila, onko rikki. Sitten korjaa camshaft gearin asento jos se on väärin ja irroita rockershaft moottorista jos se on hajonnut ja sitten voit ostaa uuden fleetarilta(hyllyssä).
Tuon jälkeen venttiilit nakuttaa edelleen koska ne on väärin ja niille sun pitää löytää joku perussäätö aluksi jossa ne ei nakuttaisi jotta voisit tehdä säädöt korvakuulolta. SIlloin kun ne nakuttaa sä et mitenkään voi tietää että mikä/mitkä venttilit sitä tekee jolloin säätäminen on mahdotonta. Tai voit anta fleetarin tehdä moottorinsäädöt(venttiilit, kaasari, ehkä myös virranjakaja).
Taisi olla akussa ongelma, hain vielä toisen uuden akun teimolta ja nyt sentään saa virtaa ja käynnistyy.
Sitten säätämään. Rocker shaft oli kunnossa. Säädin camshaft gearin, kilinä loppui. Säädin venttiilit 18 naksausta eteenpäin ja 7 takaisin kuten ohjeessa sanottiin enkä kuule mitään ylimääräisiä ääniä moottorista. Sammuttamisen jälkeen jää tikittämään mutta se kai kuuluu asiaan.
Oisko sammuttamisen jälkeinen tikitys jäähdyttimen tuulettimen ääntä?
Sä voit säätää venttiilit vielä paremmin ihan korvakuulolta auton käydessä nyt kun ne on hiljaa. Käännät ruuvia myötäpäivään(hiiren rullaa ylöspäin) kunnes alkaa tikittämään ja sitten vastapäivään kunnes se loppuu, toistat tämän jokaisen 8 venttiiliruuvin kohdalla.
Se sammuttamisen jälkeinen tikitys on pakoputkiston jäähtymistä, mitä voi kuulla oikeastikin kesäaikaan. ;)
Jees, pääsin nyt testilenkille, tuntuu kyllä että tehot on hukassa, ei jaksa kulkea enemmän kuin 60 km/h tai pysty nostamaan kakkoselta. Pärski myös jotain nestettä, ilmeisesti jäähdytysnestettä ja savutti. Pääsin melkein fleetarille kotoa mutta ajoin ojaan eikä auto jaksanut sieltä nousta pois.
Sun pitää laittaa virranjakaja(distributor) vielä oikein(asento) että se moottori toimisi kunnolla.
WARNING: Your Fan Belt might be gone, go buy a new one from Teimo
-Fixed bug with rear shock absorbers not going in after first removing them
-Added telephone bills
-You can now grill food on top of a hot Satsuma engine
-Added purchasable computer
-Spawn point after death is now at the gate of the graveyard
-Alternator Belts (prev. Fan Belt) can be now stocked
-Weather is now being saved
-Driving lights can be now toggled off by keeping Beam Mode button pressed down
-Changed how driving light modes are used in Satsuma
-Added Marker Lights to Parts Magazine
-Added seatbelts to Ferndale
-Fixed bug with Rally where it was not possible to register for a new event if player abandoned previous rally after Saturday stage
-Spark plugs have now also visual indication about their condition
-Added Wristwatch (you need to fight for it!)
-Added roll down windows to every vehicle, but not for passenger sides for performance economic reasons (:D)
-Added Wood Stove and Wood Chopping to Ventti-cabin, which activate after you win the cabin
-Staying at the Cottage island reduces stress now
-Gifu truck requires now rev matching when changing gears, applies only to players using H-Shifter controller
-Made highway little more bumpy
-Added roll down windows to every vehicle, but not for passenger sides for performance economic reasons :)D)
Tuo moottoritie on lähinnä perseestä.
Ihan mieluusti samanpituinen ovaalirata saisi tulla huristeltavaksi, Shitsumalla ei mutkaan tahdo uskaltaa päästää nappi lattiassa.
Eihän tuossa "moottoritiellä" ole kuin 3-4 mutkaa johon pitää hiljentää :confused:
Ennen päivitystä siis.
Kahdessa mutkassa sinne sataanneljäänkymppiin, ennen päivitystä. Nykyään sillan yli, kaikki mutkat joutuu himmailla...
Hiacella hyvä ajaa, 120kmh mittarissa on poliisin gepsiin ollut jotain 130kmh+, ja 100kmh liki 120kmh :D
Kun tuosta tarvikekatalogista selailee auton osia ja tekee tilauksen niin mihis tuo kirjekuori nykyään menee?
Ei löydy enää siitä vierestä eikä muualta asunnosta.
Taitaa olla bugi. Mullekin kävi joskus samanlailla. En kyllä muista miten korjaantu pitikö alottaa uus save, vai korjasko joku päivitys sen.
Jos sinulla on valmiiksi tilaus sisällä niin silloin kirjekuori ei spawnaa, mutta taitaa olla bugi mikäli ei ole.
Taisi olla joo, edelliskerrasta oli monta kuukautta kun tätä tuli pelattua. Pari pakettia löytyi Teimolta ja sama racing vauhtipyörä löytyi kaupalta kahteen kertaan eri reissuilta :D.
Jaaha, alotinpa uuden pelin jälleen kerran ja nyt renkaita ei löydy mistään.. :confused:
EDIT: nopea kookletus kertoi että renkaat on nyt jonkun kummittelevan talon ullakolla, Fleetarin lähellä.. :dead:
Joo, kummitustalon ullakolla. Siellä on päivisin ampiaisia joten kannattaa mennä yöllä jolloin siellä kummittelee.
Onko tuo se palanut tai puoliksi tuhoutunut talo? Viimeksi kun kävin sitä tutkimassa en päässyt sisään muuta kun johonkin nurkan kellariin tms.
Joo, tarina kertoo että paloi pikkupoikien tulitikkuleikkien seurauksena. Sisään pääsemiseen tarvitsee lekaa tai ajoneuvoa jotta oven saa murjottua.
latest
Tämä on sellainen peli että ilman editoria mun hermo ei tätä kestä 5min pidempää ja todennut että mielummin katson kun joku pelaa ja kärsii bugeista.
Se tunne kun olet kolmatta kertaa kasaamassa satsumaa ja kolmannen kerran bugin takia auto tuhoutuu:beye:
No nyt ne vetää livenä. Jospa tulis joskus tännekkinpäin.
Isoa päivitystä tulossa.
Information about next update! :: My Summer Car General Discussions (Owners)
People have been asking when the new update is coming. Well I do not have exact answer to that, as it is hard to estimate how much certain things take time to develop. This update is different than many of the previous ones, as this require a lot "manual" work. In short: developing a carburetor is easier and faster than human to human dynamics.
So this next update will add hopefully all the missing story lines (game ending, closure) and introduces also new characters related to that. Together with that goes also random set of other changes and fixes as usually. One thing with this update is that because it basically adds the whole story and spoils it too, I try to make sure that it actually functions correctly as well. Such things take more time to figure and test out. I do not envy game studios that work on story-driven games :D
But due the possibly game breaking nature of the update, it will go to the Experimental branch first so do not worry that one day it hits the main branch and you are not being warned.
So, stay tuned! Also if you do not want any spoilers about the new content, get out of the MSC-Internet before the update hits :D
kevennyksenä :D
Tulipa pitkästä aikaa päiviteltyä MSC ja heitettyä Hayosikolla lenkki Teimon kautta takaisin kämpille. Heti eka ongelma; vaihteet ei pysy; pitää kytkin pohjassa laittaa manuaalisesti 1-2 jne ja pitää itse pohjassa. Bugi?
Noin muuten, kylällä näkyi uusi amisautoilija ja kotio päin ajaessa tanssilavamesta? Mitkäs on noin niinkun vaikka 5 isointa uudistusta vuoden sisään?
Auto clutch-asetus pois päältä? Noin sen mielestäni kuuluukin toimia ilman sitä.
Auto-clutch päällä, silti(kään) ei pysy vaihde silmässä, vaikka ennen toiminut ihan jees?
Mitä reittiä Teimo fillaroi töihin/töistä kotiin? Ja mihin aikaan yleensä siihen törmää?
htjk
